Mavic Pro Cam sensor error message / NO PICTURE
9106 12 2016-11-26
OXooqWLxWQQA
Flight distance : 123369 ft
Hello,
I flew my brand new mavic today and during the flight
The dji go app told me that the camera sensor has an error.
Did someone has the same problem?
The drone and the gimbal itself works perfect.
It did not come down or was dropped.
Please help me.
Here is a picture of the error message.
It's in german.
Kind regards
Chris
2016-11-26
Anoniem
Flight distance : 70043 ft
what software ?
Did you calibrate camera and do reset of camera
2016-11-26
OXooqWLxWQQA
It has the latest software update.
As i read your post I turn on the mavic to try calibrate the cam. And befor i did it starts working. I have no idea why it is working now.
I will try it in two or three hours again and will post a comment.
2016-11-26
Nees
Flight distance : 80991 ft
Belgium
OXooqWLxWQQA Posted at 2016-11-26 14:57
As i read your post I turn on the mavic to try calibrate the cam ...
Might be sensor overheating issue. fly it long enough to see if it happens again.
2016-11-26
DJI Natalia
Flight distance : 318 ft
You can try to restart the aircraft if you get that error to see whether it will disappear, if so, please do not worry about it. And please keep an eye on the APP for the future flights.
If it appears frequently, then it needs to be sent in for evaluation by our engineers.
2016-11-27
fans6862a571
I received this error after flying for a few minutes today. The temperature was 29F. I don't know if that would cause this failure. I found the operating range for the Mavic is 32F.
2017-3-10
Asainz320
Flight distance : 1061594 ft
I've had this problem before. Restarting the craft did nothing. What fixed my issue was removing and reinserting the SD card. Give that a try.
2017-3-10
fans6862a571
Thanks for the tip. I tried removing and reinserting the SD card. I've tried recalibrating the gimbal too.
After my first flight where the camera stopped working mid flight (very scary). I then had two more successful flights that day. When I tried a third flight, the camera completely failed. I got the error below. At this time, I think the Mavic has a hardware problem. It's less than two weeks old.
2017-3-11
fans6862a571
The above link didn't work.
2017-3-11
fans8aa984bb
Indonesia
Haloo Team , I have problem camera sensor error and screen blank and cannot work for recording . Kindly need your help for this problem .. thx .
2017-5-17
djiuser_f9OcjRXbcjRV
fans8aa984bb Posted at 2017-5-17 22:31
[view_image]
2022-7-7
[view_image]
2022-7-7
[view_image]
2022-7-7
