Barometer error after firmware upgrade
1942 19 2016-12-26
fansd4765c21
I bought a new DJI Phantom Standard 3 from DJI online store.  After updating firmware prior to first flight I now have a barometer error.  My log file is:
[00128017]========== 2016.12.26 09:52:09. boot(15) ============
[00128148]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0x85b93c32].
[00128182]Packet upgrade start...
[00128224]Packet checking...
[00128306]Packet vlink 01.07.0090 <-> 01.06.0080.
[00128341]Done.
[00128381]Version checking[1]...
[00128416][01 00][00] v1.14.4920 -> v1.14.4920 need upgrade
[00128455][01 01][00] v1.14.4920 -> v1.14.4920 need upgrade
[00128537][03 05][00] v34.2.0.9 -> v34.2.0.9 need upgrade.
[00128607][03 06][00] v2.4.20.22 -> v2.4.15.5 need upgrade.
[00128665][04 00][00] v1.51.0.0 -> v1.51.0.0 need upgrade.
[00128734][09 00][00] v0.1.0.9 -> v0.1.1.0 need upgrade.
[00128847][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00131469][11 01][00] v1.7.0.0 -> v2.0.0.33, firmware v1.7.0.0 not support.
[00131502][11 01][00] v1.7.0.0 -> v2.0.0.33
[00131612][12 00][00] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00131738][12 01][00] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00131812][12 02][00] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00131937][12 03][00] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00131972]Done.
[00134003]Waiting for user confirm...
[00144038]Timeout, start upgrade automatically.
[00144114]Firmware upgrading[1]...
[00161343][01 00] Firmware upgrade start...
[00013840][01 00] Firmware upgrade finished successfully.
[00013896]Done.
[00013947]Packet [C:\P3C_FW_V99.99.9999.bin] resumed, card sn [0x85b93c32].
[00014006]Packet vlink 01.07.0090 <-> 01.06.0080.
[00014048]Version checking[2]...
[00014081][01 00][05] v1.14.4920 -> v1.14.4920 need upgrade
[00014116][01 01][00] v1.14.4920 -> v1.14.4920 need upgrade
[00014231][03 05][00] v34.2.0.9 -> v34.2.0.9 need upgrade.
[00014312][03 06][00] v2.4.20.22 -> v2.4.15.5 need upgrade.
[00014355][04 00][00] v1.51.0.0 -> v1.51.0.0 need upgrade.
[00014416][09 00][00] v0.1.0.9 -> v0.1.1.0 need upgrade.
[00014550][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00014669][11 01][00] v1.7.0.0 -> v2.0.0.33, firmware v1.7.0.0 not support.
[00014856][11 01][00] v1.7.0.0 -> v2.0.0.33
[00014976][12 00][00] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00015069][12 01][00] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00015158][12 02][00] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00015261][12 03][00] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00015296]Done.
[00015327]Firmware upgrading[2]...
[00015489][01 01] Firmware upgrade start...
[00045785][01 01] Firmware upgrade finished successfully.
[00045832][12 00] Firmware upgrade start...
[00085260][12 00] Firmware upgrade finished successfully.
[00085299][12 01] Firmware upgrade start...
[00124709][12 01] Firmware upgrade finished successfully.
[00124749][12 02] Firmware upgrade start...
[00164049][12 02] Firmware upgrade finished successfully.
[00164091][12 03] Firmware upgrade start...
[00203650][12 03] Firmware upgrade finished successfully.
[00203691][11 00] Firmware upgrade start...
[00252380][11 00] Firmware upgrade finished successfully.
[00252445][03 05] Firmware upgrade start...
[00326787][03 05] Firmware upgrade finished successfully.
[00327044][03 06] Firmware upgrade start...
[00690416][03 06] Firmware upgrade finished successfully.
[00690476][09 00] Firmware upgrade start...
[00716840][09 00] Firmware upgrade finish without reboot.
[00746882][09 00] Firmware upgrade finished successfully.
[00746957][04 00] Firmware upgrade start...
[00805883][04 00] Firmware upgrade finished successfully.
[00805919]Done.
[00805954]Version checking[3]...
[00805992][01 00][05] v1.14.4920 -> v1.14.4920 need upgrade
[00806027][01 01][05] v1.14.4920 -> v1.14.4920 need upgrade
[00806120][03 05][05] v34.2.0.9 -> v34.2.0.9 need upgrade.
[00806197][03 06][05] v2.4.15.5 -> v2.4.15.5 need upgrade.
[00806234][04 00][05] v1.51.0.0 -> v1.51.0.0 need upgrade.
[00806283][09 00][05] v0.1.1.0 -> v0.1.1.0 need upgrade.
