Magnetic interference from battery
12Next >
5429 40 2016-12-11
fans72488b36
i just received two new Mavic batteries.  Took a few flights to try them out.  It quickly became apparent that the batteries are causing magnetic intererence at high discharge.  When in sport mode, and flying at max speed, the DJI go app throws up a warning that there is magnetic interference, fly with 'cautious'.  As soon as I slow down, or stop, the warning disappears.  I've never seen this behaviour with my original battery.  Has anyone else encountered this?
(Edit I am seeing this with my original battery too now.
2016-12-11
Mir
Flight distance : 2718491 ft
I just had the exact same thing happen to me during my flight today. In sport mode I got multiple warnings about magnetic interference.  It was also a new battery I received last week.
ANY insight DJI?
2016-12-11
fans72488b36
Glad someone else can verify this.  Making me a bit nervous to fly with the new batteries, as I often fly fast in sport mode.Note: this is with new Firmware : v01.03.0000
2016-12-11
Free Bird
Yes, I have the same thing. I just received my Mavic Pro but it keeps telling me I have magnetic interference. It let me calibrate the compass once but not since, and it took 12 attempts to get the calibration the first time. I haven't flown my Mavic yet because I don't want to fly when it tells me I have magnetic interference.
DO you think it's because of the new batteries they are making or is it the new firmware upgrade?
DJI please respond. I really want to fly my Mavic. the whole week coming up is supposed to sunny. Rare for our wet winters.
2016-12-11
Peter Galbavy
Flight distance : 545377 ft
I got the same when flying over a shore / the sea - nothing metallic or ferrous there. After reading this I assume it was from the flight while fighting high-ish winds. Once I stopped moving and hovered the warning went away.
2016-12-11
MavicUser
Flight distance : 431417 ft
Peter Galbavy Posted at 2016-12-11 21:34
Please read the post here regarding this issue.  You're lucky to be on firmware 1.03, otherwise your Mavic could have gone into TBE... Contact DJI as this could possibly be a problem with a faulty cable placement within the Mavic and needs to be serviced.  See post #20 in the linked thread...
2016-12-12
Could you please provide some screenshots of the error message? What mobile device you are using and what's the DJI GO version?
2016-12-12
Peter Galbavy
Providing screenshots may be hard as the error (for me) stops as soon as you stop moving. Which you would have to do to press the screenshot buttons, right?
DJI-Mindy, can you please find out if there is a known issue in support with this mentioned "misrouted cable" ?
I will be raising a support case once I get back from my holiday.
2016-12-12
Peter Galbavy Posted at 2016-12-12 18:32
Maybe you could use a screen record software to record a short video, if convenient.
And I've reported this issue. If our engineers need more information, I'll let you know.
2016-12-12
Peter Galbavy
Thanks. I will try.
If it helps, I have synced my flights under this name/account and the Mavic flights from the 11th Dec (Eastern Australian time!) all exhibited this behaviour at the start while I flew from take-off to the location a few hundred meters north.
2016-12-12
Travis199
Flight distance : 144039 ft
I have the exact same issue. Sports mode at full throttle and it goes mental. Looses gps and drifts away. I only have the original battery so not that
2016-12-12
Nymble
I've posted a video of the behavior .
2016-12-12
canadianairborn
This is concerning.
2016-12-12
Mir
DJI Mindy Posted at 2016-12-12 02:43
Hi Mindy,
I was able to capture this happening. I was in Sports mode.. and right when the video starts I'm starting to push the right stick full forward. As soon as it was full speed you see the error come up. I was able to reproduce this every time.
2016-12-12
FedsRevenge
Flight distance : 2487 ft
Norway
Can't deny the fact in the video. This only happens in sport mode? How about when RTH against wind?
2016-12-12
Travis199
Bizarre that yours says magnetic interference yet mine says compass errors when doing the same thing
2016-12-12
Mir
FedsRevenge Posted at 2016-12-12 15:04
Only in sports mode this occurred. I don't know about RTH though, honestly.. I'm more of a fly-manually type of guy.
2016-12-12
FedsRevenge
Norway
Just concerned this could happen if you loose connection with the remote and it tries to return home and has to fight wind. Wouldn't that push the motors to the point this happens?
2016-12-12
IIJBII
That's very concerning. I'd fly with caution. Unfortunately, it looks like there's a fair amount of "quirks" with the Mavic pro. Some of these issues could be dangerous.
2016-12-12
Nymble Posted at 2016-12-13 06:49
I've posted a video of the behavior Here.
Could you please upload the flight data and flight records to dropbox and send me the link?
Please follow below method to find the app logs and flight data :
App logs:
Android:Link your mobile device to a computer, the follow this file path: \DJI\dji.pilot\FlightRecord\
iOS system:Connect your iPhone to iTunes then find the flight record in the DJI GO APP folder.
Flight data:
You can use the same method as for the Phantom 4.
