DJI GO Version 3.0.2 Issue
12Next >
4915 48 2016-11-2
fansd8b91b11
Flight distance : 141427 ft
Brazil
[size=14.6667px]Installed DJI GO version 3.0.2 in Ipad 4 mini ios 10.1.1
[size=14.6667px]Now, In Flight logs tapping on any one log, displays "NO GPS SIGNAL" and screen stays black, no data.
[size=14.6667px]My other device ios version 9.0 with DJI GO version 3.0.0 still displays map, data etcs.
[size=14.6667px]In a Galaxy Android 5.0.1 DJI GO version 3.0.1 works ok and dispays map.
[size=14.6667px]Someone else having this kind trouble ?
[size=14.6667px]It seems to be to do with DJI GO new version 3.0.2 ?
[size=14.6667px]Thans in advance. Juan
2016-11-2
Aardvark
Flight distance : 384432 ft
I'm getting the same here.
So DJI Go again, one step forward and two back........
Tried on both iPad Pro 9.7 and iPhone 6s plus.
2016-11-2
fansa84fe8a4
Flight distance : 3 ft
Ditto the above.  3.0.2 reports "No GPS Signal" on a dark gray/black screen on mine as well with iOS 10.1.1.
More odd is you can press the 'forward arrow' and it will move as if it were playing back the flight (sans map), then hit the control sticks and it shows them both in blue with a full down stick as well as a full left stick on both.  Screen is still gray and no map though.
Yep.  It's broken.
So how do I get back to 3.0.1?
2016-11-2
Aardvark
Seems to be date specific, I synced all my flights (and lost a few by the look of it), Flights from start of October onwards are reporting "No GPS", Flights up to the end of September are playing okay.
2016-11-2
fansa84fe8a4
Aardvark Posted at 2016-11-3 07:54
Seems to be date specific, I synced all my flights (and lost a few by the look of it), Flights from  ...
Same here.
ALL October flights other than one are gone!  The one remaining shows NO GPS and no map.
September flights are there and play.
Guess I'll have to go out and see if it will work for November flights before I try and figure out how to roll back to 3.0.1.  There is a YouTube of doing it though Apple Store, but it is a real mess of editing the Store with a secondary app to get it.
2016-11-2
fansa84fe8a4
I got back to 3.0.1 (2726) via iTunes on the desktop where I backed up prior to the 10.1.1 iOS upgrade to the iPad.  I just deleted the DJI Go on the iPad, opened iTunes, Apps and the old DJI Go was there and set it to Install.  Sync & Done.  Pretty quick.
However, bad part is that doing that erased ALL flight records too.  Clean slate.
2016-11-2
Aardvark
fansa84fe8a4 Posted at 2016-11-2 23:53
Ditto the above.  3.0.2 reports "No GPS Signal" on a dark gray/black screen on mine as well with iOS ...
You may have a recent backup on iCloud, or in iTunes that you could restore.
2016-11-2
vandruten
Indonesia
Oh snap. Just pressed "update all" on the appstore and Go 3.0.2 was in it. Hopefully it'll be raining today as a reason to not flying.
Any response, DJI? Please hurry.
2016-11-2
DJI Natalia
Flight distance : 318 ft
Thanks for your feedback, would you please sync your flight records through APP, and provide us your APP account username, we'll help you check it, thanks.
2016-11-2
DJI Natalia
fansa84fe8a4 Posted at 2016-11-3 07:53
Would you please sync your flight records and provide us your account username? we'd love to help you check it , thanks.
2016-11-2
dave75
Flight distance : 15096995 ft
Mine flights are all corrupted too. Same no gps
2016-11-2
fans06a48882
Flight distance : 263465 ft
dave75 Posted at 2016-11-3 05:10
Same issue here too - when opening a flight log, I get a brief flash of the UK map and then the whole screen goes grey with "no GPS signal" across the middle. You can still press the play button and the time cursor moves along but no change to the grey screen at all.
I've tried force closing the app, rebooting the iPad and also did a hard reset with the home/power button combination but the issue still remains.  Also tried swapping between the two craft I gave craft in the app (Phantom 4/Phantom 3 Pro) without any effect on the issue.
2016-11-3
Focusian
Flight distance : 155443 ft
Thailand
Really ?!  i will immediately disable DJI Go update.
2016-11-3
Hello Juan, I've synced your flight records and it's all normal.
Here is the screenshot for your reference.
Have you tried to reinstall the app or syncd the flight records again?
