Phantom 4 Pro Now Introduced
52575 884 2016-11-15
Tahoe Ed
Flight distance : 41668330 ft
Phantom 4 Pro
Visit the store page here!
Available for pre-order today (11-15)
Product Summary
An updated camera is equipped with a 1-inch 20-megapixel sensor capable of shooting 4K/60fps video and Burst Mode stills at 14 fps. The adoption of titanium alloy and magnesium alloy construction increases the rigidity of the airframe and reduces weight, making the Phantom 4 Pro similar in weight to the Phantom 4. The FlightAutonomy system adds dual rear vision sensors and infrared sensing systems for a total of five-directions of obstacle sensing and four-directions of obstacle avoidance.
The Phantom 4 Pro camera system has been significantly upgraded from the Phantom 4, improving every part of the camera including, sensor size, resolution, image processing system, and more, making it the most powerful Phantom camera ever.
______________________________________________________________
1-inch 20-megapixel CMOS
Sensor size is more important to image quality than the number of pixels because a larger sensor captures more information in every pixel, improving dynamic range, signal-to-noise ratio, and low light performance. The 1-inch 20-megapixel CMOS sensor in the Phantom 4 Pro is four times the size of the Phantom 4's 1/2.3in sensor. It uses larger pixels and has a maximum ISO of 12800 as well as increased contrast. It is good enough for images to be used immediately, while also capturing enough detail for advanced post-processing.
Production optimized 4K
An enhanced video processing system allows video to be captured in cinema and production optimized DCI 4K/60 (4096 x 2160/60fps) at a bitrate of 100Mbps, enabling you to get high-resolution slow motion shots. The Phantom 4 Pro also supports the H.265 video codec (Maximum resolution 4096X2160/30fps). For a given bitrate, H.265 doubles the amount of image processing as H.264, resulting in significantly enhanced image quality. Record in the high dynamic range D-log mode to make the most of this image data for color grading.
High resolution lens
The resolution and contrast of a lens is critical to image quality, because only a quality lens can capture sharp, vivid photos at high resolutions. The brand new Phantom 4 Pro camera has an aerial optimized F2.8 wide-angle lens with a 24mm equivalent focal length. It features eight elements – 2 aspherical – arranged in seven groups that fit into a smaller, more compact frame. Its images are consistently detailed with low distortion and low dispersion, ensuring that photos and videos are sharp and vivid. For the first time ever with a DJI camera, MTF (Modulation Transfer Function) results for this camera have been made public, so people can get a better understanding of lens performance.
Five Direction obstacle sensing
FlightAutonomy is expanded with an additional set of high-resolution stereo vision sensors placed at the rear in addition to the pair placed at the front as well as infrared sensing systems placed on the left and right sides. This network creates a total of five-directions of obstacle sensing and four-directions of obstacle avoidance, protecting the Phantom 4 Pro from more obstacles and giving filmmakers the confidence to capture more complex images.
Pilots always need to be aware of obstacles when shooting from the air. This is a challenge for beginner pilots as well as experienced pilots, especially when sight lines are obstructed. The Phantom 4 Pro is equipped with an environment-sensing system based on stereo vision sensors and infrared sensors. It is able to detect obstacles 98ft (30m) in front, allowing it to plan its flight path to avoid them or simply hover in the event of an emergency. This same system also allows it to hover in position without GPS. Combined with infrared sensors on its left and right sides, the Phantom 4 Pro can avoid obstacles in a total of four directions. Forward and rearward obstacle sensing range has been increased, allowing the Phantom 4 Pro to fly at 31mph (50kph) with full protection of its stereo vision obstacle sensing system. It makes fast, dramatic video easier and ultimately safer to capture.
Six-camera navigation system
Three sets of dual vision sensors form a six-camera navigation system that works constantly to calculate the relative speed and distance between the aircraft and an object. Using this network of forward, rearward and downward vison sensors, the Phantom 4 Pro is able to hover precisely in places without GPS when taking off indoors, or on balconies, or even when flying through windows with minimal pilot control. In the unlikely event that front and downward sensors are unable to operate, the aircraft can still hover in place using the rear stereo vision system. The Phantom 4 Pro also is able to fly in complex environments at a flight speed of up to 31mph (50kph) while avoiding obstacles in its path. It will automatically adjust its obstacle detection method in line with its flight speed, allowing it to avoid obstacles at high and low speed.
