Micro SD Card For Phantom 4 Pro
123Next >
82726 91 2016-11-29
Wollert
Flight distance : 863763 ft
Norway
Bullflyer Posted at 2017-3-22 13:14
Are you sure that The EXTREME you have is an original one ?
I had a bad experience in the past, with one SanDisk I bought from eBay, an It was a counterfeit, as Geebax said
I bought sandisk extreme 64gb of a certified shop in Norway and exchanged the card 2 times, but got the same problem.
Have I bought another brand now, Lexar 633x. This card is even worse!!!, I insert the card en instantly gets the message error. ( Have tried to format to fat32, but stil only error message. Lexar 633x
But the sony 16gb card works like a charm, maybe it truly don´t support higher storage then 16gb -32gb cards.
2017-4-5
Brian Fist
Flight distance : 19928 ft
Wollert Posted at 2017-4-5 03:33
I have two SanDisk Extreme Plus 32gb cards, a SanDisk Extreme Plus 64gb card, a Lexar 633x 32gb card, Kingston 32gb card and the supplied Sony 16gb card and they all work flawlessly.
I would have to imagine your problems are associated with counterfeit cards, or bad cards.  If the stock 16gb card supplied works, then you know the card port in the AC works.
The P4Pro *IS* picky about what cards it will use successfully, but with a number of *known good* brands and configurations out there,  I would have to imagine you can find something that works.
Is the Lexar 633x a 32gb or 64gb card?  I do know that under Lexar that different capacities are different technologies, so maybe that is where the problem is...
I have a couple of cards that I can't use in my P4Pro either, including a 128gb card that works flawlessly in PCs/Samsung smartphones/tablets and I can't get the P4Pro to utilize it no matter how I format it.
2017-4-5
Wollert
Norway
Brian Fist Posted at 2017-4-5 10:20
Thanks for replay.
I have the 128GB lexar 633x card, I returned it yesterday. Now I have tried the sandisk extreme again, but now with the 32GB version. I have tried this card for 20 minuts and had no problems with it, so if this card works I will buy more of them.
Thanks for help
2017-4-5
Makingof83
Flight distance : 51020 ft
http://it.lexar.com/products/mem ... C-UHS-II-cards.html
2017-4-6
Makingof83
Uao
2017-4-6
Bullflyer
Makingof83 Posted at 2017-4-6 11:48
http://it.lexar.com/products/memory-cards/microsd/Lexar-Professional-1800x-microSDHC-microSDXC-UHS-II-cards.html
You must look for an UHS-I  card, and at least U3 or V30, because the U1 or V10 are in the limit.
2017-4-6
fansb8a1bbee
Flight distance : 13 ft
Lithuania
What SD cards are supported by the Phantom series?
The Phantom 4 Pro records videos at 100 Mbps. If the SD card’s write speed is low, videos may fail to be recorded. Recommended SD cards for the Phantom 4 Pro are listed below:
Sandisk Extreme 32GB UHS-3 MicroSDHC
Sandisk Extreme 64GB UHS-3 MicroSDXC
Panasonic 32GB UHS-3 MicroSDHC
Panasonic 64GB UHS-3 MicroSDXC
Samsung PRO 32GB UHS-3 MicroSDHC
Samsung PRO 64GB UHS-3 MicroSDXC
Samsung PRO 128GB UHS-3 MicroSDXC
Panasonic 16GB MicroSDHC UHS-3 SD card
Sandisk Extreme 16GB MicroSDHC UHS-3 SD card
Sony 16GB MicroSDHC UHS-3 SD card
Lexar 16GB MicroSDHC UHS-3 SD card
(2) The Phantom 3 series aircraft and Phantom 4 come with a 16 GB Micro SD card. SD cards up to 64GB are compatible. It is recommended to use a UHS-1 or Class 10 Micro SD card. Recommended Micro SD cards for the Phantom 3 series aircraft and Phantom 4 are listed below:
Lexar 633X Class10 16GB Micro SDHC UHS-I SD card
Panasonic 16GB Micro SDHC UHS-3 SD card
Sandisk Extreme 16GB Micro SDHC UHS-3 SD card
2017-4-7
Bullflyer
fansb8a1bbee Posted at 2017-4-7 08:03
There is also a Transcend Ultimate UHS-I, U3 V30
2017-4-7
fansf4be8d5b
Flight distance : 553268 ft
WeAreRebellion Posted at 2016-11-29 11:59
https://www.amazon.com/SanDisk-Ultra-Memory-MicroSDXC-Adapter/dp/B018J9YEI2/ref=sr_1_1?ie=UTF8&qid=1480449542&sr=8-1&keywords=sandisk+ultra+plus+64+gb+class+10+microsdxc+with+adapter
I picked up a few of these last weekend. But they were only $10 a pop.
sandisk ultra will not do 4k 60fps   you need sandisk extreme
2017-4-8
fansf4be8d5b
sandisk extreme will never let you down!
