AusAir
Flight distance : 425049 ft
This is the only thing with the Mavic that lets it down. Anything high speed.
I was driving along a dirt road through rather open paddocks with tall dry grass and a few trees here and there. The car looks great in the video. Sharp, clean, clear. The background on the other hand is lacking as a result of the low frame rate. It's acceptable but only just.
I've played around with the various resolutions, frame rates and formats and found the best compromise (because that's really what it is) to be 1080/30 NTSC (forget anything above this as the binning method employed leads to serious aliasing). 4K/30 NTSC works well in some cases and produces excellent results when it works but can falter a little in complex scenes. From a career dealing with video, PAL typically produces a far better result however the Mavic either doesn't have the processing grunt to deal with it effectively or has very inefficient codecs.
Frame rate unfortunately is the Mavic's only real downfall. |