What is FlightAutonomy?
FlightAutonomy is an advanced aerial intelligence and flight automation platform. It is made up of a complex network of ten component groups including seven cameras — forward, rearward and downward dual vision sensors and the primary camera — an infrared sensing system, dual-band satellite positioning (GPS and GLONASS), two downward facing ultrasonic rangefinders, redundant IMUs and compasses, and a group of powerful, specialized computing cores. The Phantom 4 Pro acquires a real-time view of its environment and information about the height and position of nearby obstacles to create a 3D map it can locate itself within. The IMU and compasses collect crucial flight status, speed and direction data, while redundant IMUs and compasses monitor critical data and rule out possible errors, dramatically enhancing the reliability of flight.
Infrared sensing system
The Phantom 4 Pro is the first DJI aircraft to use an infrared sensing system. Placed on the left, and right sides of the aircraft, these measure the distance between the aircraft and any obstacles using infrared 3D scanning. When in Beginner Mode and Tripod Mode, these sensors have a horizontal field of view of 70° and a vertical field of view of 20°, providing a wide view of the scene to the sides of the Phantom, and a maximum range of 23ft (7m). Traditional ultrasonic sensors only have a detection range of 3-5m and may be confused when affected by propeller vibration or when  sensing uneven surfaces. The infrared sensing system is able to sense larger areas and measure the distance between the aircraft, identifying the closest objects accurately while avoiding interference, providing more reliable sensing and protection.
Remote controller with built in screen
The Phantom 4 Pro controller integrates an upgraded Lightbridge HD video transmission system that adds 5.8 GHz transmission support. The ability to choose between 2.4Ghz and 5.8Ghz allows pilots to cut through interference and eliminates image lag caused when flying in an area with extensive 2.4Ghz frequency use. Normally, Wi-Fi video transmission systems use a 2.4GHz frequency to work with a controller using a 5.8GHz frequency as this prevents interference that can occur when both use the same frequency. To perform normally, the video transmission system and the controller will interfere with each other causing image lag, especially if both use the same frequency. The use of two different frequencies has drawbacks in terms of flight performance. For example, flight performance will be affected when either of the two frequencies suffer interference.
The Lightbridge HD video transmission system used in the Phantom 4 Pro uses TDM (Time Division Multiplexing) to transmit signals, allowing it to send controller signals and receive video transmission signals at the same frequency. As the 2.4GHz frequency band is often affected by Wi-Fi, 4G cell towers, and other types of interference in urban areas, a 5.8Ghz band will increase transmission reliability. When switched on, the Phantom 4 Pro evaluates local signal levels, automatically choosing the transmission frequency with the lowest level of interference. This ensures the optimum range of a maximum video transmission of 4.3mi (7km)*.
A 5.5in 1080p screen integrated with the Phantom 4 Pro+ offers 1000 cd/m2 of brightness, more than twice as bright as conventional smart devices. It makes bright, vivid colors easily visible in direct sunlight. With this screen, a mobile device is not required, simplifying pre-flight preparations. As the DJI GO app is built into the screen, hardware and software can be fully optimized, further reducing video lag. Integration of an HDMI port, Micro-SD card slot, microphone, embedded loudspeaker, and Wi-Fi connection allow images to be edited inside DJI GO to be shared almost instantly. Lastly, a five-hour battery life makes the Phantom 4 Pro + a complete aerial imaging solution.
Intelligent Flight
Drones are becoming easier and easier to control, but the piloting experience remains essential for quality aerial imaging. Using DJI’s machine vision and depth learning technologies, the Phantom 4 Pro transforms complex aircraft movements into simple orders, significantly simplifying aerial creativity. In contrast with satellite positioning based intelligent flight functions, Intelligent Vision enhanced flight ensures precision camera view and control.
Draw
Draw is a brand new technology for waypoint control. Simply draw a route on screen and the Phantom 4 Pro will move in that direction while keeping its altitude locked. This allows the pilot to focus on camera control and enables more complex shots. There are two Draw modes that can be used in different scenarios.
