Hi all,
Does the Mavic capture geotags with the images?
It would be good, straight back to that awesome spot in space for another shot
Obvs, you can set a way point for locations and that way be able to return to the same spot in space, I believe?
When setting a predefined path with way points and setting speed to suit - can you run the active track at the same time, so the camera will follow subject (flight path suited so as not to exceed gim- rotation)
In active track can you nudge the drone from intended flight path and then let it resume control without further command or does it just stop in space? Same for gimble, if I were to look away from my moving subject, take in some natural beauty and then return to my moving subject - will it continue to active track?
Any, "it can do this" and any other cool tips gratefully received
Cheers
