EdM
Flight distance : 1491814 ft
Norway
Have not had a problem flying close to them, but have had low signal when dropping down behind some when the signal path was directly thru the lines at different times. And as Lildevilx said, depth of field vision can cause you to be right in the middle of them before you realize whats happening. Myself and an observer knew I had flown over a set, then lowered and filmed a wooded area, then did the same thing on the way back. Reviewing the footage later I scared myself when I realized I had flown right thru the middle of them going both ways. Sometimes it is better to be lucky than good. |