Standard: The aircraft follows the route at a constant speed with the camera facing in the direction of flight.
Free: The aircraft only moves along the route when instructed. In this mode, the camera can face in any direction during a flight.
ActiveTrack
The Phantom 4 Pro automatically recognizes subjects, follows and captures them as they move, making it easier to get complex shots.
Following fast-moving objects can be very challenging, but advanced image recognition algorithms used by the Phantom 4 Pro allow it to recognize and track the object while keeping it in frame. This new algorithm also recognizes more subjects, from people to vehicles to animals, and will adjust its flight dynamics to match, ensuring smoother shots.
Pilots can now choose between:
Trace – Follow behind or in front of a subject, avoiding obstacles automatically.
Profile – Fly alongside a subject at a variety of angles to get profile shots of the subject.
Spotlight – Keep the camera trained on a subject while the aircraft flies almost anywhere.
TapFly
Fly in any direction visible on-screen with a simple tap. Tap anywhere on-screen to smoothly adjust the direction of flight while automatically avoiding obstacles * and tap the screen again or use control sticks to change direction. A new AR route function shows the aircraft’s real-time flight direction for reference as its route is adjusted. As it can be difficult to control altitude, course, speed and camera pitch simultaneously using joysticks, TapFly Free allows a pilot to set the direction of flight, allowing them to turn the Phantom 4 Pro or tilt the gimbal as required without changing the direction of flight. In total, there are now three TapFly modes:
TapFly Forward
– Tap to fly in the selected direction
TapFly Backward – Tap to fly in the opposite direction of the tap, i.e. tap in the bottom right corner of the screen to fly backward towards the top left.
TapFly Free – Lock the forward direction of the Phantom without locking the camera direction allowing it to turn as it flies.
*Obstacle Avoidance is not available with TapFly Free
Return to Home
In its upgraded Return to Home mode, the Phantom 4 Pro can automatically choose the best route to return home depending on environmental conditions. It records its route as it flies, allowing it to return along the same route avoiding obstacles if the control signal is disconnected.
Based on its altitude at the time of disconnection, the Phantom 4 Pro is also able to adjust its flight path to avoid obstacles it has seen during its flight. At takeoff, the Phantom 4 Pro will record the scene below and compare its recording with what it sees as it returns, for more precise landing. It can also detect the ground to see whether there is suitable spot for landing. If any obstacles are found, or there is water on the ground, it will alert the pilot and hover at an appropriate height, helping the aircraft to land more safely.
Gesture Mode
Using Gesture Mode, selfies can be captured easily using a few gestures without the remote controller. Advanced computer vision technology allows the Phantom 4 Pro to take instructions through gestures. The subject simply lifts their arms when facing the camera and the aircraft will recognize this movement by locking on and placing the subject in the center of the frame. When ready for a photo, the subject holds their arms out to signal the aircraft. A three second countdown will begin, making time to strike a pose, allowing moments to be captured without the remote control.
Flight modes
Different productions require different flight characteristics, and the Phantom 4 Pro offers three modes for flight: P, A and S. Switching between them allows pilots to get the control they need, whether they seek smoothness, simplicity, intelligent navigation or speed. In Position Mode, TapFly, ActiveTrack, obstacle sensing and positioning features are available. Sport Mode adds extra agility and higher speed, reaching 45mph (72kph). Atti Mode switches off satellite stabilization and holds the Phantom 4 Pro’s altitude. It is ideal for experienced pilots looking to capture smoother footage. Tripod Mode, which limits speed to 4mph (7kph) provides precision control for fine framing and indoor flying. Both the infrared sensing system and vision sensors are enabled in these modes for a safer flight experience.
4.3mi (7km) long-range control
Using brand new DJI Lightbridge HD video transmission technology, the Phantom 4 Pro has a maximum transmission range of 4.3i (7km)*. Before each flight, it scans a range of available frequencies to find and use the one with the least interference. By supporting 2.4GHz and 5.8 GHz frequency bands, it gives you more reliable control. Tightly integrated with DJI GO, Lightbridge video transmission also sends vital flight statistics in real time, and can be used to quickly download photos and videos to connected mobile devices.
