rick39
Flight distance : 164354 ft
Heavysledz Posted at 2016-12-7 17:50
This is exactly what I did....I purchased a Hubson x4 107C drone on Amazon for under $50 and have been practicing with this. In just a few days, I have gotten much, much better and since this particular drone does not have the auto hovering capability, you have to really work the sticks....so if you can fly this reasonably well, you should be able to fly a Mavic with ease.......much easier and cheaper to crash a $50 drone than a $1000 drone! If you want a cheap drone that does hover you can pick up the Hubson X4 107C+ for about $10 more but I think it is better to learn how to fly without it as it may pay off in a situation where you need to react quickly to control altitude on the Mavic and the muscle memory of flying a drone without hovering capability may be the difference between a crash and saving it....
Did the same as you Heavysledz, but bought the 107D+. I should have saved $60.00 and not bothered with the camera and barometric hover, neither of which work particularly well. However, the drone is pretty much indestructible apart from the blades, it even took a swim in the dog's water bowl and survived!
Great for learning orientation and nose in flying. The Mavic is 100 times easier to fly having options to be almost totally autonomous, but that's the issue in the event of a problem. You need to learn how to fly a drone manually to experience controlled unassisted flight.
Just a tip for the OP. A free drone sim app which is probably as good if not better than the DJI one is worth downloading if you haven't got your Mavic yet. It's called Quadcopter FX Simulator and will give you some idea of how the controls react to flying a drone. The paid for app gives extra scenes and different drones which you can change the settings on, from super easy, like Tripod mode, to mad uncontrollable mayhem mode! |