Here is a video tutorial for reference:
2016-12-12
Mir Posted at 2016-12-13 07:01
Hi Mindy,
Thanks.
App logs:
Flight data:
2016-12-12
Nymble
Here is a link to the flight record of the video that I posted: https://www.dropbox.com/s/xodmmr ... 26-46%255d.txt?dl=0
2016-12-13
Blade Breaker 0
Nymble Posted at 2016-12-13 23:36
Here is a link to the flight record of the video that I posted: https://www.dropbox.com/s/xodmmr0knesopma/DJIFlightRecord_2016-12-12_%255b14-26-46%255d.txt?dl=0
Same exact thing happens on my AC. I have not seen anything bad happen as soon as you slow down a bit from full throttle all is happy.
RTH in S mode if the AC goes full throttle may be an issue?
2016-12-13
DJI-Ken
Flight distance : 1515312 ft
Mir Posted at 2016-12-12 17:01
Hi Mindy,
I had the magnetic interference as well,  I calibrated the compass and it no longer appeared.
Make sure when you calibrate the compass thee is no metal around and no metal in your pockets (phone, keys, jewelry) and set the RC/phone on the ground several feet away from you when you start the calibration.
2016-12-13
Could you please upload the flight data as well? And please click the "Reply" button, so I can see you're responding to me.
2016-12-15
R&L Aerial
Flight distance : 298100 ft
DJI-Ken Posted at 2016-12-13 11:41
No gold or silver rings on your hands either.
2016-12-15
Nymble
DJI Mindy Posted at 2016-12-15 03:14
I'm not sure what you are referring to as flight "data".  I followed the info you posted about the flight "record".  Nvm, I'll have it in a minute.
2016-12-15
DJI-Ken
R&L Aerial  Posted at 2016-12-15 04:40
Yes, to be safe take ANYTHING with metal in it, remove it before a compass calibration.
I've been doing that for years and have never once had an issue.
When I got the Mavic my first flight I got a Magnetic Interference warning and after calibration, it's been 100% flying 100% perfectly.
2016-12-15
Nymble Posted at 2016-12-15 22:58
Please connect your aircraft to DJI Assistant. You could refer to the video to export the flight data.
Thank you for your cooperation.
2016-12-16
Stu-pak
Flight distance : 144570 ft
South Africa
Nymble Posted at 2016-12-12 14:49
Hi Nymble,
Did you ever manage to figure out what caused it? or be able to stop it from happening?
Im having the same issue even when I'm in normal mode and using full stick.
Just trying to search the forum to see if there is a solution as it sucks not being able to use full stick without errors.
Thanks
2017-1-4
mavicme
Flight distance : 35738 ft
Glad I saw this thread.. I got the same magnetic interference warning flying sports mode. I got worried flew it back and landed
2017-1-5
Andrejs
Flight distance : 1730177 ft
Latvia
I had the same problem, but also GPS turn off and coming to ATTI mode
I think it was because I was flying in new spot without compass calibration.
Now I try to make compass calibration each time when I am in new spot and so far this helps. Compass calibration not taking a lot of time so it is better to make I think.
2017-1-5
Stu-pak
South Africa
Hi Mindy,
Has anything come back after you reported it to the engineers last month or any suggestion what we should be doing to resolve this issue. As the others have stated and shown above in their videos, it happens every time i push the sticks close to full in either normal and sport mode.
(I've done every calibration possible).
I.e. have people been resolving it themselves, or is this an issue where our mavics may need to be sent back?
Thanks.
2017-1-5
Andrejs
Latvia
Stu-pak Posted at 2017-1-5 01:16
Hi Mindy,
In my opinion if calibrations not help you should contact DJI and send it back for repair.
2017-1-5
Hi Mindy,
Sorry for the late reply.
This issue should be fixed in the latest firmware version. Did you update the firmware?
2017-1-7
fans2783c9e0
Flight distance : 12405 ft
Malta
I had the same proplem with mine today and red alerts kept coming up on the screen. A few minutes later, my drone started drifting away and the stick controlers would not allow me to take control of my drone. The final result, my drone got lost at sea. :-(
2017-4-15
Delta 1
Malta
Where ever I go with the Mavic Pro, it states the same. And I blammed it on the latest firmware 600. Ever since I did the update everything started going nuts.
2017-5-5
Delta 1
Malta
fans2783c9e0 Posted at 2017-4-15 15:12
OMG Fan2783c9e0... Mine did the very same thing. But thanks to DJI,  I got a new one.
2017-5-5
Griffith
Flight distance : 98537 ft
There is another post out there somewhere - maybe another forum,  that documents electronic noise from unshielded motor wiring interfering with compass readings. Seems to be major problem in sport mode. Several DIY fixes proposed http://forum.dji.com/thread-94664-1-1.html
2017-5-5
Griffith
Here it is. http://mavicpilots.com/threads/diy-rear-compass-cabling-fix.8349/
2017-5-5
12Next >
