Issues transferring X5R footage to OSX
1129 10 2016-11-10
MinusRed
I have an Inspire 1 RAW, with the Zenmuse X5R,  and when I try to access the SSD from my MacBook Pro, it shows up as empty.  However, the files show up in CinElite. Does anyone know why I can only access the files through CinElite, but not directly through finder or any of my other Video Transcoding programs? Thanks for any help.
2016-11-10
DJI-Jamie
Flight distance : 112405 ft
The main importer is Cinelight. You can export to other programs, such as Adobe, from there.
2016-11-10
MinusRed
DJI-Jamie Posted at 2016-11-11 03:00
That is he one I meant! Not CinElite, it is Cinelight! Sorry.
2016-11-10
MinusRed
MinusRed Posted at 2016-11-11 03:12
But not all of the footage is showing up. I playback from my monitor all the footage, but only some of it shows up in cinelight.
2016-11-10
DJI-Jamie
MinusRed Posted at 2016-11-11 03:13
But not all of the footage is showing up. I playback from my monitor all the footage, but only som ...
All the footage is RAW, correct? Have you checked the regular SD card to see if anything was saved there? Do you see a trend as to which ones are not showing up such as plain stills?
2016-11-10
MinusRed
DJI-Jamie Posted at 2016-11-11 03:16
All the footage is RAW, correct? Have you checked the regular SD card to see if anything was saved ...
The trend is that it is all footage from around the same time. I have not checked the SD card, I will do that next.
2016-11-10
DJI-Jamie
MinusRed Posted at 2016-11-11 04:13
The trend is that it is all footage from around the same time. I have not checked the SD card, I w ...
Please keep me posted.
2016-11-10
MinusRed
That worked! They were all on theMicro-SD. Thanks for the help! Any idea why that happened though? Is it some kind of  setting?
2016-11-11
DJI-Jamie
MinusRed Posted at 2016-11-11 19:07
That worked! They were all on theMicro-SD. Thanks for the help! Any idea why that happened though? ...
Glad to hear you found them. Any video that's not shot in the Cinema DNG format (like MOV or MPG4) would save to the SD card and not the SSD. If you were in Cinema DNG before, perhaps you may have accidentally switched to MOV or MPG4?
2016-11-11
MinusRed
DJI-Jamie Posted at 2016-11-11 15:46
Glad to hear you found them. Any video that's not shot in the Cinema DNG format (like MOV or MPG4) ...
Sorry for the late reply, but you were right that was the problem. Thanks for the help!
2016-11-22
DJI-Jamie
MinusRed Posted at 2016-11-23 03:25
No problem. Happy flying!
2016-11-22