2017-4-8
Helimage
Flight distance : 144140 ft
Finland
SanDisk Extreme works, can confirm. They have a long history with storage tech and it's officially supported.
2017-4-8
fans620de4f5
Selecting a memory card is way more confusing than it has any right to be because these cards started out as storage media for images, not video, and the different uses require much different behavior from the memory card. For images you want a fast burst speed but you don't care about the minimum sustained speed. In the worst case, it just  takes a little longer to write your image(s) to the card. On the other hand,  video requires the card to have a guaranteed minimum write speed. If the card is any slower than that, in the best case the camera will drop frames and in the worst case it will generate an error and stop recording. In the past manufacturers would specify only the maximum write speed, which is only useful when recording bursts of images.  When SDxx cards came into use for video recording the industry developed speed classes. These specify minumum (continuous) rather tham maximum (burst) write speeds. The classes relevant to HD and 4K recording are SDHC/XC Class 10, UHS-i U1, UHS-i U3, and UHS-ii. Each of these standards (SDHC, SDXC, UHS-i , UHS-ii) uses a different electrical and software interface to the card, each of which provides enhanced performance and increased capacity. In the case of UHS-ii there are six additional connector contacts on the back of the card, while the others use the original set of 9 contacts. The newer cards are backward compatible with the older interfaces, that is, you can use a UHS-ii card in a SDHC or UHS-i camera, but it will still only operate at SDHC or UHS-i speeds. The phantom 4 pro has a UHS-i interface and so it supports Class 10 or UHS-i U1 or UHS-i U3 cards. If you spend the extra money on a higher speed UHS-ii card it will work but it just falls back to UHS-i mode and speed.  So don't waste your money.  The fastest video compressor on the P4 pro runs at 100 Mb/s (12.5/MB/s). DJI  conservatively suggests a card with minimum speed rating of 15 MB/s.  That suggests that you need a UHS-i U3 card which guarantees a minimum of 30MB/s. While Class 10 and UHS-i U1 (both guarantred @ 10MB/s) will most likely work, for the few extra dollars it's worth buying the U3 card.
2017-4-8
Bullflyer
fansf4be8d5b Posted at 2017-4-8 03:19
Sandisk Extreme and Extreme Plus
2017-4-8
fans3dda6c74
Thailand
Can someone help please.
I have unboxed my new p4p and it has come with sd card installed but no sd card in the controller. My questions are-
Why do I need sd card in the drone?
Do I need sd card in the controller and why?
Many thanks Dean
2017-4-18
fans614a70b4
Flight distance : 178196 ft
scott209 Posted at 2017-3-21 18:54
I can tell you from experience that a Sandisk Ultra Plus will not work. Doesn't seem to be able to keep up. Took 2 pictures yesterday & it must have taken 8 seconds to write to the card and reset so that I could take another. The video would stay on maybe 45 seconds max before stopping. Extreme Pro on its way. I compared the memory card that came with the P4P to the one I mistakenly bought. Looks like you need U3 and 90 MB/S transfer rates from what I've been able to figure out.
Same here Ultra Plus doesn't even get recognized. But Extreme Pro works perfectly for me.
2017-4-19
WyoFlier
Flight distance : 12802 ft
fans3dda6c74 Posted at 2017-4-18 17:31
I had to send mine back because it displayed a critical error, but I noticed that the controller for the P4P did not have a slot for a SD card.
The SD card in the drone will record your videos and pictures without glitches caused by transmission back to the controller
Ed .
2017-4-21
WhosTaylor
I just got the sandisk extreme U3 xc1 v30 (64gb) for my P4P. (Purchased from amazon) My video freezes every 2-4 seconds. Has anyone else experienced this?
I should also add the Sony SD that came with works totally great.
-Taylor
2017-4-28
Bearded_Henry
South Africa
MNL5099 Posted at 2016-12-9 13:24
FYI, if you plan to record 4K at 100Mb/s on the P4P, you will need a U3 rated micro SD card, otherwise you won't be recording at 100Mb/s. U1 and Class 10 cards are not fast enough.
I put a little guide together for myself. All the information you need to know about SD cards and data rates with the phantom series aircraft can be found below. ____________________________________________________________________________
I Have just bought http://amzn.to/2q0WZUH which is not compatible
2017-5-9
Bullflyer
Bearded_Henry Posted at 2017-5-9 10:44
That is an UHS-II and you need an UHS-I  V30.  Look for Sandisk Extreme or Extreme Plus, or Transcend Ultimate
2017-5-9
Bearded_Henry
South Africa
Bullflyer Posted at 2017-5-9 10:51
found this  https://www.takealot.com/sandisk ... dapter/PLID40400517
2017-5-9
Bullflyer
The Ultra is a C10, you need a V30. Sandisk Extreme or Extreme Plus. C10 is something like V10 and these cars are in the " limit but not inside "
2017-5-9
DIott3113
Flight distance : 1797516 ft
Wondering if anyone has seen this issue. I installed a Sandisk Ultra 128G card the other day.  While shooting some video today I noticed that the capacity counter on the DJI GO app was not decrementing. It continue to display 99:59 even as I shot 20 minutes of 4K video?
