Gimbal Disconnected?! - SOLVED?
8193 25 2016-11-16 13:08:34
ctopysf
Hobbyist
I have had fewer than 20 flights on my Mavic and now when I connect to it with the DJI Go App, the Gimbal Status says "Gimbal Disconnected". I have a (blurry) image and the gimbal appears to be powered, but it isn't responding to any commands. I can't focus it, and i can't adjust the tilt or change the mode. I tried removing and reinstalling DJI Go, rebooting the phone, I even tried a different device..with the same results.
The last time I flew, it was completely uneventful. I flew out, flew back, landed on flat concrete,powered it off, then put the gimbal clamp and cover on it and put it away.
Anyone seen this before?
I just spoke with support in chat, and they told me to go do an IMU calibration and then a gimbal calibration. oddly, the video they pointed me to was for the Phantom 3. Im guessing its the same process. I'll report back the results.
2016-11-16 13:08:34
dotfiles
Student Pilot
Yes, report back after both calibrations, you may also want to try resetting factory settings with the Assistant 2.
2016-11-16 13:26:26
ctopysf
Hobbyist
The IMU calibration completed, but it wasn't able to start the gimbal calibration. When I click ok to start, it doesnt do anything other than dismiss the window. Did the factory reset in Assistant 2 but it didn't help.
2016-11-16 13:33:50
DJI-Ken
Flight distance : 444792
ctopysf Posted at 2016-11-17 05:33
The IMU calibration completed, but it wasn't able to start the gimbal calibration. When I click ok t ...
Can you connect it to the Assistant2 and do a factory restore and then see what happens.
I do find it strange that one day it worked and the next day it didn't.If a factory reset or reinstaling the firmware doesn't clear it up then please contact support and send the aircraft in for repair.
2016-11-16 13:50:09
ctopysf
Hobbyist
I just reset it in Assistant 2. Didn't help at all.
I am totally baffled too. I should note that at one point, maybe my 5th flight or so, the gimbal became non-responsive. I landed the Mavic, reset it and it continued to work after that. I honestly just figured it was a temporary glitch, but it makes me wonder if perhaps the gimbal cable wasn't securely attached at the factory.
2016-11-16 13:56:16
ctopysf
Hobbyist
DJI-Ken Posted at 2016-11-16 13:50
I do find  ...
Ok, so this is the strangest thing.
As I was packing up my Mavic to get ready to ship back, I replaced the 32GB microsd card that I had in there with the card that came with the Mavic and it occurred to me to just double check it, you never know. It started working again.
I checked the 32gb card in my pc using a flash memory toolkit to scan for errors, and it seemed to be fine. To see if that was really the cause, I put the 32gb card back in the Mavic, and the gimbal became non-responsive again.
I put the 16gb card back in, it started working again.
Should I still send it back? Should I just not use that card? I'm not sure what to do at this point.
Edit: I just popped the suspect card into my P3 Pro and it works just fine in there. Something unique to the Mavic, or perhaps just to my Mavic.
2016-11-17 13:37:09
Petroboy
Intern Pilot
Flight distance : 1122
ctopysf Posted at 2016-11-17 14:37
As I was packing up my Mavic to get ready to ship back, I repl ...
Maybe try formatting the 32 GB card while it's in the Mavic and see if that makes the gimbal responsive again?
2016-11-17 13:53:18
ctopysf
Hobbyist
Petroboy Posted at 2016-11-17 13:53
Maybe try formatting the 32 GB card while it's in the Mavic and see if that makes the gimbal respo ...
When I do that, it gives a "Format timed out" error message.
2016-11-17 13:55:10
DJI-Ken
ctopysf Posted at 2016-11-18 05:37
What exactly SD card is that. It has to be a Class 10 or UHS-1 ratiing.
Try some other cards that meet the specs and if they don't work then send it in.
2016-11-17 13:55:17
Petroboy
Intern Pilot
ctopysf Posted at 2016-11-17 14:55
I would say the card is corrupted and you should buy another one.  I had a micro SD card in a Net Camera once that got corrupted and would also not format.  Had to replace the card.  Sounds like a corrupted SD card will affect things on the Mavic.  Weird.
2016-11-17 14:01:24
ctopysf
Hobbyist
DJI-Ken Posted at 2016-11-17 13:55
Try some other cards that  ...
Just trying a bunch of different cards, and they seem to be working.
The one that doesn't work in the Mavic is a "PNY Elite-X 32GB microSDHC Card UHS-I, U3". This card works in my P3P
2016-11-17 14:01:51
DJI-Ken
ctopysf Posted at 2016-11-18 06:01
The one that doesn't work in ...
That is strange, well at least you know it's the SD card.
Maybe it's damaged somehow, does it work in your other devices?
2016-11-17 14:05:12
ctopysf
Hobbyist
DJI-Ken Posted at 2016-11-17 14:05
Maybe it's damaged somehow, does it work ...
Very strange. I am very happy that I don't have to send my mavic back though.
It works in my PC and it also works in my P3 Pro...just tested it. I'll just put a sharpie mark on it so I know not to put it in the Mavic.
