Flying with a Nvidia shield
12Next >
13308 41 2016-12-27
fanseb85c303
I am waiting for a Nvidia shield and my drone.  Do you recommend flying in airplane mode or turning WI Fi off or leaving both on.  I have heard so many different things.  What is the best and safest way to set up your tablet?
2016-12-27
Peter Galbavy
Flight distance : 545377 ft
When I have used mine (with a tablet holder) it's worked fine with WiFI on. I normally use a smaller tablet that fits in the arms but it was out of batteries, so the last time I used it was not that long ago.
2016-12-27
Enkeixpress
Flight distance : 297497 ft
I own an NVIDIA Shield K1 tablet but I prefer flying with an iOS device, such as the iPad Mini 4 or the iPod Touch 6th Generation, as DJI seem to favor those devices over Android devices. For e.g. the iOS version of the DJI Go 4 app receives updates first, and seems to be more stable to use. I own both of those iOS devices myself btw.
2016-12-27
Mir
Flight distance : 2718491 ft
I also use a Nvidia shield K1, it's now my primary screen for the Mavic. A few tips:
- For smoother flying I disable the DJI App's local video recording. Instead I use Mobizen to record my whole screen.
- I set the tablet for "Max Performance" mode
-  Under "Performance and Power" options, set "Tegra PRISM Dynamic backlight" to OFF, it will give you a bit more screen brightness- Disable/uninstall any app you're not going to use
- I also set the tablet to Airplane mode, otherwise it will keep pinging for wifi in the 2.4ghz band, same as your mavic frequency.
Overall I've found my shots to be ten times better using a tablet and I can see a whole lot more detail while flying.
2016-12-27
Socalrob
Flight distance : 5892 ft
Mir Posted at 2016-12-27 10:13
I also have the nvidia shield k1 and I'm waiting for a holder. My lg v20 phone isn't working well with the DJI go4 app but I'm still trying things. Thanks for your setup info, I'll try those settings when I get the holder.
2016-12-27
fanseb85c303
Thank you MIR
2016-12-28
fanseb85c303
MIR a couple more questions.  How do you disable DJI recording and use Mobizen??? Is that an app?  And also can you activate a new drone with a Nvidia shield because it is not a DJI approved device.
2016-12-28
JustABill
Just picked up a Nvidia Shield K1 tablet....  so far so good with this device and my Mavic Pro.  The specs speak for themselves...
Dedicated GPU: NVIDIA Tegra K1 192 core Kepler GPU
CPU: 2.2 GHz ARM Cortex A15 with 2 GB RAM
Not as "square" and "bulky" looking as an ipad mini.....
2016-12-28
fanseb85c303
How are you recording your screen and where do you save it too?  Did you activate your drone with the shield?
2016-12-28
Mir
You can disable local cache recording in the DJI app settings, I believe it's under general settings. This is just my preference though.
Mobizen is an app you can get from the app store. It records your whole screen, so you can play it back in case something goes wrong or to look at your telemetry again.
2016-12-28
fanseb85c303
Thank you.  I thought the shield has its own screen recording is all.  Why is the app more beneficial
2016-12-28
DJI-Ken
Flight distance : 1515312 ft
JustABill Posted at 2016-12-28 06:49
Does your Shield fit in the holder slots, or do you have to remove the inserts. I have a iPad Mini 3 and it just barely fits in the inserts and it's perfect where it sits.
I see the Shield is just a little thicker so I didn't know if it would fit or not.
2016-12-28
Peter Galbavy
Ken, shield is far too wide let alone deep to fit. I have a 7" tablet that just fits, and that's right and worries me about the arms enough.
2016-12-28
fans093fc0b7
Flight distance : 514373 ft
Peter Galbavy Posted at 2016-12-27 23:40
What tablet holder do you use?
2016-12-28
fanseb85c303
I dont have my mavic yet but I ordered a custom tablet adapter from Etsy.
