dji assistant can't find p4p
5157 39 2016-12-25
Tarbax
Belgium
I am not able to connect my p4p to my PC using the dji assistant.
I tried a dji driver install but still wont connect.
Also in device manager shows that there is a missing driver ''CDC Serial''
The SD card is recognized and can be opend.
Using Windows 8.1
dji assistant 1.08
2016-12-25
trance728-
Flight distance : 298048 ft
Have you restarted your computer? And do you have the P4P turned on?
2016-12-25
Tarbax
Belgium
trance728- Posted at 2016-12-25 16:31
yes and yes have tried also on another pc with no lock same exact problem.
2016-12-25
fans82f30c9f
Flight distance : 80112 ft
must update the DJI assistant 2 before it will show the P4pro models.  donnie
2016-12-25
Tarbax
Belgium
fans82f30c9f Posted at 2016-12-25 18:27
as already said i am using the latest version of dji assistant
2016-12-26
DJI Natalia
Flight distance : 318 ft
Do you have anti-virus or firewalls installed on your PC? if so, please turn it off, then install Assistant 2 again.
If you still cannot get it connected, please try to change the USB cables and restart it again.
2016-12-26
Tarbax
Belgium
DJI Natalia Posted at 2016-12-26 04:22
Thanks Natalia,
Tried this a minute ago.
Disabled all my anti-virus softwares and firewalls.
Butt still no connection only sd card is showing up.
Also still have a CDC Serial Driver missing.
2016-12-29
DJI Natalia
Tarbax Posted at 2016-12-29 12:52
Thanks Natalia,
You have installed the driver as well, right?
If still the same case, please try another PC and check the performance.
2016-12-30
Tarbax
Belgium
DJI Natalia Posted at 2016-12-30 00:47
i have this on both of my PC's.
2016-12-30
DJI Natalia
Tarbax Posted at 2016-12-30 04:19
Would you please leave me your e-mail address?
2017-1-2
freelanderuk
Flight distance : 177720 ft
I have the same problem with the dji assist program and my p4, I have tried installing 3 times now with all virus and firewall turned off,logging in and out ,different leads from the p4 to pc and nothing I do will get the programme to even acknowledge the p4, pc is running win 8.1, keeping an eye on this thread hopefully for a good outcome
2017-1-2
Tarbax
Belgium
DJI Natalia Posted at 2017-1-2 01:12
i only send my e-mail via pm. accept friend request so you receive my e-mail
2017-1-2
DJI Natalia
Tarbax Posted at 2017-1-2 05:21
Please check the following info on your PC:
1. Whether there is the "usbser.sys" file under "C:\WINDOWS\system32\drivers”?
2.Whether there is a file named by "mdmcpq.inf_amd64_neutral_fbc4a14a6a13d0c8" under C:\Windows\System32\DriverStore\FileRepository\?
If no, please click on the link below, extract it and put the file under "C:\WINDOWS\system32\drivers", then create a file naming "mdmcpq.inf_amd64_neutral_fbc4a14a6a13d0c8", then put the "usbser.sys" into it.
At last, please install the assistant 2 again. Here is the link for you to download "usbser.sys" file: http://download.dji-innovations.com/downloads/driver/usbser-cn.zip
2017-1-3
DJI Natalia
freelanderuk Posted at 2017-1-2 01:40
Please try the method as I mentioned on 13# and keep us posted, thanks.
2017-1-3
Tarbax
Belgium
DJI Natalia Posted at 2017-1-3 00:06
files were missing but it still won't recognizes the phantom 4 pro after adding the files.
2017-1-3
freelanderuk
Same here ,files missing ,followed your instructions and will still recognise  the P4
2017-1-3
freelanderuk
I have downloaded DJI ASSISTANT 1.0.7 and my P4 connects to it straight away
2017-1-3
Wildersachse 4
Switzerland
same problem here with the connection to my mavic, i want to do a vps calibration, but i can't.
same missing file, everything up to date, the file creation and drag and drop don't solve the problem, no connection!
is there an older version of dji assistant anywhere to download??
2017-1-4
freelanderuk
Link to DJI ASSIST 1.0.7
https://dl.djicdn.com/downloads/ ... sistant+2+1.0.7.exe
Courtesy of  a post on Phantom Pilots by  Tylerjay24
2017-1-4
Wildersachse 4
Switzerland
Yes, it solved the problem, thx
2017-1-4
Tarbax
Belgium
Yes indeed 1.0.7 solves the problem!
2017-1-4
fans2817da00
DJI assistant 1.08 or 1.07 doesn't work for me.  On multiple pcs. It worked for me a couple weeks ago.  Wanting to refresh my firmware.  Any solution yet DJI.  I have tried the things listed above.  It shows the mavic plugged in, i can even see the firmware in the back ground of the log in prompt.  I can browse the micro sd, so i know its connected.  I know my internet is working as i have speedtested the internet and it works on other devices.  I have restarted pc, restarted Mavic, reset password, what gives with this stuff.  Anyways i guess i'll wait to see if it works later today.
