Cetacean
Flight distance : 2528264 ft
Aloha fans83,
The "Narrow Sensing" hold function is in the slider options for the C1 and C2 buttons (under the remote controller). Be sure to slide the "C" options up to find the full set of options.
If you are in Mode 2 where the left stick controls up and down, yaw right and yaw left and right stick moves the Phantom forward, backward, left and right, then it is strongly suggested that you use the "C1" key for "Narrow Sensing" Hold. C1 is under the left stick on the bottom of the remote controller. This allows you to hold the button down with your left hand while you fly the Phantom forward, backward, left and right with your right thumb. This really makes things easier!
Hope this helps!
Aloha and Drone On! |
