Zenmuse GH4 gimbal not working
875 4 2016-11-19
AWDS
Hello,
   My Zenmuse GH4 gibmal is not working, at all. It isnt initializing, calibrating, transmitting video feed... nothing. I have just installed it on my S1000+ and am running it witht the LB2 and A3 system. All other system components work and the S1000+ is flyable.
   I am thinking that the reason the gimbal isnt working is because of a firmware issue. On the GB assistant it says that the GCU and IMU needs to be updated, but it wont update. Could this be because I apparently do not have a S/N number? I should have an S/N but it shows N/A in the GB assistant. DJI is supposed to do this during manufacturing. Where do I get my S/N? I looked on the packaging and found nothing, looked it up in the manual and found nothing.
   Any help or suggestions would be much appreciated as DJI isnt open until Monday.
Thanks.
2016-11-19
DJI-Jamie
Flight distance : 112405 ft
Just to clarify, do you see a green/blue LED in the corner of the Gimbal Assistant? What LEDs are you getting from the gimbal itself? Is this a new build, or have you had this set up for a while?
2016-11-19
AWDS
I am getting all the correct LEDs. I have a green LED and a blinking blue LED in the assistant and a green LED on the gimbal. I have video feed but the gimbal will not upgrade or initialize. Also, S/N shows up as N/A and according the manual this could be an issue. The rest of the S1000+ works all except the gimbal.
2016-12-28
DJI-Jamie
AWDS Posted at 2016-12-28 19:47
Could you happen to provide a picture or a small video of how the gimbal is behaving?
2016-12-29
AWDS
It's completly limp. It wont move at all.
2016-12-29