2017-1-7
jetforce
Denmark
fans2817da00 Posted at 2017-1-7 06:58
some say  that DJI server is down for the moment
http://forum.dji.com/forum.php?mod=viewthread&tid=79349&extra=page%3D1%26filter%3Dtypeid%26typeid%3D386%26typeid%3D386
2017-1-7
Chief RM
Flight distance : 136204 ft
DJI Natalia Posted at 2017-1-3 00:02
Natalia, please take into consideration that not all of us are technically competent to go into files in WINDOWS to accomplish what you suggested for Tarbax and if the issue is software that it is DJI's responsibility to fix the problem so we just have to download the app.
2017-1-7
DJI Natalia
Chief RM Posted at 2017-1-7 07:29
We're concerned much about your feedback and would like to try our best to help you for any problems.
Very sorry if any inconvenience caused.
The software should be working fine, if it cannot be installed on a PC, we need do some troubleshooting firstly.
maybe we need make the methods more clear. Thanks for your supporting again.
2017-1-9
Chief RM
DJI Natalia Posted at 2017-1-9 03:53
Tried to refresh my firmware again this morning and got the same errors as yesterday.
2017-1-9
DJI Natalia
Chief RM Posted at 2017-1-9 07:06
We've replied you in your original post, please try the methods, if problem persists, then it needs to be send in, our engineers will take care of the case, sorry for the inconvenience caused.
2017-1-9
picky
Flight distance : 279 ft
freelanderuk Posted at 2017-1-4 04:43
https://dl.djicdn.com/downloads/dji_assistant/20161115/DJI+Assistant+2+1.0.7.exe
Thank you for posting. The DJI Assistant 1.07 now works for win 8.1.
2017-1-11
NKars
Flight distance : 834117 ft
Use version 1.09  deinstall the old version first...
2017-1-11
FLIDAHO
Flight distance : 2010249 ft
Looking forward to trying this. I had success only with Win.7 64 on a PC I don't regularly have running. My primary PC is Win 8.1 64 and I have tried MANY different methods with no joy.
Please state what OS you are using to help better sort out these issues. That would be helpful✌
2017-1-11
P4-Pilot
FLIDAHO Posted at 2017-1-11 07:40
Hello,
I´m using win 8.1 64 bit. I´ve tried the Version 1.0.9, 1.0.8 and 1.0.7. I´ve also looked to the usbser.sys and have the files copied to the folders. But the assistent 2 doen´t find my Phantom 4. I have wrote a Mail to the (german) dji-service and i have phone with the german dji hotline. They don´t have heared from this problem...
What can I do????
I´m sorry for my bad english ;-)
2017-1-12
FLIDAHO
P4-Pilot Posted at 2017-1-12 08:26
Hello,
What can I do????
Hello, your English is fine!
I too am having this issue with 3 different PCs running Win. 8.1 (64 bit).
I will make another attempt to get it working this weekend and will post if I have any success.
I was able to get it to work on a Win. 7 (64bit) system, but it's not a PC I keep running and regularly use any more.
Hang in there, DJI must be aware of this issue, and will fix it or give us concrete instructions as to what a proper workaround is.
Dallas
2017-1-14
P4-Pilot
This notification appears in the log-file:
[17:06:33][DevMgr              ] DLL : DJIFlightDataService ignore!
[17:06:33][DevMgr              ] DLL : DJIRadarService      ignore!
[17:06:33][DevMgr              ] DLL : DJIRonin2Service     ignore!
[17:06:33][DevMgr              ] DLL : DJIWatchService      ignore!
[17:06:33][DevMgr              ] DLL : In2UsbReader         ignore!
[17:06:33][DevMgr              ] DLL :  PathPlanningService Doesn't Support Standard API!
[17:06:33][DevMgr              ] DLL : RemoteController     ignore!
[17:06:35][dServer             ] 1    Connected <- root
[17:06:36][DJILogin3           ] set login status : 1
[17:06:36][DJILogin3           ] get login status : OK, error_code : 0
[17:06:38][DJILogin            ] set login status : 1
[17:07:22][dServer             ] Disconnected! /general, root
P4-Pilot
2017-1-15
P4-Pilot
...or a notification like this:
[DevMgr              ] DLL : DJIRcService         ignore!
[DevMgr              ] DLL :         In2UsbReader Doesn't Support Standard API!
There is no difference whether I am logged in or not - the P4 don´t connect to the pc with assistent2
2017-1-15
barrub3d
Flight distance : 53333 ft
P4-Pilot Posted at 2017-1-15 09:11
not resolve..firewall and antiv off..create folder in repository and copied usb file, nothing..
reinstalled, rebboted more time..nothing
RESOLVED installing 1.0.7 version
2017-4-5
kknop
Russia
1.07 indeed works for 8.1 64bit
others do not
2017-4-9
Antonio76
Flight distance : 144403 ft
Denmark
The latest DJI Assistant 2 is v 1.1.0-2, March 27th , 2017.  If your version is v 1.08 you must upgrade.
2017-4-9
jdiago
Flight distance : 42142 ft
Colombia
Turn off the ethernet network and try again.
2017-7-1
fans62f53ef0
Flight distance : 18750 ft
Lithuania
Thanks DJI assistant 1.0.7 solved the problem.
2017-7-17
Eduardo9
Mexico
freelanderuk Posted at 2017-1-3 06:57
Works for my P4 Thanks
2017-8-7
