phantom_of_the_
Flight distance : 90459 ft
Hi folks,
Kinda annoyed right now, as after spending 45 mins outside with my P4 ive had to come in without even taking off!
Basically, when I turned everything on and connected as I normally do, I got a message telling me that I needed to update the firmware. No problem I thought, as ive done this loads of times before. First attempt failed, with the error message that the Phantom was disconnected.... It was connected just fine... So I tried it again, this time it got to 5%, where it just sat for 15 mins, and then failed again. Same reason. So I turned everything off, took battery out of the Phantom and put it back in. Restarted tablet (NVIDIA Shield K1), turned controller back on etc....This time when I load up the DJI Go app, it tells me my firmware is of the latest version! What the heck!!
No problem I thought, however I have now noticed a couple of strange issues that were not there before! Firstly, I have a small red warning near the top of my screen, telling me there is something partially blocking the front VPS. Which there isnt. I even cleaned the 2 sensors with a microfibre cloth. VPS appears to have now turned itself off until this issue is fixed. Secondly, there appears to be an issue with the maps. Normally before a flight I would cache my maps so I can turn on aeroplane mode during flight. However when I choose the "terrain" option, the one that gives you all the trees etc, it simply doesnt cache the map. Its like GPS and WiFi are turned off and it cant download the mapping data. So there is just a blue blob in the middle of a big sea of nothingness.
Can anyone give any advice?
Thanks.
