Mavic Pro wavy video and gimbal warnings
12Next >
22819 53 2016-11-12
Enzo65
Flight distance : 734485 ft
Hi,
This was the second weekend I've flown my Mavic Pro and a problem started today with my gimbal and/or the video/photo quality.  My videos are all wavy (see below) and photos (attached) as well.  I also received a couple warnings today saying "Gimbal Motor Overloaded" and "Abnormal Gimbal Vibration".
Does anybody reconize this problem?  Is my gimbal motor shot and does this require sending in the Mavic for service?  Any idea how long this type of service takes?
After anxiously waiting for it to ship, for this to happen now is so disappointing.
Thanks,
Jeff
2016-11-12
symbol
Flight distance : 440981 ft
Make sure the gimbal hasn't popped over any of the corner stops (little plates). I think there's 3 - 2 front and 1 back. Haven't got mine yet but saw this mentioned elsewhere.
2016-11-12
Enzo65
symbol Posted at 2016-11-12 18:34
Make sure the gimbal hasn't popped over any of the corner stops (little plates). I think there's 3 - ...
My Gimbal tabs are correct and it's moving freely and I still have the problem.
2016-11-12
Hello Jeff, could you please refer to the image and check the gimbal if it is normal?
2016-11-13
fans55dd4de5
Flight distance : 1232677 ft
i got sort of the same Problems, see Video
for me it is sort of an pid problem,
i can see micro vibrations with happen in sort of regular time, nearly every 15-20 seconds,
contacted the dji support allready, up to this point i checked the following things:
gimbal moving freely
no dampening thingies were sliped out of place
the gimbal is not stuck behind one of his limiting clamps
propeller are in balance
motors without propellers are running smooth, no vibrations or unbalance visible
did the following:
imu calibration
gimbal calibration
dji support told me to do this process again without sd card, i dont know why this matters,
success no.
still got micro vibrations, the footage is not usable and pictures are even worse.
i will contact dji support germany on monday and i think i have to send it in for service.
crop
crop
original
original
2016-11-13
Enzo65
DJI Mindy Posted at 2016-11-13 03:19
Hi, Yes I can confirm my Gimbal is sitting normally according to this picture and the dji pre-flight tutorial video and I still have the problem. Any other ideas?
I hope it can be fixed through firmware instead of sending in for repair.
2016-11-13
watuse
Flight distance : 2064587 ft
fans55dd4de5 Posted at 2016-11-13 17:12
https://www.youtube.com/watch?v=zPYBRkiQUsU
you just got this drone last week
2016-11-13
fans55dd4de5
i got it three weeks ago, but i was on an vacation, so i just tested it since monday, 4 flights now.
but every footage got these micro vibrations.
2016-11-13
Enzo65
fans55dd4de5 Posted at 2016-11-13 15:50
i got it three weeks ago, but i was on an vacation, so i just tested it since monday, 4 flights now. ...
After 2 days and 8 flights of having these suspected micro-vibrations causing wavy video and photos, the problem disappeared this afternoon.  The only thing I did was rotate my blades switching the fronts and backs.  I'd like to think this problem is solved in my case (fingers crossed).
@fans55dd4de5 - you said your blades are already balanced so maybe your cause is different than mine, but your photo of the crane looks exactly how my photos turned out when i was having the problem.
2016-11-13
Enzo65 Posted at 2016-11-14 00:36
Hi, Yes I can confirm my Gimbal is sitting normally according to this picture and the dji pre-fligh ...
Could you please take some photos of your gimbal and post it here?
2016-11-13
jn005pyKOxC3
Same problem here. I flew it twice, with the same result.  Couldn't resolve the problem, so I sent it back to DJI last week. They should receive it on the 16th of Nov, so I will let you guys know what the turn around time is. Very disappointing... Just hoping that it was damaged during shipping, and not a systemic problem that will result in a later recall.
Flight#1 - 1080P, 60fps
Flight#2 - 4K, 30FPS
2016-11-14
Enzo65
jn005pyKOxC3 Posted at 2016-11-14 22:06
Same problem here. I flew it twice, with the same result.  Couldn't resolve the problem, so I sent i ...
Sorry to hear that. Thanks for keeping us updated if DJI gives you more information from the repair. The problem for me went away but it would still be good to know the problem in case it returns.
2016-11-14
Enzo65
DJI Mindy Posted at 2016-11-14 10:02
Thanks for your interest to help. For now, the problem has stopped as of yesterday.  If it reoccurs I'll let you know.
2016-11-14
Enzo65 Posted at 2016-11-15 12:57
Thanks for your interest to help. For now, the problem has stopped as of yesterday.  If it reoccur ...
Thank you for the update.
If there's anything I can help with, please let me know. :-)
2016-11-14
Enzo65
DJI Mindy Posted at 2016-11-15 15:14
Hi DJI Mindy,
My problem with a wavy, distorted imaging from the camera has returned.  I've attached pictures of my gimbal and everything is correct.  Do you have any other ideas as to the problem?  Thanks! FullSizeRender-1.jpg
2016-11-16
vuwn6MOD1YLB
India
I have the same problem!!