2016-11-17 14:07:00
Anoniem
Intern Pilot
Flight distance : 1732
put it in your PC and do a real format, not quick format. Then try again.
2016-11-17 14:09:52
DJI-Ken
ctopysf Posted at 2016-11-18 06:07
It works in ...
Sounds good, and yes follow the above post and format in the computer and see what happens.
2016-11-17 14:20:28
ctopysf
Hobbyist
Anoniem Posted at 2016-11-17 14:09
Did a full format in my PC. No luck. Tried 5 other cards that all seem to work fine though.
2016-11-17 14:28:32
StianGel
Student Pilot
Flight distance : 73205
I had a card that worked fine in my previous phone a while back. One day id stopped working in the phone, but worked fine in a camera and my pc.
Another thing to add for a troubleshooting guide.
2016-11-17 14:39:18
aesculus
Hobbyist
Man am I glad I found this thread!  I had the same thing happen to me today.  At first I thought it was caused by the ND filter I had just installed.  I was trying new filters out and assumed they were causing a gimbal error.  So when I took it off and restarted the Mavic I was dismayed to see the error was still there.  After swapping out the SD card for the one that came with the Mavic, all was well again.  The card is a SanDisk Extreme 64GB microSDXC UHS-I.  It is new but I had used it all weekend with no issues.
So then I remembered that I had copied a bunch of files to the card the night before using a Mac, and then deleted all of them on a Linux machine before I re-installed the card in the Mavic.  So apparently I did something to corrupt the card?  I went ahead and reformatted it to exFAT (not quick format) and now the Mavic likes the card again.
Who would have ever thought an SD card would cause the gimbal to malfunction?
2017-3-6 12:36:44
gjanumavic
Beginner
Flight distance : 10121
Scary experience: I finished flying my MAVIC Pro last night, everything was fine. Took out my SANDISK Extreme PRO 64Gb micro-SD card to view the film clips on my PC. Without much thinking about it, I changed, on the PC, the name of one of the files on the SD card to something more descriptive (normal MAVIC-generated file names are like DJI_####.MP4). This morning I put the SD card back in the MAVIC and I go to fly the MAVIC and in my DJI GO 4 app running on my iPad 2 mini, the "Aircraft Status" shows "Gimbal disconnected", the picture from the MAVIC is out of focus and blinking and all camera settings show N/A. It made me think that there is a hardware error, gimbal has a bad wire connection. I tried restarting the MAVIC, the RC, the app multiple times, but the problem would not go away. Fortunately I thought of asking Google and found this discussion thread! I put a different SD card in the MAVIC and everything is fine. I put back in the card with the changed file name and the problem was back. So a wrongly formatted SD card can generate an error message "Gimbal disconnected" and disable the MAVIC camera. Talk about misleading error messages.....
2017-4-1 10:30:49
Cgibsonmm
Beginner
Try a new cord, I had the same issue.. looks like an error with the cable that connects the phone to the controller.
2017-4-2 17:37:04
Cgibsonmm
Beginner
ctopysf Posted at 2016-11-16 13:33
Change the cable that connects the phone to the controller
2017-4-2 17:37:32
fans78acada1
Beginner
Hi, I had the same problem of a gimbal that was disconnected. The solution was: when pulling out the SD card from the slot I unintentionally changed the tiny switch (Remote control setting) besides the slot from RC to Wifi. Putting it back to RC solved the gimbal disconnection problem. Hope this helps others. Best regards
2017-5-6 00:26:48
fans47c0bb7e
Beginner
Brazil
I changed the SD Card and problem continues. Gimbal disconnects randomly. I tried without any SD card and having the same problem.
2017-6-25 16:46:47
Pa1nter
Beginner
Flight distance : 127288
I just had the same problem,it flew perfect, landed,took memory card out and empty files in computer,put card back in,restart and no gimbal connection??
I did have a blurry vision on tablet but had no control over gimbal.
A couple of tell tale signs were, I couldn't reset camera settings? I couldn't find video record button and it said I didn't have a memory card in?
Consulted doctor google AKA dji forum and found memory card issue, found another card and now, Life is good again.The card was a 32gb Sandisk Extreme U3 and another thing is when I went to format properly in computer,it would freeze my computer when I went to right click to format.
I put the same type of card back in
2017-6-30 19:13:15
Backpacker
Beginner
Ukraine
Gimbal disconnected error. I did everything, but did get success. Very strange it was not any crashes. Suddenly I'v got this error and I don't know what to do. Any suggestion ?
2017-7-16 13:54:22
fans0837537b
Beginner
Flight distance : 10001
ctopysf Posted at 2016-11-17 13:37
Hi
Format your card in your computer with exFat format. I did this on my MAC with the diskutility
Then put it in your MP again and format it within your MP in the DJO GO App
The all works fine again.
WARNING TO DJI
It is absurd that the card status influences the operating system on the Mavic Pro in such a manner that this can happen.
DJI solve this!
3 days ago
Close
DJI RecommendsPrevious /1 Next