2017-5-19
BigPic
Flight distance : 22700 ft
Yes this is the card you want
Amazon, 64GB or 128 GB UHS-3, Class 10 SDXC, San Disk Extreme Pro
$30 + or - on Amazon for the 64GB    -- 30 year warranty from SanDisk as if you will even have it that long
2017-5-19
BigPic
MaxP4 Posted at 2017-4-2 02:34
Toshiba Exceria MicroSDXC 64 Gb U3 is ok with P4 but it does not work with P4P.
$30 + or - on Amazon 30 year warranty from SanDisk as if you will even have it that long
2017-5-19
MediaGuyZack
Colombia
This is something I actually over looked myself and I ended up making a mistake. I picked up a Lexar High-Performance 633x microSDHC™/microSDXC™ UHS-I card thinking it would be just fine however the drone doesn't read the card, but my DSLR cameras do. I guess the legal that "WeAreRebellion" posted is better optimized for a drone?
2017-5-19
Bullflyer
You need a V30  UHS-I.  Sandisk Extreme or Extreme Plus are good cards
2017-5-20
fans066df620
Flight distance : 9610797 ft
https://www.amazon.it/SanDisk-Ex ... eywords=micro+sd+u3
So this card is ok cause write 60MB/s ... i'm i true?
2017-6-3
Bullflyer
fans066df620 Posted at 2017-6-3 08:45
https://www.amazon.it/SanDisk-Extreme-Memoria-MicroSDHC-Adattatore/dp/B01HXR51DI/ref=sr_1_4?ie=UTF8&qid=1496507796&sr=8-4&keywords=micro+sd+u3
Yes, that is a good one
2017-6-3
fans066df620
I have the phantom 4 pro and with the drone i have had a bad micro sd card ... why Dji gives a slow card with the drone^??
2017-6-4
MJLSTUDIOS
Flight distance : 1540131 ft
If you have a Best Buy close to you they have what you will need.
2017-6-4
Rodger8
Flight distance : 20145135 ft
I use the Class 10 32GB Sandisk cards and get them at B&H. Never an issue. I do mapping and need the write speed and have never had a problem.
2017-6-5
Bullflyer
Rodger8 Posted at 2017-6-5 04:17
The problem is with video
2017-6-5
Rodger8
Bullflyer Posted at 2017-6-5 13:05
You lost me. I thought you wanted a fast card. Video or Photo you want a fast write speed. I just ordered a Sansisk with a 95 Mbs write speed.
2017-6-6
Foxtrod89
Flight distance : 67513 ft
The one which comes with the package for p4p is terrible! Don't get me wrong for 12.5 MB/sec video stream it is fine but 16 gb... cmmon! It also suffers transfer rate between PC and adapter.  Wanna get some SDXC with UHS 3.
2017-6-30
Tony Dodds 1
Flight distance : 8163 ft
I use a Lexar 1800x & have no problem at all with it, used it in a GoPro & hd drift motorbike camera & it was perfect
2017-6-30
Amacron
Flight distance : 41657 ft
Tony Dodds 1 Posted at 2017-6-30 08:40
Will this card work in the PH4p?
http://www.bestbuy.com/site/sand ... 066.p?skuId=7801066
2017-6-30
djiuser_Y0mr6oI
Dominican Republic
Complex Posted at 2016-11-29 15:31
Any UHS-3 should be more than fast enough.
UHS-3 doesn't exist yet. they just release UHS-2. You maybe mean U3 that means minimum of 30mb/sec steady write speed
2017-8-17
Bradders
Flight distance : 862283 ft
I purchased a Sandisk Extreme Pro. http://amzn.to/2vOHbWe .... its an excellent card and I get no dropped frames when filming 4K as it is 4K Rated, it also has the benefit of transferring form the card to the computer externally quick. I have been using it in the Mavic for around 4month with no issues. Or a cheaper option is  the Sandisk Ultra http://amzn.to/2uVYqn1 though transfer speeds will be greatly reduced.
2017-8-17
rudyasho
Flight distance : 547320 ft
Indonesia
sandiks  extreme pro ist recomended
2017-8-18
Genghis9
Flight distance : 961 ft
Outstanding post, with great info...super job
Thanks!
2017-8-18
123Next >
