H.265 Videos in Vegas Pro 14
16289 21 2016-12-10
Cobra44Magnum
Flight distance : 935135 ft
I have taken a few videos using the H.265 option with my Phantom 4 Pro and they play flawlessly on my Windows 10 PC connected to a 43" 4K monitor. However, when I attempt to use one of those videos in a Vegas Pro 14 project, the file is not recognized as a valid multimedia file. The Vegas Pro 14 "features" list includes H.265 support. In fact, this is the main reason that I upgraded to version 14. I have tried their forums to no avail so far and just now submitted a support case to Magix (they own the Vegas Pro software now). Hopefully I'll get an answer from them soon but wanted to see if anyone else is using H.265 videos. If so, have you tried editing them in Vegas Pro 14? How about another video editor?
2016-12-10
Natemare13
let us know what they say.  I too use Vegas 14 but have not tried P4P footage in it yet.
2016-12-11
fansaf04bd9e
try to use .mov format
2016-12-11
Cobra44Magnum
I will give the MOV format a shot this evening when I get a chance to shoot some test video. Using MOV was a suggestion from the Vegas forum also. For existing videos they suggested remuxing them with ffmeg. I plan to try that also. I'll post my findings.
2016-12-13
Cobra44Magnum
Okay, shooting the video in MOV works (simply renaming the MP4 file to MOV did not). It also worked after I remuxed it using ffmpeg. However, even though all of these videos play flawlessly with the built-in Windows 10 video app, they bring my machine to its knees in Vegas Pro 14. Its worse than a slide show and all CPU cores max out at 100%. My machine has an Intel Core i7-3960X 3.30 GHz (6 cores/12 logical processors) with 64 GB of RAM and the disk subsystem is a 4-drive RAID 0 array of Samsung SSDs. For most things it rocks the house!
Bottom line is that even though I have a solution, I don't think I'll be using H.265 unless I find some way to edit them without going through too many hoops. I do very much appreciate everyone's input and suggestions. Thank you all.
2016-12-13
vidwiz
I'm a newb and I see no way to subscribe to this thread so perhaps this post will do so.
2016-12-13
Slug69
Are you using Vegas 14 build 201 or the original release? (201 came out two or three weeks ago)
2016-12-17
Cobra44Magnum
Using Vegas Pro 14 build 201.
2016-12-26
fans7c0ea622
I just filmed footage in H.265 on my Inspire 2 and ran into the same issue. I purchased Movavi converter to make the file an MOV.
2017-2-15
Cobra44Magnum
Glad to hear you got it working. What format are you converting it to?
FYI, if you shoot the video in H.265/MOV (as opposed to H.265/MP4) the file header is correct and they are recognized. You won't have to do a conversion outside Vegas Pro. I create proxy media files, inside Vegas Pro, to work with for editing. Working with the original 4K, H.265/MOV files is way too choppy. Even using the proxy files I had to turn down my preview quality to smooth out transitions and text animations.
2017-2-16
monica66
Russia
I followed this article to solve the issues. Hope it will help you out. Good luck!
2017-5-10
Geebax
Cobra44Magnum Posted at 2017-2-16 05:39
Editing with an MPEG based file is asking for trouble. It is designed for distribution, not editing. I convert all my MPEG footage to Quicktime Uncompressed YUV 422 10 bit for editing and only convert back to MPEG as the final stage.
2017-5-10
Cobra44Magnum
Geebax Posted at 2017-5-10 20:19
This thread was about Vegas Pro which is a Windows application. Your method is certainly preferred for FCP on a Mac but not sure Vegas would work with or do any better with ProRes files.
2017-5-11
Geebax
Cobra44Magnum Posted at 2017-5-11 08:37
Quicktime Uncompressed YUV 422 10 bit is not ProRes, but I can output it from Resolve after grading, and import it into Vegas for editing. Although these days I am finding myself using Vegas less and less for simple edits and just using Resolve. the only disadvantage of my approach is the fact that the file size gets huge after conversion, but you can always delete the Quicktime files after you complete the edit, I just use it as an intermediate. I am a long time user of Vegas.
2017-5-11
christing
Japan
I'm using Vegas Pro 14. For the goal of maintaining maximum image quality while providing the smoothest editing experience, what I've done is  converting Phantom 4 Pro H.265 to MPEG-2 for Sony Vegas Pro. Here is the solution to Phantom 4 Pro 4K H.265 Not Work With Sony Vegas Pro.
2017-8-11
Geebax
christing Posted at 2017-8-11 00:48
I do not agree with that approach because in converting MPEG4 to MPEG2, all you are doing is converting from one highly compressed distribution format to another. Better to convert H.265 to a high quality uncompressed intermediate before doing any edit or other processing work.
2017-8-11
Cobra44Magnum
Geebax Posted at 2017-8-11 01:21
I agree with you not agreeing. If you're going to the trouble to convert for editing, the output should be an editor-friendly format. I no longer have a Phantom drone and this isn't an issue shooting Prores on my Inspire 2 and editing in Final Cut Pro X.
However, I would like to know what editor-friendly format that Vegas Pro likes the best (i.e. which format is the smoothest for editing) and convert the H.265 files to that format. Prores is great for editing and has great quality but archiving those huge files is costly. For most of my needs I could just convert H.265 for editing then delete the converted files when done. That way I would just be archiving the original H.265 files.
2017-8-11
Aardvark
Flight distance : 384432 ft
I use Sony Movie Studio V13 (Baby brother to Vegas), and have never seen a need to convert my H265 encoded MP4 files (Phantom 4) to any other format to allow me to edit them.
Surely converting MP4 (or MOV) to any other format would incur some degree of distortion or loss of detail or colour on image ?
2017-8-11
Geebax
Cobra44Magnum Posted at 2017-8-11 04:04
As I said earlier, I use Quicktime Uncompressed YUV 422 10 bit. It converts into huge files, but as it is nothing more than an intermadiary, I erase them after I finish the project.
Conversion of anything should in theory introduce distorions, but the above format does limit the damage and it means you have a good quality base to convert to another output format.
2017-8-11
christing
Japan
So, how about H.264 MOV? Any intermediate format for Sony Vegas?
2017-8-15
Cobra44Magnum
christing Posted at 2017-8-15 00:15
I experimented with the proxy feature of Vegas Pro a while back but don't remember how much control you have. I don't use Vegas Pro as much as I used to since I am shooting ProRes and editing on my MacBook Pro with FCPX most of the time.
2017-8-15
Emily Harney
iDealshare VideoGo can convert any video files like H.265, MP4, MKV, AVCHD, MXF, MOD, TOD, MOV, Apple ProRes to Sony vegas supported video format.
Here is the easy guide https://www.idealshare.net/video-converter/sony-vegas-mp4.html
2018-3-7