[00806400][11 00][05] v1.8.0.0 -> v1.8.0.0 need upgrade.
[00806541][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00806572][11 01][00] v1.8.0.0 -> v2.0.0.33
[00806782][12 00][05] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00806873][12 01][05] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00806959][12 02][05] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00807042][12 03][05] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00807079]Packet upgrade finish successfully.
2016-12-26
DJI Natalia
Flight distance : 318 ft
Sorry to hear about the issue, we are working on it now.
Besides, may we have the aircraft SN?
Then please export the flight data as the following instruction:
1.Connect your drone to your PC with the USB cable through the Micro USB Port under the Phantom Label in the front.
2.Turn on both your drone and controller, connect your phone to your controller and open DJI GO
3.This option is under MODE_MC Settings_Advanced Settings_Enter flight data mode.
4.Select that DAT files with the correct date on your PC.
Then please upload it to dropbox and provide us the link, thanks.
2016-12-26
fans7059c369
Hi my aircraft is currently doing the same thing haven't even been able to fly it
2016-12-26
DJI Natalia
fans7059c369 Posted at 2016-12-27 14:33
Sorry to hear about that issue, we're working on this case now and will get it fixed soon.
Please help us confirm the info mentioned above if convenient, thanks so much for your supporting!
2016-12-26
fans7059c369
uploading file now
https://www.dropbox.com/s/2z316ixkx9yahy1/FLY040.DAT?dl=0
2016-12-26
DJI Natalia
fans7059c369 Posted at 2016-12-27 14:52
uploading file now
Thank you for the data, I've transferred it to our engineers for further analysis.
2016-12-27
DJI Natalia
Please check your e-mail box with the information and keep us posted, thanks.
2016-12-27
fans7059c369
I am placing the file sent on the p3
I'll let you know the results thank you
2016-12-28
fans7059c369
I have placed file on the sd card in logs but nothing has changed
2016-12-28
DJI Natalia
fans7059c369 Posted at 2016-12-28 17:53
Please format SD card and put the bin file into the root of SD card, then try again.
2016-12-28
DJI飞控加班狗A
DJI R&D Squad
China
Very sorry to hear this, please contact with DJI  support team , they will provide you a firmware with out this issue.
2016-12-28
fans17dd5cdd
I have the same problem. My Mailadress is ingo.stoehr@freenet.de. After I bought the Phantom 3 the first startup was to update the firmware which ended in an Barometer error. Bought the Phnatom Std. in december 2016 and never could flew only one second since there . Please send me new firmware file.
2017-1-2
DJI Natalia
fans17dd5cdd Posted at 2017-1-2 00:22
I have the same problem. My Mailadress is . After I bought the Phantom 3 the first startup was to update the firmware which ended in an Barometer error. Bought the Phnatom Std. in december 2016 and never could flew only one second since there . Please send me new firmware file.
Sorry to hear about the issue, we've sent you the bin file, please upgrade it as the instruction  in the e-mail and let us know the result, thanks.
2017-1-2
Furyswrath
DJI Natalia Posted at 2017-1-2 04:27
So I Have the Same Issue Now with Barometer Error  with Firmware v1.07.0090
2017-1-3
DJI Natalia
Furyswrath Posted at 2017-1-3 18:42
You have mentioned in another thread that the issue has been solved after upgrading with the new bin file.
Now the problem is that you cannot know the firmware version, which will be fixed soon, sorry for the inconvenience caused again.
2017-1-4
Furyswrath
DJI Natalia Posted at 2017-1-4 00:29
No everything is fixed but the Barometer Error.  using v.1.07.0090 the RC Signal Loss error Goes away and Give me the Barometer Error.
Come on DJI I just want to use my drone.. Its your updates that are killing stuff.  Just want a Bug Free update so I can use my Phantom 3. spend 400 bucks on something you want it to work.  And like most folks if I would of gotten on the forums before I updated I would of known dont update.  But I did and Just want it fixed.
2017-1-4
DJI Natalia
Furyswrath Posted at 2017-1-4 07:53
May I have your e-mail address? thanks.
2017-1-5
Furyswrath
DJI Natalia Posted at 2017-1-5 00:25
sammyboy405@gmail.com
2017-1-6
Pap
could you also send me the latest version of the firmware for the Phantom 3 Standard model as I am also getting the Barometer error after upgrading to version v.1.07.0090 ? My email address is savvasp@hotmail.com
2017-1-12
DJI Natalia
Pap Posted at 2017-1-12 03:54
We've released a new firmware yesterday, please upgrade it again.
Here is the link for your reference: http://forum.dji.com/thread-71434-1-1.html
2017-1-12
