CuaC
Flight distance : 369626 ft
DJI Joe Posted at 2016-12-19 17:20
Thanks a lot for posting this. I'm sure this will help users that may be having a similar issue with this unsupported phone. I'll forward this to our dev team to see it helps speed up any bug fixing on their end.
Hi Joe! Dev Monkey here!
I'm pretty sure your dev monkeys can also read stack overflow, but this is a known issue in Android as they've changed how some things are drawn in the latest version.
I'm copying the solution from this thread on stack overflow: http://stackoverflow.com/questio ... lay-size-set-larger
I my case, moving the (hi-res) splash bitmap from drawable to drawable-xxhdpi was the solution.
I had the same problem. I didn't suspect my splash screen to be the problem, since it is displayed when the app is started, but it turned out the splash screen is the problem.
The splash screen in my case has xxhdpi resolution, and it was mistakenly placed in the drawable folder, instead of drawable-xxhdpi. This made Android assume the splash screen had mdpi resolution and scale the image to 3*3 times it's required size and trying to create a bitmap.
So yeah, pass it over. 1 minute solution, 5 minutes unit testing, 1 hour integration testing, roll it out and you get all the Android 7 users happy. |
