Barometer Error
3778 18 2016-12-24
tanner80
I received my Phantom 3 Standard in the mail, opened it and updated the firmware.  Now I have a Barometer Error that will not go away.  I have not been able to fly the drone at all.  It appears to have an unrecoverable error.  It also instructs to contact support.  Is it possible to get past this error or did I get a dud?
2016-12-24
DJI Natalia
Flight distance : 318 ft
The upgrading was successful, right? what mobile device you are using to connect the remote?
Please try to restart the aircraft and calibrate IMU then check again.
How about the LED for aircraft status?
2016-12-24
fansa6b0124d
Were you able to fix your problem ? Im having the same issue.
2016-12-25
DJI Natalia
fansa6b0124d Posted at 2016-12-26 00:33
Sorry to hear about the issue, we'd like to collect the information and locate the issue asap.
What's the firmware before you upgrade it to the latest?
Please help export the upgrading log for us as the following instructions:
1. Enable Viewing hidden files in your OS. Below are the websites where you can check how to show the hidden files in your PC. For The Windows System: http://windows.microsoft.com/en- ... den-files=windows-7 For The Mac System: http://ianlunn.co.uk/articles/qu ... mac-os-x-mavericks/
2.Enter the root directory of the SD card, then find the hidden folder MISC and enter it. There is LOG folder in it.
3.The LOG txt file is under the LOG folder.
2016-12-25
fans147e3e0e
Same thing happened to me please help !
2016-12-25
DJI Natalia
fans147e3e0e Posted at 2016-12-26 15:06
Would you please help me confirm the aircraft SN? thanks.
2016-12-25
tanner80
Craft S/N: P5AUDL0501003Q
Camera S/N: P5BDDL06041018
Repeater S/N: P5CUDC60C100SD
Date Code: DL061927483472
The upgrade was successful.  I don't remember the firmware version before I upgraded though.  There is beepbeep....beepbeep....beepbeep consistently ongoing when powered on.  The lights on one side blink green..red..yellow (i think it's that order).  The other two lights are always red.  The status LED is red.  I've restarted and recalibrated more than once and left off for quite awhile in between the calibrations.
I'm using an Andriod (HTC phone) to connect but I've also tried an iPhone and it shows the barometer error too.
P3C_CAM_VERSION.zip
134 Bytes, Down times: 1
Log File
2016-12-26
cris1990
Chile
tanner80 Posted at 2016-12-26 10:35
i have the same error. please help
2016-12-26
SimonR32
Another firmware upgrade Barometer error victim. How long until DJI work out to fix or stop the upgrade so they don't have to replace thousands of drones?
2016-12-26
DJI Natalia
tanner80 Posted at 2016-12-26 21:35
Thanks so much for the information, we're working on it now.
Would you please export the flight data as well and upload it to drop box, provide us the link?
1.Connect your drone to your PC with the USB cable through the Micro USB Port under the Phantom Label in the front.
2.Turn on both your drone and controller, connect your phone to your controller and open DJI pilot
3.This option is under MODE_MC Settings_Advanced Settings_Enter flight data mode.
4.Select that DAT files with the correct date on your PC and send them to us
2016-12-26
DJI Natalia
cris1990 Posted at 2016-12-27 06:27
Sorry to hear about the issue, we're working on it now.
Please help confirm the aircraft SN and export the flight data as the instruction mentioned above, thanks.
2016-12-26
DJI Natalia
SimonR32 Posted at 2016-12-27 13:13
Very sorry for the inconvenience caused, we're working on it now and will let you know once it's done.
Please help confirm your aircraft SN and provide us the flight data if convenient, thank you so much again for your support!
2016-12-26
tanner80
here are the latest files
https://dl.dropboxusercontent.com/u/53627485/FLY028.DAT
https://dl.dropboxusercontent.com/u/53627485/FLY027.DAT
https://dl.dropboxusercontent.com/u/53627485/FLY024.DAT
https://dl.dropboxusercontent.com/u/53627485/SYS.DJI
https://dl.dropboxusercontent.co ... 53627485/FLY026.DAT
2016-12-27
cris1990
Chile
hi my data is here  https://drive.google.com/open?id=0B1gbEFHLbzAwZkZndFlpZ1pkZ2M
2016-12-27
DJI Natalia
Hi all, we've sent e-mails to the e-mail address you used for forum, please check it and upgrade it with the instruction, please feel free to let us know for any further questions.
2016-12-27
tmc073
Just contacted DJI.  They released a new version of the firmware to fix this issue.  I updated to this version (1.07.0094) and all is working great now!
The firmware for the Phantom 3 Standard is here: https://drive.google.com/file/d/0B9s6ow5tFkDxX2Y1QlhDM0ZhR1E/view
2016-12-28
tanner80
Its working now thanks for the new firmware!
2016-12-28
AustinBook
I am having the same issue. I cannot seem to get the link for the firmware upgrade to load. Any idea?
2016-12-31
DJI Natalia
AustinBook Posted at 2016-12-31 10:53
Please send an e-mail to support@dji.com or provide us your e-mail address, we'll send you the bin file and instructions to upgrade it.
2017-1-1
