iPad screen impossible to see
2324 16 2015-2-4
ranchbroker.me
Using an iPad air 2 in bright sunlight and even on a cloudy day, I'm having trouble seeing the screen image in both Map and camera mode.  Any ideas about what to do.  I've turned up the screen brightness to max, still the image is difficult to see.    Is there another device that has a clean bright visual of what the camera sees.   Goggles or android?
Help!
2015-2-4
Playful Monster
You did the swipe up menu and moved the bar over to the brightest setting?
2015-2-5
ranchbroker.me
Playful Monster Posted at 2015-2-6 03:36
Yes I did swipe.....and move the bar...  Thinking about FPV
2015-2-5
laurent.crivell
Flight distance : 52549 ft
Switzerland
Do you have the same issue when looking the screen in the dark (or inside) ?
2015-2-6
lethbrp
I think this is just a limitation of viewing tablets in daylight. The Inspire video of Jamie Savage shows him using hoods. I'm guessing these are hand made, as I can't find any on the interweb.
The Nvidia is an 8" tablet and most hoods are 7". Its also go to go around the bracket somehow. Well DJI, I think there is a market here for you, if you want to create a universal tablet hood for the Inspire handset.
2015-2-6
craigarthurson.
I use the satin finish typ screen protect stop all the reflective glare and a sun hood
2015-2-6
misticsea.yahoo
Flight distance : 87228484 ft
Hoodini should be in stock soon
2015-2-6
jebryant10.att
Flight distance : 56112 ft
I have this it works and helps a lot. Collapsible Molded iPad Sun Shade and Privacy Hood for $30. https://www.etsy.com/transaction ... p;x_eaid=ac009513af
2015-2-6
AshInspire1
I need one for an iPad mini 2 if any one knows where to get an actual decent one from. I agree it's impossible to see and when you can the aircraft is behind you haha
2015-2-6
darickyeo.gmail
Flight distance : 4108688 ft
Singapore
http://www.ebay.com.sg/itm/251666886658
2015-2-6
InspiredOne
I just got one of those for my iPad Air 2 from Amazon yesterday. Piece of junk., doesn't fit tightly, flops around, too heavy, and prevents iPad from fitting securely into holder on controller. That's my opinion. It's going back to Amazon.
EDIT: There's no port (hole) for the cable going from the iPad to the controller.
2015-2-6
lethbrp
darickyeo.gmail Posted at 2015-2-6 21:26
Thank you. These look just the ticket!
2015-2-6
InspiredOne
lethbrp Posted at 2015-2-6 22:36
See my post above.
2015-2-6
svencool
Flight distance : 6690 ft
Thanks for saying so I was just thinking about maybe getting a couple of them! Not now!!!!
Mike
2015-2-6
AegisFC
Flight distance : 12372 ft
Do you have the filter installed on the camera?  I took mine off and put on the clear cover.  Really made a difference.
2015-2-6
rodger
Flight distance : 20145135 ft
AegisFC Posted at 2015-2-6 23:50
Do you have the filter installed on the camera?  I took mine off and put on the clear cover.  Really ...
The Filter is not the issue. He is suffering from glare. He needs the Hoodie.
2015-2-6
rodger
The clear cover is a filter for UV Haze. It will make a big difference.
2015-2-6
