Jimney
Flight distance : 103268 ft
DJI Mindy Posted at 2016-12-23 11:48
Hi Jim, after click start simulating, you will get a new windows.
Then you could use CSC to turn on the aircraft in that windows. Then start the simulating.
Hi DJI Mindy,
That's just the problem, no new windows are opening. It just stays on the window with the stop/start simulating buttons on.
I have used CSC to start and done a take off routine using left stick up. All the long list of the parameters to the right start changing, but no visual simulation screen appears.
Can you confirm I have connected things up correctly as I can't find any instructions anywhere.
Thanks
Forgot to say my PC is running Windows 10 with all the latest updates installed.