2016-12-28
DJI-Ken
Peter Galbavy Posted at 2016-12-28 12:19
Thanks, I didn't think it would fit. I may get one to support Android users.
I used to have one but got rid of it as the battery would go dead very quickly, my iPAds will last almost a week.
2016-12-28
JDBull
Flight distance : 917054 ft
Thanks for the Shield setting tips as I'm new to the Shield.  I just got it because I wanted a bigger screen and to use the HDMI out into my FatShark Dominator V3's.  I'm using the 3D printed "Z" clips to hold the Shield in place.  The problem I'm having is I can't get the Shield display to rotate so the HDMI port is on the lower right side.  The FatShark's work great but with the "Z" clips and the HDMI port on the upper left side it doesn't work becasue the tablet sits to high and interferes with the sticks.  How do I get the Shield display to rotate?
BTW as far as FPV goes, the FatSharks are $349 and the Nvidia $200 so it's a $550 FPV solution.  I like the size of the FatSharks and the 720P image.  I don't like the additonal HDMI cable going to my head.  I also tried the Litchi and a VR goggle setup.  The head tracking of Litchi is cool but I don't like the bulky VR googles and much prefer FatShark size.
Here's to hoping DJI comes out with a wireless FPV headset that's not to big and bulky nor too expensive.
2016-12-28
Peter Galbavy
fans093fc0b7 Posted at 2016-12-28 19:30
I got this via a Chinese reseller on Amazon UK (https://www.amazon.co.uk/gp/product/B01N97XNYV) - it's "ok" but not special. I don't like the very long fixed arm which can be made even longer. On the other hand, the spring grip is stronger than it feels and holds the shield by the narrow side only, so you have to rotate it to have the grip top/bottom, unlike my smaller 7" tablet which fits left/right. I think that the balance is better with the top/bottom grip however as the ball joint is off center when the spring moves, so up/down is easier to balance than left/right.
2016-12-28
Chazzm
JDBull Posted at 2016-12-28 15:16
I have the exact same setup, meaning Fat Shark Dominator V3, But am awaiting a new nvidia shield K1, my granddaughter got ahold of my last one ( my fault) my question is where can I get ahold of these Z clips??? I've searched high and low, and since I don't have a 3D printer,,,,,,could you make/sell me a set for mine? Or a least show me where I can get a set???????? Please?
2016-12-29
Mir
I've flown fpv with the shield > hdmi out > fatsharks. To be honest it's not that great of an experience. The text is legible and you can fly it, but I much prefer looking at the Shield's screen. The nice thing about the fatshark though is it blocks out the sun, so you can definitely see easier.
2016-12-29
phantom_of_the_
Flight distance : 90459 ft
DJI-Ken Posted at 2016-12-28 12:36
Hi Ken, any chance you could have it added to the list of DJI's recommended Android devices? As far as I know it still hasn't been added, even though its one of the most popular out there. I think that list needs a good updating in general to be honest.
2016-12-29
DJI-Ken
phantom_of_the_ Posted at 2016-12-29 10:31
I will ask and see what they say.
2016-12-29
eurocenter
Flight distance : 12339 ft
Greece
Peter Galbavy Posted at 2016-12-28 11:19
Using a Tablet With Your DJI Mavic Pro Quad
2016-12-29
JustABill
DJI-Ken Posted at 2016-12-28 11:16
mavmount.com makes a great adapter.
2017-1-9
puredata
DJI-Ken Posted at 2016-12-29 10:33
Is there any updates on this? Thanks in advance.
2017-1-9
DJI-Ken
puredata Posted at 2017-1-9 14:50
No, nothing yet.
2017-1-9
Mavic 007
Mir Posted at 2016-12-29 10:22
Totally agree, I had the fatshark dominator v3 hd set in use with the k1, and the video quality was awful. Sent those back and picked up the Yuneec Skyview for half the price and the field of view and image is so much better.