The Lightbridge video transmission system uses advanced transmission technologies and can automatically adjust to environmental conditions. It ensures high quality, low latency image transmission across its range and offers pilots a better shooting experience. Traditional analog video transmission occupies a larger bandwidth and is more susceptible to interference. It also suffers from poor image quality and short range. Wi-Fi transmission also compares poorly, suffering from low latency, lengthy re-connection times, and short transmission distances due to the high cost of more powerful Wi-Fi transmission.
2016-11-15
Warnberg
Flight distance : 24764 ft
Suggested retail price is???
2016-11-15
Tahoe Ed
http://store.dji.com/product/pha ... =search#/?_k=uecp0w
2016-11-15
st pauli
I see they are high capacity batteries, but are they interchangeable with P4 standard?
2016-11-15
grangerfx
Flight distance : 817713 ft
Really great upgrade and only $100 more than the original price of the P4. Can you still use an iPad with the controller? I prefer the large screen.
2016-11-15
Tahoe Ed
st pauli Posted at 2016-11-16 03:59
Yes they are interchangeable.
2016-11-15
trance728
Flight distance : 298048 ft
I don't see any option to buy extra batteries?
2016-11-15
Jeromeo
Flight distance : 103369 ft
Server down already...
2016-11-15
Tahoe Ed
They will be available.  The website will be updated tonight.
2016-11-15
grangerfx
Does this mean a larger battery for the P4 standard as well?
2016-11-15
trance728
So will they have the bundles up tonight? And is the 1-2 weeks shipping an accurate thing as opposed to the Mavic?
2016-11-15
R&L Aerial
Flight distance : 298100 ft
Tahoe Ed Posted at 2016-11-15 15:09
I'm in on the p4 pro, just placed my order but I'm going to pass on the new inspire 2 ( for now)
2016-11-15
canadianairborn
So no mavics available but you guys roll out two new models.
Good lookin out.
2016-11-15
trance728
canadianairborn Posted at 2016-11-15 15:21
Good lookin out.
Inspire 2 is pre-order and the P4 Pro already has the assembly line from the Phantom line so it's faster to produce than the Mavic. At least that's what I think the case is.
2016-11-15
Aardvark
Flight distance : 384432 ft
1" Chip,mechanical aperture, manual focus & 100Mb/s
Some time in the future maybe
2016-11-15
fansf97dc459
Flight distance : 9498 ft
By March of 2017 P5 Pro will be out and P4 Pro is like Mavic Pro lol..
2016-11-15
trance728
On the website under the box contents there is a P4 Pro and a P4 Pro+, anyone know what the difference is?
2016-11-15
WillBapta
Wow! This is what we have been really waiting for
2016-11-15
R&L Aerial
trance728 Posted at 2016-11-15 15:32
On the website under the box contents there is a P4 Pro and a P4 Pro+, anyone know what the differen ...
I think one version comes with a built in screen the other does not
2016-11-15
DRONE-flies-YOU
Flight distance : 1450594 ft
I'll bet you stayed up ALL NIGHT typing all that, Ed.  We appreciate it!
2016-11-15
fansabec300f
Flight distance : 19734 ft
DRONE-flies-YOU Posted at 2016-11-16 04:40
Can we use the screen for the standard P4 remote? I am assuming the controller is the same and the screen will be sold separately for us standard P4 owners? Would love to not rely on my iPhone or iPad and have a dedicated screen.
2016-11-15
Mallettron
Flight distance : 82641 ft
Hd android, really, lets have 4k (ipads)
So with 2.4 & 5.8 does  this mean dji acknowledge the video problem and this is their solution to fix it
5 direction of sensors, no up?, suppose they cant say 3axis, maybe 2.5
Like the idea of sd card on the controller, is there one still on the drone, cant see?
Also hdmi option built in should solve the problems that people have when they install their own, but is it full hd, or 4k
Will the other apps still work with the new setup, i use ios for specific app, not sure about having to go back to android
Is there a chance of some of the new features being passed over to the origonal p4?
