Donnie Stugots
Flight distance : 3636782 ft
I would do a stick calibration and be sure to rotate the Pan roller ( the one used to pan on the RC ) as well as the sticks . be sure the Rc is in the proper "Mode " as well. Mode 2 is the default .
What version of the RC are you on , Is it updated as well to the latest one ?
*****Start Here - make sure also the camera Pan speed for the Master is not set to 0 as well, this could cause this also ..... check the Camera Configuration ( 1 ,2, 3 ) dont have a 0 set for the camera expo pitch .
I will bet it is a setting that is set to zero value causing the problem .
go to general settings , then to Camera icon =gimbal settings tab, advanced setting, from here check the values . Make sure system is all on .
good luck
donnie
