DJI-Jamie
Flight distance : 112405 ft
DJI has changed how they named downloads and how some components are updated over time. Please be advised that the camera's firmware package is combines with the aircraft's firmware package. Not all firmware versions have updates for the camera, the same thing can happen with the aircraft. Looking at the release notes will tell you what component that the update will effect and how the firmware versions will read in the about section of your app.
For example, the latest aircraft version is v01.09.01.30 and the camera version is v01.09.01.10. If your running older firmware on bothe components, the v01.09.01.30 firmware file will also upgrade the camera to v01.09.01.10. If your running the current aircraft firmware and the camera has older firmware than what's above, then only the camera will be updated when you run the v01.09.01.30 .BIN file on the camera. The opposite is true should the aircraft firmware have older firmware than the camera.
All the Inspire 1 models (I1 V2 with the X3, I1 Pro with the X5, and the I1 Raw with the X5R) firmware files have the exact same aircraft versions, but contain different camera firmware packages). Should you have both and X3 and an X5R, you can use either camera to update the aircraft, but will need to change cameras and firmware downloads should you need to update the other camera.
I hope this helps clarify. |
