Lightbridge 2 + A3 Connection
13849 16 2016-12-12
JohnGrand
How is the A3 connected to the Lightbridge 2?
Particularely:
1 - How does the Lightbridge 2 receive it's input voltage, when there is no gimbal connected (just the A3)
2 - After that: What is the input voltage range for the Lightbridge 2
3 - What does the wiring look like for a A3-Lightbridge2-RoninMX setup
The DJI Manuals for these parts unfortunately are not specific on those questions.
Thank you for your time and help!
2016-12-12
DJI-Jamie
Flight distance : 112405 ft
The LB2 would get its power via the DBus II cable when connected to the A3. The Appendix section of the LB2 manual does provide some information on voltage:
http://dl.djicdn.com/downloads/l ... ser+Manual+V1.4.pdf
If you're using the Ronin MX with the stand alone A3 with LB2, then you would follow the instructions for connecting it to the M600:
If you do not use the SRW-60, then you would connect to the camera you're using directly to the LB2 air end via HDMI.
2016-12-12
alikc218
Russia
DJI-Jamie Posted at 2016-12-12 12:32
dbus II cable have only 3 wires (left emty) and no powered from A3? in which left and second = 9V
2017-1-17
alikc218
Russia
In A3 RF port I check by tester:  left and second pin = 9v
In my cable DBUS II from box only 3 wires and left empty and no powered TX LB2
Do you have another DBUS II cable?
Where I can powered from A3 another place without gimbal?
Thanks
2017-1-18
DJI-Jamie
alikc218 Posted at 2017-1-18 00:49
Have you ensured that you connected the DBus II in the proper position? Could you happen to provide a picture? Other than the RF Port with the DBus II cable, the only other way is via the EXT port, which does require a DJI HD gimbal.
2017-1-18
alikc218
Russia
DBus cable II from A3 box include 4 wires and powered LB2 !!!
Thanks
2017-1-21
alikc218
Moldova
Hi James
Where I can find protocol data transmit from DBus port of LB2 to RF port A3?
I very need this
Thank You
2017-2-1
Nanox
Flight distance : 1941217 ft
Chile
alikc218 Posted at 2017-2-1 07:37
Hi James
I very need this
Hi!
Did you get any response to your question?
I'm also trying to connect a LB2 to A3 but my DBUS cable has 3 wires instead of 4... . I'm not using a gimbal.
Please let me know if you got any answer!.
Thanks a lot!
2017-10-9
DJI-Mark
Nanox Posted at 2017-10-9 07:49
Hi!
Which aircraft are you trying to set this up on? Can you send me a personal message and provide a list of what your set up is?
2017-10-9
fans217b3666
Ok, guys I thought
I was the only one having problem with the connections.  The instruction that the A3 comes with are not very clear.  I have the A3 and having problems with the basic set up. Where do all the cables connect to.  At the moment I am only using the single satellite and installing it to my S-900.  But the controller LED indicator keeps flashing steady red, indicating an improper connection...
2017-10-10
WiSi-Testpilot
The Lightbridge gets power through the S-bus cable, which is in the A3/N3 box, see above.
Connect the parts according to the manual.
Important: use assistant2 v1.1.2.
Factory reset (dashboard restore)
Make all settings from scratch.
I always make a test setup, see my N3 picture. Then you can go in the garden and calibrate the compass. Then the red flashing will stop.
Best regards,
Wilhelm
2017-10-10
fans217b3666
Is the setup for the A3, same as the picture above?  I am having similar problems.  I cant get the A3 working properly and cant get power to the LB2.  Can some one please post a diagram of all the connection with the A3 and LB2.
Thanks,
2017-10-27
WiSi-Testpilot
Take the RF cable from the A3 box. It has 4 wires. The same cable in the LB2 box has only 3 wires.
Best regards,
Wilhelm
2017-10-27
airtakes
Flight distance : 623045 ft
Hi to all I know this is an old ttread but I just got in to this Lightbridge 2 instillation I am installing a LB2 to a A3 no gimbal and I also only have the 3 cable Dbus to RF cable that does not power the LB2 si base on the previous posts should there had been another  Dbus to LB2 cable in my kit  that has the 4th cable installed?  or how do yo get the correct cable?
help appreciated
2019-8-9
airtakes
airtakes Posted at 8-9 00:13
help appreciated
Any one please need help help
2019-8-18
djiuser_0uq3SIfIR2SV
Flight distance : 125 ft
airtakes Posted at 2019-8-18 08:14
If you read some of the answers youll find people have already answered...the 4 wire cable should be in a3 box connect rf port to dbus
2021-12-16
Juan carlos3
Flight distance : 31768 ft
I don't have that cable,
does anyone have the position of the pins?
2022-7-9
