Any planned future support for Zenmuse X5S/X4S working with A3?
3918 23 2016-11-27
Sunday Idajili
Flight distance : 6033701 ft
Nigeria
Hi DJI Support,
Any planned future support for Zenmuse X5S/X4S working with Lightbridge 2 +A3 flight controller system on S900/S1000/M600 spreading wings platforms?
2016-11-27
DJI-Jamie
Flight distance : 112405 ft
Current Spreading Wings users with the A3/LB2 have been using the M600 X Mount kit for the X3/X5 and XT, so it stands to reason that compatibility would have to coinside with a new mount for the M600 to support the X5S/X4S.
2016-11-28
Sunday Idajili
Nigeria
DJI-Jamie Posted at 2016-11-28 15:17
I see same reason with you that DJI should easily make this compatibility possible. Thanks for responding.
2017-1-7
alexrj
Flight distance : 785525 ft
Is there an anymore info on this Jamie? would be great to have the option to mount the X4S/X5S with the A3 & LB2
best
Al.
2017-1-14
UAVServices
Flight distance : 756178 ft
HI Jamie, can you please confirm this is coming? our clients wont' buy a drone using the old camera when the phantom has a better camera than the A3 N3 with LB2 does
thank you.
2017-3-6
DJI-Jamie
UAVServices Posted at 2017-3-6 14:41
thank you.
There is no information at this time. A X5 or X5R would still be a viable option for high end filming.
2017-3-6
UAVServices
DJI-Jamie Posted at 2017-3-6 14:54
Thanks but this is for mapping, and X5 is 16mp only and heavy.
Without the X4S it pretty much makes A3 / N3 / M600 paper weights.
2017-3-6
UAVServices
I am here bumping this and hopeful that one day we get support for the X4S cameras.
2017-3-15
Hazardpro1
Bump from me too! ;)
2017-3-22
AeroFotografie
Flight distance : 23786 ft
Any news on this topic? Will there be an option to use X4S with LB2?
2017-5-12
markus.e
Flight distance : 304370 ft
This is also very interesting for me
2017-5-19
filmderek
Flight distance : 2318550 ft
Yes, PLEASE add support for A3, LB2 with X4S / X5S. DJI is killing us here. Why DJI put their premiere mapping camera on their craft with the least flight time is hard to understand.
Also, DJI needs to put out stand alone FW upgrades for their gimbal systems to be compatible with A3 / N3 on custom crafts. No way to have proper FW installed on a custom craft as the only camera updates are for DJI specific craft models. Currently, I have to go find someone with an Inspire 1 just to upgrade my X3/Z3 cameras to work with my custom craft that uses A3, LB2, and X3, X3, XT PL.
2017-5-30
mattbeardsley
Flight distance : 85850 ft
I'm curious too.  I'm really getting a lot of great content from the X5s camera on the Inspire 2.  A bit off topic, but I'm also curious how it might integrate with a future version of the OSMO
2017-5-30
Stuartcol
I guess the answer is to no longer buy DJI products because they will be obsolete by design on the release of a new product.  What DJI customers are requesting is easily done. I myself have an s1000 with A2 flight controller and a S1000+ with A3 Pro flight controller.    This is a significant investment to just throw away.
DJI lack of response and support for loyal customers is a disgrace.
2017-6-23
filmderek
Stuart, What DJI is NOT telling folks is that the X5S, X4S and soon the X7 are all compatible with your M-600 if you instal the M-600 Z-30 mounting kit. The connector for the Z-30 is the same as the mentioned cameras. I just confirmed this with a colleague. However, I am still working on a capture solution for the X4S, using the Z-30 mounting kit as the X4S does not have SD card slot on board. So all that is needed to close this gap is a capture solution for the X4S when using it on a copter that is NOT an Inspire 2....
2017-10-12
filmderek
Sunday, What DJI is NOT telling folks is that the X5S, X4S and soon the X7 are all compatible with your M-600 if you instal the M-600 Z-30 mounting kit. The connector for the Z-30 is the same as the mentioned cameras. I just confirmed this with a colleague. However, I am still working on a capture solution for the X4S, using the Z-30 mounting kit as the X4S does not have SD card slot on board. So all that is needed to close this gap is a capture solution for the X4S when using it on a copter that is NOT an Inspire 2....
2017-10-12
Sunday Idajili
Nigeria
filmderek Posted at 2017-10-12 13:37
Hi FilmDerek, This is Interesting. Thanks for sharing.
Sunday
2017-10-20
Fotopiloot
Flight distance : 1032070 ft
Sunday Idajili Posted at 2017-10-20 14:21
Sunday
I would really like to fly with an X4S and/or X7 on a m600  but i afraid it will never happen. How hard would  it be to integrate the cinecore into a an universal adapterplate? We would buy the  X4S and X7 without any hesitation. Investing in a camera as the X7 would be much more interesting/profitable knowing DJI is taking compatibility serious.
2017-11-22
mikes1
Flight distance : 1740699 ft
Fotopiloot Posted at 2017-11-22 08:45
Although the Z30 mounting bracket will allow the X4S or X5S camera to be mounted on the M600 I wonder if the App/Firmware would allow you to operate those cameras. Also if the wiring would be compatible. The X4S is a nice camera but I would be more interested in the  X5S. Higher end camera with 4/3 lens. Has anyone actually tried an X5S on the M600 using this bracket?
2017-11-30
Spamby
Flight distance : 3040853 ft
mikes1 Posted at 2017-11-30 13:18
I have mounted the x5s on the s1000+ using the z30 mount made for matrice 600. It powers on and does its start up dance but in the app it says my gimbal is disconnected. I have to solder the x30 into a xt60 adapter so I could get power. Im thinking that i may have my wiring wrong. I will upload a vid and pics here in a minute.
I bought the x5s under the assumption that it would work with the s1000+ because everywhere on dji.com I read said the mounts, gimbals, etc were compatible with the x5 series, I think that is totally misleading and they should state the x5s is not compatible. ITs only when you do a deeper look that you see it says x5 and x5r. 2,000$ camera that is usless at this point
2018-2-16
Farnk666
Flight distance : 1711394 ft
For mapping purposes there is no reason you can't fly a Canon/Nikon/Panasonic or even Hassy on the M600.
Would have thought these would be preferred options over DJI's X5s..
2018-2-18
PraveenSudhakar
Flight distance : 112726 ft
India
Does X5S have an in-Gimbal SD Card slot? I'm looking to buy a Matrice 210 with Zenmuse X5S & Zenmuse XT was wondering if X5S doesn't have an SD Card Slot how can I use it to record videos or Photos? Does Matrice 210 have an SD Card Slot if not Zenmuse X5S?
I Know Zenmuse XT has an in-Gimbal SD Card Slot
Best
Praveen
2018-3-2
Spamby
PraveenSudhakar Posted at 2018-3-2 00:56
No it doesn't have one on the gimbal or camera. Im thinking the only way to use the x5s on another platform is to wait for dji to make an adapter with an on board image processing chip since the x5s doesn't have it built in but rather the inspire 2 does, which is the only drone it can be used on at this point
2018-3-10
