Cruising speed for Litchi wsypoints
6735 7 2016-12-6
Taydav
Flight distance : 115328 ft
Looking for advise on what others are using for the speed settings in Litchi waypoints to get a smooth unrushed video output?
2016-12-6
samuraiz
Flight distance : 202585 ft
A lot depends on how long and how far the mission is.   If you are going to be flying  a couple of miles you need to complete the mission before you run out of battery.  How high will the AC be flying is important.  Since 25MPH @ 250 feet seems a lot slower than 15MPH at 50 Feet.      These are the considerations that I use.   Since almost all of the flying and filming I do is relativly local.  I get to experiment with a mission, Review the footage.  Go back on Mission hub, make adjustments and re-run the mission.
2016-12-6
Kneepuck
Flight distance : 275105 ft
Really, the only way to know is to try it out.  There are so many variables involved.  On the up side, it costs nothing but time to experiment.
2016-12-6
Matt-and-Riley
Flight distance : 324442 ft
This is at 25kmh
This is at 15kmh
Both between 60-70m high
2016-12-8
Taydav
Matt-and-Riley Posted at 2016-12-8 15:39
This is at 25kmh https://www.youtube.com/watch?v=YgJfRpTcHNM
This is at 15kmh https://www.youtube.com/watch?v=Ljr5CvSVw-g
Thanks very much Matt and Riley.
This is a wonderful benchmark to use
2016-12-8
Matt-and-Riley
Taydav Posted at 2016-12-9 00:10
Glad I could help. If I get out at the weekend I'm going to try some very slow tests, 0.5 - 5kmh
2016-12-9
Craig540
Flight distance : 1292339 ft
Matt-and-Riley Posted at 2016-12-8 12:39
This is at 25kmh
This is at 15kmh
does the gimbal speed depend on the speed of the drone? Like if your panning left to right will it turn slower depending on the speed.Also what is the cruise speed for the Mavic ?
2017-4-24
Matt-and-Riley
Craig540 Posted at 2017-4-24 18:47
Shouldn't change the gimbal speed, pan / yaw is the same at any speed. Not sure about the Mavic, probably about 30kmh before the props come into shot?
2017-4-25
