DJI Natalia
Tiago Arii Posted at 2017-1-1 13:20
I have exactly the same problem but when I try to upgrade the gimbal starts normally and after 2 minutes she makes a weird noise and the led becomes red continuous.
when I upgrade to v1.10.09 the result file after upgrade as it said 'success'.
After finish the upgrading process, how about the led status on the gimbal camera? it's solid green or not?
Since it shows "Success", have you tried to restart the aircraft and calibrate it then check again?
Also you can turn it off, unplug the pin cables attached to gimbal, wait for a while, then plug them tightly again. |
