asdasdasd123522
India
Firstly, make sure that your Mavic has the latest firmware installed then try using a different image viewer, such as Ifranview. Some programs may not recognize EXIF information correctly, and Ifranview is known to display this information accurately.
Open your photos with Ifranview and press the 'e' key to view EXIF data. Alternatively, in Windows, right-click on the image file, select "Properties," and navigate to the "Details" tab. Look for Latitude and Longitude coordinates under the GPS section. This method provides another way to check for GPS information in your photos.
If the issue persists, you can use jpeg compressor to remove metadata and compress your images. This online tool allows you to optimize your JPEGs, potentially resolving any discrepancies in the EXIF data. |
