ESC error M600
3764 13 2016-12-29
gryzzly
Hello,
I have recently replaced a bad motor on my M600 but I'm still getting a M600 error.  When I start it up the lights at the end of the motors flash yellow on all but my new motor.  Its like all the other motors need to be reset or something.  Any advice?
Thanks!
2016-12-29
DJI-Jamie
Flight distance : 112405 ft
Did you only replace the motor itself, or its whole arm? Did you make sure you got the appropriate CW or CCW one?
2016-12-29
gryzzly
DJI-Jamie Posted at 2016-12-29 13:19
I replaced the whole arm assembly.  And yes, I got the appropriate one.  The one I replaced actually turns when ESC testing in DJI Assistant.  It's all the others that don't turn. Its as if the others are stuck in "auto-shutoff" mode or something.  Like they just need to be reset or something.
2016-12-29
DJI-Jamie
gryzzly Posted at 2016-12-29 14:34
Just to clarify, did you replace the motor due to a crash or out of box issue?
2016-12-30
gryzzly
DJI-Jamie Posted at 2016-12-30 10:34
It was a crash, but the motor I replaced was the only one with physical damage.  The arm broke and the wires were pulled from the motor mount so I replaced the whole arm assembly.
2016-12-30
Tahoe Ed
Flight distance : 41668330 ft
Did you check all the connections on the motors that you did not replace.  Do you have the flight data log of that crash?  I am just wondering if something else was damaged.
2017-1-1
gryzzly
Tahoe Ed Posted at 2017-1-1 15:54
Do you mean open up all the motor mounts and check the wires connecting to the ESC board?  No, I didn't do that.  But I don't think those wires would have been put under stress when none of those arms were affected by the crash.  The main hub of the craft wasn't hurt either and all those connections look fine.  I downloaded the ".dat" files from the bird, but apparently there is no way to read those.  Only DJI support can?  What do I need to do to get the log of the crash?
I'm really hoping to repair this thing myself because shipping an M600 is a pain...
2017-1-1
DJI-Jamie
gryzzly Posted at 2017-1-1 21:29
Just for further troubleshooting, have you tried switching the working arm with one of the other arms fo see if it only responds to the replaced arm or that particular motor position.
2017-1-5
gryzzly
DJI-Jamie Posted at 2017-1-5 15:00
I have not, but I'll give it a try when I get some time.
2017-1-5
DJI-Jamie
gryzzly Posted at 2017-1-5 16:39
Whenever you have a chance would be great.
2017-1-5
RimpleStillSkin
I have just updated firmware on M600 and I got 1ESC Error Status.  The M1 motor blinks yellow about 1 time a second.  I have downgraded best I know how but no help.  DJI Go app says to contact DJI Customer Support?  What should I do?   My Z5 light is red.   This aircraft has performed flawlessly up til now.  No crashes, no flips, simple perfect operations and soft landings.
Is there a way to revert software to the very beginning and reload everything?
What is DJI solution?
Or should I start a new thread.
Thanks.
2017-3-4
ricci2
Flight distance : 61158 ft
Hi,
This thread shows how to read the data using assistant 2 data view if that helps .
http://forum.dji.com/thread-83184-1-1.html
Ricci
2017-3-4
RimpleStillSkin
ricci2 Posted at 2017-3-4 19:13
Hi,
thanks... will take a look
2017-3-5
RimpleStillSkin
Replaced the M1 motor arm CCW and error went away... crap
2017-3-8