2016-11-3
Cetaman
Flight distance : 2528264 ft
DJI Natalia Posted at 2016-11-2 17:25
Would you please sync your flight records and provide us your account username? we'd love to help  ...
Aloha Natalia,
     This is kind of strange.  There is no iOS download for DJI GO version 3.0.2 on the downloads page for P4 and P3P.  I do not have an iOS device but constantly check to see if there is an upgrade.  Last check was 12:00 AM Hawai'i time (Central Pacific I guess).
Aloha and Drone On!
2016-11-3
fansa84fe8a4
Baldo81 Posted at 2016-11-3 18:12
DJI Natalia Posted at 2016-11-3 15:22
Have you restarted all device and check again, still the same ...
At least your rollback shows some logs.
Mine are 100% gone, but I uninstalled and reinstalled 3.0.1 via iTunes on the computer backup and sync.   Now it's like I never had GO prior and I had to log in with email and password all over.
2016-11-3
Ulysse
Flight distance : 1389931 ft
Belgium
Once again, a complete failure from DJI.
This company has absolutely and definitely no pride and no respect for the customers.
2016-11-3
JACKODOG-ANDROI
Flight distance : 208383 ft
2.8.0 flying great!!
2016-11-3
fans991e763e
I new better than to update the app, just my gut feeling.  Figured if the app update works anything like the Mavic, it's worthless.  Still on 3.0.1 and no issues with P4.  DJI- this whole Mavic situation has been a huge disappointment.  Not buying one.  P4 will be my last.
2016-11-3
JACKODOG-ANDROI
i think i would put lightbridge on my f550 flamewheell before i bought new!
2016-11-3
dkruseski
Flight distance : 791184 ft
So is 2.8.1!
2016-11-3
crackthesky
Flight distance : 123402 ft
Flying with IPAD Mini 4 with wifi & 4G/LTE. Updated to DJI Go V 3.0.2 today and everything is flying & working flawlessly. Never even restarted the Mini 4.
2016-11-3
keiser08
Flight distance : 446355 ft
Mine is running great after using 3 batteries to 50%. I did lose all my flight logs
2016-11-3
MD_Icarus
You "auto update" brave guys should have realized by now that you are our beta testers!
Thanks for reporting your woes, and for all your sacrifices ! {:4_157:}so the rest of us, manual updaters, can wait, till you report that a good version came out, so we can update too!
You Deserve a Metal for Bravery! Metal
2016-11-3
Cetaman
Aloha JACK,
     If I recall right, 2.8.0 was nice and stable back when.  What firmware are you using for the aircraft and the remote controller?
Aloha and Drone On!
2016-11-3
Cetaman
Aloha kruseski,
     So 2.8.1 is nice and stable?  What firmware are you using for the aircraft and the remote controller?
Aloha and Drone On!
2016-11-3
MD_Icarus
I am staying with 10.0.1 and RC1.8 and the latest firmware; but I am using iphone and it works well.I think the RC1.8 and ap 10.0.0 issue was affecting android devices, so maybe the 10.0.2 update to fix android, messes up ios?
2016-11-3
Cetaman
Ulysse Posted at 2016-11-3 04:15
This company has absolutely and definitely no pride and no  ...
Aloha Ulysse,
     How can you say "complete failure" like that.  You are failing as a customer.  If you keep acting like that you are justifying bad behavior in return.  You should sell all your DJI products and go with some other company, after all you say the DJI failure is complete!
     Hope this helps!
Aloha and Drone On!
2016-11-3
Cetaman
MD_Icarus Posted at 2016-11-3 19:08
I am staying with 10.0.1 and RC1.8 and the latest firmware; but I am using iphone and it works well. ...
Aloha Icarus,
     The 10.0.1 is the iOS operating system version.  The only place I have seen DJI GO ver. 3.0.2 is on the Mavic Pro web page, downloads page.  Android does not have access to DJI GO ver. 3.0.2 yet, even on the Mavic Pro, downloads page.  So how are the iOS guys getting DJI GO 3.0.2?
     RC ver. 1.8.0 is still giving me problems, so I am rolled back and slowly testing as I try to get current.  Currently at RC ver. 1.6.0.
     I wonder if the KARMA guys are playing Krishna and planting bad versions of DJI GO 3.0.2 out there for DJI customers who are not using the DJI Web Site to download DJI GO since they got their KARMA okoles kicked so badly.  Hmm!?!
Aloha and Drone On!
2016-11-3
Ulysse
Belgium
Cetaman Posted at 2016-11-4 07:13
Aloha Ulysse,
     How can you say "complete failure" like that.  You are failing as a customer.  ...
