Stewie Griffin
Jenee 2 Posted at 2016-12-18 22:06
When I first started the Controller, Mavic and GO 4, I was presented with an initial setup. During this I was able to select Mode 1 and various other settings including the default for C1 and C2.
I haven't yet flown as I am still trying to go through all the options in the GO 4 app but now I would like to have another look at the options for the C1 and C2 buttons but I just can't find where to get to the settings for this.
One of the drawbacks with the app I find is that the settings you can change are dependant on if you are connected to the Mavic or not. The reason you might not be able to find it easily is because you're not connected, and then it seems like some screens or selections aren't available. I know that for programming the C1 and C2 buttons, if not connected, you have some options, but not all the options. Then when you do connect and turn the drone on, you get way more things you can attach to this custom button.
Of course if you make any changes without being connected, they aren't kept. The reason I guess why its most frustrating is that when the Mavic is on, after only 2 minutes the fan turns on to cool it down, which is annoying if all I want to do is go through all the menus and just get to know the app. You can't really get to know if without the Mavic being on and connected, but when it is, it seems like you are doing damage to the Mavic by having it sit there and heating up just from being on. |
