Phantom 4 pro Sd card
14227 20 2016-11-24
glowingsplint
Flight distance : 832641 ft
Recomendations below cheers, Stuart
2016-11-24
BeefyJ
A big fast one!
I've been using Sandisk Extreme like this https://www.amazon.co.uk/SanDisk ... extreme+memory+card , seem robust with my TomTom bandit. 90/80mb/s.
2016-11-24
glowingsplint
BeefyJ Posted at 2016-11-24 11:57
A big fast one!
I've been using Sandisk Extreme like this https://www.amazon.co.uk/SanDisk-Extreme ...
Cheers, the one a have been using seems to have a problem with 4K with the gopro for some reason.
2016-11-24
SERq1QaKiUck
make sure to get 95read/90write u3 like this one - http://www.bestbuy.com/site/sand ... T&skuId=9387093
2016-11-24
DRONE-flies-YOU
Flight distance : 1450594 ft
Those recommendations are spot-on!
HERE is the newer V30 version of that card for a similar price.  It's a GUARANTEED minimum write of 30MB (megaBYTES) per second; making it excellent for this higher bitrate 4k.
I will be using the included 16GB card in the P4P+ R/C.
2016-11-24
MNL5099
Flight distance : 820174 ft
FYI, if you plan to record 4K at 100Mb/s on the P4P, you will need a U3 rated micro SD card, otherwise you won't be recording at 100Mb/s. When it comes to video recording, it's all about the minimum sustained write speed, which is defined by which class the SD card falls under.
To clarify, Class 10 and U1 SD cards are not fast enough for the P4P when recording Cinema4K at 100Mb/s.
I put a little guide together for myself. All the information you need to know about SD cards and data rates with the phantom series aircraft can be found below.
____________________________________________________________________________
                                  Transfer Speed Information
1. P3P Max write speed is 60 Mbps (7.5 MBps) at Cinema4K (.45 GB per minute, or 27 GB per hour)
2. P4P Max write speed is 100 Mbps (12.5 MBps) at Cinema4K (.75 GB per minute or 45GB per hour)
3. Lexar U1 64GB Micro SD max write speed is 160 Mbps (20 MBps) & 95MBps Read
4. Mbps (Mega Bits per second transfer speed)
5. MBps (Mega Bytes per second transfer speed)
6. Conversion 8 bits = 1 byte ———So, 8 Mbps = 1 MBps
7. Minimum sustained write speeds. A speed class rating means that the card has been verified to never write slower than the speed of that class.
    1. U3: Minimum 30 MB/s Write
    2. U1: Minimum 10 MB/s Write
    3. Class 10: Minimum 10 MB/s Write
    4. Class 6: Minimum 6 MB/s Write
    5. Class 4: Minimum 4 MB/s Write
    6. V6: Minimum 6 MB/s Write
    7. V10: Minimum 10 MB/s Write
    8. V30: Minimum 30 MB/s Write
    9. V90: Minimum 90 MB/s Write
8. Online Guide https://www.bhphotovideo.com/exp ... cards-money-can-buy
9. Note, a U3 rated SD card is needed for the P4P. https://www.amazon.com/Lexar-Pro ... ds=u3+micro+sd+card
Hope this helps,
~Mitchell
2016-12-9
lasersbee
MNL5099 Posted at 2016-12-9 16:35
Very helpful info on the P4P Sd cards.
Jerry
2016-12-17
link nugget
Thank guys,
My P4Pro says SD card too slow on the stock 16 Sd they provided and also with the Lexar 1000x 3 series 64GB. Also says video cache is full.... any pointers?
2017-2-4
stalker
Flight distance : 13632 ft
Interesting read. 16GB won't be enough when I go out to shoot but I'm doubting between Sandisk Extreme U3, 32 or 64GB. Officially recommended by DJI. And I hope it will be fast enough. The included Panasonic 16GB card seems to be too slow. Anyone has the same experiences?
2017-2-14
SeanThV
South Africa
MNL5099 Posted at 2016-12-9 13:35
Im reading up on mem cards. The phantom 4 pro records at H.265 C4K:4096×2160 24/25/30p @100Mbps not 100 megabytes per second, which is then 12.5 MB/s (100 Mbps = 12.5 MB/s) Not even USB3 comes close to 100 megabytes per second, my SSD in my PC maybe does. Why would you need a 100 megabyte per second read/transfer card? Am I missing something?
2017-2-23
MNL5099
SeanThV Posted at 2017-2-23 03:39
Sean,
Your math is correct, but I think you've gotten yourself confused.
To clarify,
MB = MegaBytes
Mb = MegaBits
You need a SD card capable of recording 12.5MB/s (which is the same as saying 100Mb/s), this means you need a U3, V30, or V90 SD card. U1 cards are rated at 10MB/s sustained write speeds which is not fast enough for the 12.5MB/s the P4P is spitting out when recording at Cinema4K.
Does that clear things up?
~Mitchell
2017-2-23
MNL5099
Sean,
To clarify,
MB = MegaBytes
Mb = MegaBits
~Mitchell
2017-2-23
Geebax
It isn't that hard, just buy a Sandisk Extreme or Extreme Pro series SD card and you will be fine. The Lexar cards are dodgy, and have been reported many times as failing to intialise.
2017-2-23
larrybull
Have now rec'd 2 Lexar micro SDXC UHS-II U3 Class 10 cards for my P4P and neither would format.
Ordering a SanDisk.
2017-3-22
armyav8r
I now see others have had the same issue, going with San disk
2017-6-11
armyav8r
I ordered this one, https://www.amazon.com/Lexar-Pro ... ds=u3+micro+sd+card , and it works fine in a computer but gets 'error' when inserted in P4P.  Anyone know what's wrong
2017-6-11
Geebax
armyav8r Posted at 2017-6-11 22:45
I ordered this one, https://www.amazon.com/Lexar-Professional-microSDXC-UHS-II-LSDMI64GCBNL1000R/dp/B00U77V5IW/ref=sr_1_6?ie=UTF8&qid=1481316334&sr=8-6&keywords=u3+micro+sd+card , and it works fine in a computer but gets 'error' when inserted in P4P.  Anyone know what's wrong
Avoid Lexar, they are very frequently reported on here as not working. Get a Sandisk Extreme series card.
2017-6-11
Helimage
Flight distance : 144140 ft
Finland
Lexar is known to be incompatible with DJI products. You can't do anything about it, except maybe pray.
2017-6-11
armyav8r
Helimage Posted at 2017-6-11 23:13
Just got the sandisk extreme pro 64gb, works great with P4P
2017-6-24
Aero Flow - Ima
Flight distance : 2728835 ft
Brazil
Do you recommend this SD? https://www.amazon.com/Sandisk-E ... 5MB%2Fs+Class+10+U3
I want to film in 4k 60fps.
Thanks very much!
2017-8-28
Genghis9
Flight distance : 961 ft
Yes, but I would not pay $114 for it
I just got one for $42.50, on Amazon, about 2 weeks ago
Also, I'd take another look at post #8 in this thread, it has a lot of useful info.  Info you can use to make your own informed decision about this issue.
2017-8-28
