thehippoz
jdmagoo Posted at 2016-12-21 15:12
So this is what I have found, when observing the compass data within the go app the value climbs pass 400 when I travel max speed in sports mode, when it passes 400 the compass redundancy error appears and switches to compass 2.
The following is what I have observed with the current firmware:
I'm not sold on the new firmware switch. I had problems indoors with the new firmware as well. I'm not able to even use modes indoors with the new firmware and go 4. It just won't let you where as with old firmware and go 3, you can switch with 8 sats and it stays there (while switching in and out of opti mode in flight).
Outdoors, the compass does get high in sport but no fly away yet (cross fingers). I may have a good one. I reading in another place that people are sending units back to dji to reroute the motor wiring to the rear props, as it runs too close to the compass causing it to fail under high load. It's probably limited to early models but they are still testing.
They probably have the wire twisted causing the wire to act like an inductor under load. Haven't opened mine up yet, but that's what the problem sounds like to me if it's causing the compass to fail. |