On almost every DJI Go update new problems and bugs appear.
I have a lot of apps on my iPad and all of them are updated when an update is available. With DJI Go I always wait a few weeks to be sure I'll not be grounded.
If you think it is normal to be a beta tester for a company I'm happy for you. But this is not my "religion".
For everything related to aviation (and flying a quad is related to aviation) I have zero tolerance !
2016-11-3
mactech
How many times must you do this to your customers DJI?   No quality control.  This isn't how you're going to take over the world.
2016-11-4
Cetaman
Ulysse Posted at 2016-11-3 20:56
I have a lot of apps on my iPad and all ...
Aloha Ulysse,
     So, like I said, sell everything and go with another company that is not a complete failure.  Otherwise you just sound like a hypocrite.  We have no need to listen to you belly ache about your failure as a customer.  You appear to have no concept of what you are dealing with.  Plus, if you are unable to fly DJI products safely, then you are dangerous.  You owe it to the world to sell and get out.  So go.  We can fly safely.  You are compromised.
Aloha and Drone On!
2016-11-4
SBX8
Flight distance : 734442 ft
I guess I will stay with 2.9.2 then
2016-11-4
fansa84fe8a4
Fwiw, iOS 10.1.1 is the newest from Apple.  The 10.0.x series screwed up the barometer in the cellular models that have one.  In Autoflight, they use the phone/tablet's barometer for the "follow-me" up and down hills portion, etc. so it wasn't working for altitude changes.  With 10.1 it is working again.  That was an Apple screw-up.
The DJI GO 3.0.2 is a "No GPS Signal" screw-up in the flight folders and review along with possible deletions of prior flights.  At lest 3.0.1 was and is working for me now that I recovered it.  I just need to turn off Auto Updates though...
2016-11-4
brunobaptista55
Flight distance : 1369839 ft
Brazil
Restarting helped my situation. But I was lucky to have a second device also synced previously so I could almost put everything back at normal.
When I synced flights using 3.0.2 it erased/"NO GPS" all my november flights (I always choose 1 month sync).
I usually fly with my iPad and I tried to sync from there. I had also my flights synced to my iPhone (with 3.0.1). What I did was restart both devices and sync my iPhone (which had everything so far) and then sync my iPad (which had deleted november). November flights appeared back on iPad, nothing was erased from iPhone, and all seems in order EXCEPT the "Growth of value" which increased as if I synced additional flights.
The stats (distance, time, max distance, etc) seem to be ok.
2016-11-4
fansb1fe1104
Flight distance : 3372566 ft
dave75 Posted at 2016-11-3 01:10
I have same issue..Keeps saying no GPS, this is my 3rd phantom in the past 2 days with this one the only one seeming to work right until I get this No GPS thing....whats going on????
2016-11-4
fansa84fe8a4
fansb1fe1104 Posted at 2016-11-5 04:47
I have same issue..Keeps saying no GPS, this is my 3rd phantom in the past 2 days with this one th ...
It's a bug in the 3.0.2 iOS version.
Stay with 3.0.1 to avoid the "No GPS Signal" and erasure of your flight logs matter.
2016-11-4
DJI Natalia
May I know have you tried to restart your mobile device, connect the internet and sync flight records again?
2016-11-5
SoCal Dude
Flight distance : 695650 ft
So, I did not realize it, but my iPad Air 2 (128 GB, wi-fi only) updated my DJI Go app five days ago to v3.0.2 and I have flown 5 times since.
Everything is fine and I have not noticed anything out of the ordinary.
However, I have NOT updated my iOS to 10.1.1. I think I'll hold off on that update until later.
p.s. I have a P4 with version 01.02.0503 and remote controller is at version 1.8.0
2016-11-7
fansa84fe8a4
Baldo81 Posted at 2016-11-7 18:47
Yes I did, deleted app and clean install as well.
On 2 iPhones 3.0.2 is working fine, but not on m ...
Interesting.
I wonder if the 3.0.2 bug (i.e. "No GPS Signal" & erasing of recent flights.) is just related to the iPads?
I have the iPad Air 2 + Cellular with the 3.0.2 bug.  Back to 3.0.1 and it is OK.
Running 10.1.1 now too.  The 10.0.1 and 10.0.2 had a bug with the cellulars where the internal iPad barometer would not be recognized by sundry apps that used it.  10.1.1 fixed that, but it was an Apple bug there and they fessed up to it.
Now to wait for GO 3.0.3 to fix the current 3.0.2 bug in the iPad Air 2 + Cellular.
2016-11-7
12Next >
