Donnie Stugots
Flight distance : 3636782 ft
Hello Walter ,
If you are having trouble with the go app , sync your flight records and then delete and re install the Go app. Also for a complete version of Firmware on the 'About " page of the go app , make sure all systems are ON and flight ready . ( aircraft on , RC on, go app connected to rc and on etc. )
What device are you using for the Go app ? Is it on the approved list ? also you mentioned you have the system updated, does this include the aircraft, RC transmitter and camera ?
the satellite map will only workj if you have a wi- fi connection for the Go app device OR you have the Map "cached " into the go app . This can be accomplished on the go app settings, make sure you have it enabled and then Make sure the site you are going to be using has been memorized ( In the go app device cache ) so that you can pull it up while flying . I have my go app wi- fi enabled so it auto updates for me .
***Cache Map in backround functiion is available on the go app under General Settings , be sure to enable it .
*****You really may have no problem with the go app and no reason to delete and re install. Just make sure all systems are on and check the "about page " again , if all versions come up , you are fine . Then for the Map, jsut make sure you enable the "cache Map in backround " on the go app and then when you do have wi fi be sure to zoom in and out of the area you want the go app to remeber, this should make it available next time you fly without the wi- fi connection to go app device . Or just provide wi -fi to the go app while flying and the map function will work.
Hope this makes sense, I rambles a bit....
donnie
