Just curious if anyone has tested the DJI GO / DJI GO 4 app with the new Oneplus 3t.
I currently have a oneplus 2 and do not have much luck using it the the GO app (I know its not on the supported devices list), and I plan on upgrading to the oneplus 3t soon.
If it does not work well i will have to get some other device that i know will work as well.
Also, if it does not work well with the GO app, does anyone have any suggestions for a cheap device on the supported list that would be worth getting.
It works on the OnePlus3 with Nougat so yes it will work on the OnePlus3T, but it is not officially listed by DJI. It works very well other than the recent app crashes that is present on all Androids.
Using Oneplus 3T(Nougat) here with Phantom 3 Pro and Osmo X3 with Old Dji GO App, Phantom 4 and Phantom 4Pro With DJI GO 4 for around two months without any issues.
What about Optical Image Stabilization? OnePlus 3T out of the box comes with OIS, but that is known to not play well with the stabilization provided by OSMO Mobile. Did anyone get lucky with it? Does the app disable OnePlus 3T OIS?
I'm planning to get Osmo Mobile soon, but it would depend on how it works with 3T.
There's a app without ads called disable usb charging +. I use it to disable usb charge. If not, too much heat generated with charging, mobizen recording, high ambient temps. Might want to get off oxygen os too, it's pretty bad. Xda has a lot of devs that make custom roms.
