USB to HDMI video output for Mavic controller?
26020 17 2016-12-15
brandonb
Flight distance : 19029 ft
Hello all,
Does anyone know if you can attach a USB to HDMI converter to the Mavic controller to display live video on a TV vs. a Phone/Tablet?
Link: As seen here
Thanks,
-Brandon
USB to HDMI
USB to HDMI
2016-12-15
QuanthonyTrang
Flight distance : 419980 ft
I don't think that would work. The USB is outputting proprietary GO app data from the controller to the phone and the phone then reprocesses all that data into video via DJI GO app or Litchi.
2016-12-15
Heavysledz
Flight distance : 819491 ft
QuanthonyTrang Posted at 2016-12-15 19:51
I think your right...but there are ways around it. One fella posted a video where he was using an Nvidea tablet that had an HDMI output and he plugged in a set of FPV goggles to it anti worked flawlessly.
2016-12-15
QuanthonyTrang
Heavysledz Posted at 2016-12-16 12:56
That's a totally different ball game. He has connected the Nvidia as per normal and used the dedicated HDMI out to screen/mirror cast to any other device (in this case, a HMD FPV goggles).
2016-12-15
GrizzlyAdams
Heavysledz Posted at 2016-12-15 19:56
Please post that video. Please?
2016-12-15
thehippoz
Flight distance : 23 ft
Screencast to roku works
2016-12-15
brandonb
I have a HDMI out cable for my phone that I can hook up to the TV, maybe I'll try that first with the DJI app and see what happens.
2016-12-15
Heavysledz
GrizzlyAdams Posted at 2016-12-16 10:06
Took me a bit to find it but here it is....
2016-12-16
Heavysledz
QuanthonyTrang Posted at 2016-12-16 10:05
I agree....not too many devices with a dedicated video output.
2016-12-16
Chazzm
Heavysledz Posted at 2016-12-15 17:56
Works perfectly fine!
2016-12-29
Chazzm
Works perfectly fine! Mine does!
2016-12-29
fansdf15c545
I bought the USB to HDMI but I'm not getting signal out, was there a setting within the remote?
I bought this one, it might be slightly differenty. Trying to film an event at the end of the week, need to get a signal out or purchase a new drone that has the HDMI out of the remote otherwise. Any help is very appriciated.
Cable Matters SuperSpeed USB 3.0/2.0 to HDMI/DVI Adapter for Windows and Mac up to 2560x1440 in White
https://www.amazon.com/gp/produc ... 0?ie=UTF8&psc=1
2017-4-23
james007
fansdf15c545 Posted at 2017-4-23 19:27
Did this work ??? Currently using the NVIDIA Shield K1 tablet, something more compact would be nice.
2019-2-14
Matei DONEA
Flight distance : 1858455 ft
Romania
Yes, it is possible to do this but only with the "smart" controller. In the HDMI output you can mount a specific HDMI cable and have a video signal to a Yololiv from where you can stream much better than through a smartphone.  If you also use a capture card with HDMI input and USB output you can have a video signal to a computer, to OBS Studio for example.  Success
2021-4-17
djiuser_Oua972dLc21S
Flight distance : 776375 ft
Jersey
I have a M2P with a smart controller.  I am trying to get a live feed from my laptop. I have a usb video capture adaptor and 10' hdmi cable. I am unable to get the feed to work. The hdmi on the sc is on and O have tried all the resolution settings. When I connect the hdmi cable to the video out from another computer there is a feed so the hdmi cable and capture card are good. When I try and connect the sc direct to a tv hdmi to hdmi, the tv sees that there is a device and says that the resolution is not supported and there is also no image.
Does any one know what resolution I should use for the laptop connection?
2021-8-4
Geebax
djiuser_Oua972dLc21S Posted at 8-4 15:18
It is not going to work. You are dealing with two different things, serial data and video. Unless DJI decide to output video information from the USB port, it is not going to work.
2021-8-4
Jersey
Geebax Posted at 8-4 15:25
Hi You miss understand. I am trying to use the hdmi video output on the sc via a hdmi cable connected to a hdmi video capture adaptor to usb connected to my lap top. There are a number of you tube clips which use this method but do not say which hdmi settings they are using on the sc. Ie the video output resolution which is what I want to know.
2021-8-5
Jersey
Ok, found out what the problem is. It was the hdmi cable!!!
2021-8-5