A buddy and I hiked up a mountain near Madrid Spain to King Ferdinand II hunting lodge ruins to get some areal shots and he was blown away by the video quality of the goggles. He wore them while I controlled the Mavic through the K1.
2017-1-9
puredata
Thank you for your answer.
Could you please clarify if we use our aircraft with NVIDIA Shield and something goes bad, are we completely ruled out of being considered for examination of the case by DJI because it wasn't on the supported device list? Does using Shield Tablet void warranty?
Thanks in advance again.
2017-1-10
DJI-Ken
puredata Posted at 2017-1-10 16:15
I would not think sing a Shield K does not void your warranty.
If your device crashes or has an error, you still have full control of the aircraft with the RC.
2017-1-11
phantom_of_the_
Mavic 007 Posted at 2017-1-9 15:40
Thank you for sharing that experience. That is very useful information, as I was looking into the Dominators. So I owe you a beer for saving me the bother of sending them back
2017-1-11
phantom_of_the_
Good question. However I am unsure if DJI can tell exactly what device you are using. Is this recorded in any logs? Hmmm
2017-1-11
Mavic 007
phantom_of_the_ Posted at 2017-1-11 13:50
Not a problem. Truth be told, I would dump the K1 and Yuneec when the DJI goggles come out, but that will depend on the price for sure. I wonder if they will be vaporware given the line of sight rules in most countries.
2017-1-11
Clarxhouse
Flight distance : 160102 ft
I am using a Shield with my Mavic and DJI GO 4.  My HD signal bars flash all of the time no matter if I am at my house or out in the country with nothing around.  If I go into the POI intelligent flight mode the DJI GO 4 app will shut down.  Does anyone have any recommendations on this?  I also fly in airplane mode but when doing this I can not see the Here map because I am offline.  I have tried installing here on my device and downloading the map and switching it to work offline but that does not work as well.  If I use Litchi and download a map using Google maps the map works fine.  Does anyone have a workaround for using the Here maps while being offline?  Sorry for so many questions but this is becoming very frustrating.  I have about $1700 wrapped up in this drone with all of the accessories and I am scared to fly the dang thing because of all of the issues with the DJO Go 4 app and now they won't allow you to use the original Go app because the Mavic is not supported.  i guess I could go out and buy a $400 Ipad mini 4 but I have never used an Apple product and don't really want to start now or spend the money and the Ipad Mini's don't have gps so that won't support the return to home from the PIC.  Ken do you have any suggestions on this?
2017-2-12
FlipFlop
Flight distance : 4439 ft
I've just ordered this holder so I can try and use my shield instead of my old smart phone. Will let you know what it's like:
https://www.amazon.co.uk/gp/prod ... 0?ie=UTF8&psc=1
2017-3-22
bomberuk
Flight distance : 16759 ft
dont upgrade the firmware on the shield to 7.0 keep it at 6.01 or the dji go 4 app crashes all the time,i had to downgrade my shield k1 firmware to 6.01
2017-3-22
hridge
Flight distance : 17651 ft
How is the screen quality/ brightness in the sunlight?
Just found this... comparison
2017-3-22
Mir
hridge Posted at 2017-3-22 08:26
As with all current devices.. it sucks under sunlight. I always find some shade to stand under. If you have some shade, looks just fine.
2017-3-23
JBuck
Flight distance : 322398 ft
Several flights on this tablet now. Running Google 6. No disconnects, and minimal latency. So far it's a keeper.
2017-3-26
R&L Aerial
Flight distance : 298100 ft
The nvidia shield flys quite well if you throw it like a frisby
2017-3-26
fans27b2a16a
Flight distance : 254324 ft
Argentina
I'm having some problems with my K1, after updating the latest version of DJI Go4, the image is frozen, do you guys have the same problem? Flight with a Phantom 4 ... Thank you !!
2017-4-13
12Next >
