Seb
Flight distance : 659003 ft
Poland
Calm down guys Compass calibration have nothing to do with declination, at least directly. It only calibrate the magnetic field sensors (there are three inside the compass chip - one per axis) allowing the computer to check what measurement value corresponds to the strongest measurable magnetic flux level (so we can determine the full scale of each sensor for the same magnetic field level). This maximizes precision and reliability of compass, but with better or worse calibration, compass will show you roughly the same direction of magnetic north. Declination is a difference between magnetic north and geographic north. To obtain declination value you only need to know your GPS position and current date, then you can calculate it using some math and World Magnetic Model dataset.
But you are completely right in one important thing - good compass calibration is essential in areas, where magnetic inclination is high. So maybe you just confused declination with inclination. Norway definitely is a country where inclination values exceeds 70 degrees. For example highest inclination is over magnetic pole, where it reaches 90 degrees - compass points directly down. And this is why you can't fly your drone near magnetic poles, because it shows no horizontal direction. |
