Mavic Pro Irregular Charging Flashes
6106 9 2016-12-15
gaber77
Hi there,
So I just recieved my Mavic pro along with an extra battery, and of course proceeded to charge the first battery, start up the quad and update firmware etc. No issues.
But, while doing the updating and setting up process, I decided to charge my second battery, which is where the issue arose. When I try and charge it (using official, regular DJI charger, not even the hub), the 1st battery light blinks 16 times, then a 17th time very quickly, and then nothing for around 8 seconds, and then repeats the whole sequence. I have tried almost every outlet in my house, to no avail. This sequence of blinks isn't in the manuals anywhere as far as I can tell, so I'm wondering if I got a faulty battery or if it's a problem on my end, with voltage from the wall or something. I left it charging in this state for almost 45 minutes with no change, so I'm certain this isn't part of a normal charge routine. I've attached a video below of the blinking. Any help is welcome.
Thanks,
Gabe
https://www.youtube.com/watch?v=wTzORR0oHXc
2016-12-15
gaber77
Update: Talked to DJI, and the battery seems to be defective. Gotta send it in for repair.
2016-12-15
Heavysledz
Flight distance : 819491 ft
that sucks...hopefully they will get it turned around for you quickly.
2016-12-15
gaber77
Yeah bit of a bummer. I have an extra battery so I'm not entirely grounded, but still a hassle.
2016-12-15
DJI-Ken
Flight distance : 1515312 ft
gaber77 Posted at 2016-12-15 16:53
Glad you got it sorted out and it's going back, I've never seen a battery do exactly that before.
2016-12-15
gaber77
DJI-Ken Posted at 2016-12-15 19:01
Right? I couldn't find anyone with the same problem anywhere. Some weird fluke. Oh well, it happens!
2016-12-15
DJI-Ken
gaber77 Posted at 2016-12-16 09:00
ya, I guess so.
At least you have another one to use until you get it replaced.
2016-12-15
fanse1dd4cd2
Flight distance : 270646 ft
Brazil
I get the same thing with one of my batteries.
I plug the other one and then this one back and it works.
I guess I will have to contact DJI when I get back from vacation.
2017-1-7
djiuser_N5UN6eA
Flight distance : 167867 ft
I have the same issue.... what is the conclusion of your call with dji. ?
2017-8-13
dorius_23
Flight distance : 118766 ft
Switzerland
Same problem here with a brand new battery.. so the only way is getting a replacement from DJI?
2017-8-13