2016-11-15
trance728
R&L Aerial  Posted at 2016-11-15 15:39
Makes sense, just wasn't obvious about with the screen being +. I want to pull the trigger and get it instead of the Mavic but I gotta wait for the bundles to come out tonight. Just can't buy a drone with a single battery.
2016-11-15
DRONE-flies-YOU
Does it take the same-sized ND filters as P4/P3P?
2016-11-15
sunny051488
Flight distance : 183891 ft
100 mbps 4k recording is everything.
2016-11-15
DJI-Ken
Flight distance : 1515312 ft
trance728 Posted at 2016-11-16 04:51
Makes sense, just wasn't obvious about with the screen being +. I want to pull the trigger and get ...
Just be aware that extra accessories WILL delay shipment.
Orders will not be split, so if a bundle comes with extras that are short on hand the entire order will ship when everything is ready.
2016-11-15
trance728
DJI-Ken Posted at 2016-11-15 15:56
Orders will not be split, so if a bundle ...
Damn, I was afraid of that.
2016-11-15
DJI-Ken
trance728 Posted at 2016-11-16 05:00
I'm not saying it will happen, I just want want to put it out there in case.Maybe accessories will be available at the same time. We just don't know.
2016-11-15
BIGDZ
Flight distance : 10255860 ft
so the p4 batteries are not compatitble? canceling Mavic ordering P4P
2016-11-15
chasiu75
Flight distance : 154885 ft
DJI-Ken Posted at 2016-11-16 04:56
What if you split it yourself and place two separate orders?  Will they be automatically combined?
2016-11-15
trance728
BIGDZ Posted at 2016-11-15 16:01
They already said the P4 batteries are compatible but the Pro ones are a higher capacity.
2016-11-15
Noyag
Flight distance : 857946 ft
Can it have the HDMI-port too? Similar as the Phantom 4?
2016-11-15
mah4ever
Belgium
trance728 Posted at 2016-11-15 22:05
With a 1" sensor and F2.8 lens, I'm guessing this will no longer be 'focus free'.  How will focus work on this unit?  Will there be any auto focus modes ?
2016-11-15
DJI-Ken
chasiu75 Posted at 2016-11-16 05:04
If you order the aircraft, then place another order for the accessories then that's two totally separate orders and that's what I would do.
2016-11-15
fans502b5e9e
Flight distance : 54157 ft
Sweden
Any plans for an upgrade program which seems to have become popular in certain circles these days?
2016-11-15
Gibbo
Wow, what an announcement. Congratulations DJI.
So the new P4Pro camera now has a new 1" sensor and can record video in 4K resolution 30fps @ 100 Mbsec with H265 encoding (which has nearly double the performance of H264 encoding). In theory the video quality from this should be massively better than the previous cameras on both the P3, P4 and Inspire 1 (excluding the X5 camera)
If you don't need dual control capability (separate pilot and camera controllers) or RAW/Prores recording with interchangable lenses, why would you now buy a Inspire? Even the new Inspire 2.
I also like the manual mechanical apperture, which will avoid the need for ND filters in many situations.
This is a game changer.
Question - Does the P4 pro have a HDMI output on the controller? (or can it be added as an accessory)?
2016-11-15
Maxi3D
Flight distance : 307621 ft
Good grief! Mavic or P4P, Mavic or P4P! I can't decide.
2016-11-15
hallmark007
Flight distance : 9827923 ft
Hungary
DJI-Ken Posted at 2016-11-15 21:56
Is 1 to 2 weeks realistic.
2016-11-15
DJI-Ken
Noyag Posted at 2016-11-16 05:11
The P4 does not have an HDMI output. There's the HDMI module that you can install on a P3 or P4.
And for the new P4 Pro, only the version with the built in display will have HDMI out.
Video Output Port
GL300E: USB
GL300F: HDMI, USB
Mobile Device Holder        GL300E: Tablets and smart phones
GL300F: Built-in display device (5.5 inch screen, 1920×1080,
1000 cd/m2, Android system, 4G RAM+16G ROM)
2016-11-15
hallmark007
Hungary
DJI-Ken Posted at 2016-11-15 22:01
I'm not saying it will happen, I just want want to put it out there in case.Maybe accessories will  ...
Can monitor be used on Mavic
2016-11-15