2016-11-18
droneflyer99
Flight distance : 1138330 ft
I'm having the same issue. Really frustrating. Seems to occur randomly. Makes footage unusable.
2016-11-19
fans2b1b59ae
I am also having this problem
2016-11-25
rapcon
Flight distance : 8871 ft
fans2b1b59ae Posted at 2016-11-25 20:01
Having the same issue noticed on first flight.  Received Mavic yesterday; updated firmware, calibrated compass, IMU, and gimbal; no changes.  Just seems the gimbal is is floating too much.
2016-11-26
fansf049c902
Also having the same issue. I've noticed it before but didn't take any mind to it because I thought it was just the cold. But today it did it again. Here's a video
2016-12-21
fansf049c902
https://youtu.be/eDV7YcvbqY0
2016-12-21
DJI-Ken
Flight distance : 1515312 ft
fansf049c902 Posted at 2016-12-21 08:50
They are aware of it and this can happen in very cold weather, You video show snow so I'm guessing it's due to the cold weather.
2016-12-21
fansf049c902
Ok thanks ken
2016-12-21
chasiu75
Flight distance : 154885 ft
DJI-Ken Posted at 2016-12-22 00:06
I noticed the cold affected it as well.  It will shake and make a noise.  Sometimes will give you a error.
2016-12-21
DJI-Ken
chasiu75 Posted at 2016-12-21 10:01
Yes, they are aware of it, working on it.
2016-12-21
D_jan_i
Flight distance : 562802 ft
DJI-Ken Posted at 2016-12-21 12:18
Hi Ken, I hope they know how to fix it because my one arrives today in your service center. It showed exactly the same problems. And not only at 32 degrees. My one showed it too up to 45 degrees. I just wonder why some Mavic owners never had the issues and even flying in 10-20 degree (always Fahrenheit)?
2016-12-21
DJI-Ken
D_jan_i Posted at 2016-12-21 11:11
If yours did it well within the operating temperature than that's possibly a different thing. They'll probably repair/replace your aircraft.
2016-12-21
D_jan_i
DJI-Ken Posted at 2016-12-21 13:31
It was never operating fine since I got it back from my last DJI service. Somehow I would prefer they would know where the vibrations/waves are coming from and they improve the whole drone to be resistant against everything. I fear it's a hardware problem
2016-12-21
timur.weknowmac
Flight distance : 18255 ft
Had the same issue sent in for repair, replaced the Gimbal at no cost. Repair was super fast.
2016-12-21
D_jan_i
timur.weknowmac Posted at 2016-12-21 15:04
After my first service I got a replacement drone and I had it for a few days and could send it back because the new had this problem. So from 4 week having my DJI Mavic I had it traveling through the states for 3 weeks  :-)
Each delivery from Michigan to California takes 4 complete business days - I brought it to UPS on Thursday and it arrives today
2016-12-21
DJI-Ken
D_jan_i Posted at 2016-12-21 11:53
I see, I'm sure they'll work it out.
2016-12-21
DJI-Ken
timur.weknowmac Posted at 2016-12-21 13:04
The turn around time is fairly quick (less shipping time) for a Mavic
2016-12-21
DJI-Ken
D_jan_i Posted at 2016-12-21 13:34
Sounds good, make sure to report here how it works after your flight.
2016-12-21
D_jan_i
DJI-Ken Posted at 2016-12-21 17:59
I promise I will reply - but if it won't work then I'm not sure what to do, then DJI hopefully offers me a special deal for the Phantom 4 Pro, that seems to be an interesting drone for me...
2016-12-21
DJI-Ken
D_jan_i Posted at 2016-12-21 18:24
DJI will not let you exchange for a different aircraft. They will repair or exchange the Mavic for another Mavic.
2016-12-21
fansf049c902
I was just thinking. Today was the first time I've flown with out the gimble cover on and the wavy and jello effect happened. Tomorrow I'll try again with the cover on and see if it helps keep the camera warm enough.
2016-12-21
D_jan_i
It's really strange that it happens to so many people - I was reading that the Mavic needs probably some time to acclimatize to the temperatures, would be interesting if this is the key. But nevertheless, it shouldn't happen
I hope to get my Mavic back soon, I hate that there is no way to expedite the delivery. It will be the second time that I can't take my Mavic to a nice trip...
2016-12-22
stratosHD
Flight distance : 1231280 ft
fans55dd4de5 Posted at 2016-11-13 20:12
looks that you got the "artistic version" sorry buddy hope they fix it soon
2016-12-22
fansf049c902
So this morning I tried again with the gimbal cover on. Yesterday it was about 25 degree outside today is warmer around 30-35 degree but really windy. This is the resaults I came up with. Looks like it's just to cold for the camera and the gimbal cover helps keep it warm enough
https://youtu.be/s2R2IYklz1Y
2016-12-22
czkidd
Flight distance : 991 ft
Mine does this too.  it was cold out.  In FL it did not do this.  it was 78 out.  Im not currently in FL.  in OK.
2016-12-22
12Next >
