noob
Singapore
Misanthrope47 Posted at 2017-6-20 18:30
If you allow the DJI Go app to format the card, it will format it as proper type based on the size. If it's 32GB or less, it will be FAT32 (32kb allocation size). If it's a 64GB or greater, it will format it as exFAT (128kb allocation size). Those are based on FAT rules, and nothing to do with which is better. You can't micromanage the format to give you increased performance.
Does that mean that 128GB cards will allow me to record video files larger than 4GB since they are in exFAT format? I have only used 32GB cards so far, and since I typically record the entire flight, the 4GB limit has caused occasional frustrations where the file got split in the middle of a cool shot. And if you are wondering if I have missed the obvious solution of simply joining the videos back in editing, I have found that there were always missing frames between the split. If 128GB cards will solve this, I will be happy to replace my cards! |
