Motor Bearings
2480 12 2016-12-30
imtheredude
Flight distance : 3777011 ft
Anyone here had Motor Bearing failure yet? I think I have one going bad on mine. Don't know if I should send it in or just order the motor myself and install it.
2016-12-30
jorgerodrigues
Flight distance : 181781 ft
Switzerland
I would say send it in, the phantom 4 is a relatively new drone, so warranty will not void if repaired by DJI...
2016-12-30
imtheredude
jorgerodrigues Posted at 2016-12-30 14:35
yeah you know how it is, hate to be without it for a month.
2016-12-30
dirtdroner
Flight distance : 3633799 ft
Bend the spring tabs up a little under the prop. They sag and allow the prop to wobble on the mount as the motor spins past the magnets. The rattle sounds like bearings.
2016-12-30
imtheredude
dirtdroner Posted at 2016-12-30 14:49
Yeah it's got the bearing rattle for sure. This was a refurb so I just hope the others hold up.
2016-12-30
imtheredude
Well Dirtdroner I owe you a great big THANK YOU!!!  That cleared up the noise! It's smooth as butter now. I can't believe it. I'm glad that's all it was though.
2016-12-30
dirtdroner
imtheredude Posted at 2016-12-30 15:17
Glad I could help. I now have two spare motors because I didn't find the answer until after I panicked {:4_177:}
2016-12-30
SPRTBKRYDR
dirtdroner Posted at 2016-12-30 19:14
Can't hurt to have a spare I guess.....
2016-12-30
Tracker
Flight distance : 1263419 ft
Indonesia
Anyone has information the Phantom 4 motor bearing lifetime (hrs).
2016-12-31
SPRTBKRYDR
I'd like to know myself. Maybe one of the Mods can chime in and let us know.
2016-12-31
Ercoupedriver
Flight distance : 1075778 ft
Dirtdroner I had the same problem.  My 2 rear motors was doing the same thing, I thought it was the bearings also.  This fixed the problem, THANKS
2017-1-1
dirtdroner
It's beginning to be a pretty common issue as our birds are fairly near the same age. I see it asked quite a bit around the various forums. Seems a pinned post by DJI explaining it would help.
The new P4P uses a small coil spring instead of the leaf spring. I've not seen it available as a replacement part yet but I'm going to get some as soon as they are. One DJI dealer said everything else was the same so it should be a fairly inexpensive upgrade.
2017-1-1
user14f4a497e5
Flight distance : 240551 ft
Tracker Posted at 2016-12-31 02:14
Check ceramic bearings !
2017-10-4
