Triple yellow flashing of rear LED: X X X.... X X X.... X X X... ??
3230 23 2017-1-2
LukasBlecha
Flight distance : 577543 ft
Czechia
Hello guys, few days ago I tested newest firmware 1.03.002 if everything is running smoothly and testing some features (follow me, active track, etc). And when my Mavic was flying near to me, I have noticed triple yellow flashing of the rear led lights:
X X X (in 1 seconds)......then 1 second break... X X X (in 1 seconds)......then 1 second break... After few seconds it started blink green as usual.
I have checked manual but there is no info about tripple yellow. There is only fast yellow blinking. I have noticed this flashing few days ago with the old firmware as well and really dont know what does this mean. There were no warning on the RC or phone, no disconnect... No mention about any error in flight log.
EDIT: Yesteday, I have experienced the same behaviour! During slowing down the Mavic.
Anyone experienced the similar flashing? Thank you!
EDIT 2017/01/18: I was able to film this behaviour HERE:
2017-1-2
Visualkaos
Flight distance : 755988 ft
did it go into Atti mode?
2017-1-2
DRONE-flies-YOU
Flight distance : 1450594 ft
Looking at your log on hd, you're hitting a lot of tolerances - video cache, altitude, modes not enabled, etc...  Not sure, but mine blinks a random yellow or red in between lots of green flashes.  This will happen in any phase of flight & is very inconsistent.  App will show nothing, of course.  ALL values are very low numbers for sensors, it's hovering, no wind, etc.  Doesn't matter.
2017-1-2
Heavysledz
Flight distance : 819491 ft
Are you certain it isn't red and yellow alternating? It is hard to see the red when it flashes really fast. if it is, then it is telling you to recalibrate your compass....but you should also receive a pop up warning on your Phone/tablet as well....
2017-1-2
Hello LukasBlecha, could you please make a short video of the light? I'll help to check it.
2017-1-2
LukasBlecha
Czechia
It is definitely only triple yellow flashing, not yellow and red.  YELLOW: X X X.... pause.... X X X .... pause.... X X X... Triple flashing is done in one second. There is no info in the app or on RC. Everything is on GPS mode with 15-20 satelites.
DJI Mindy: Unfortunately dont have video of this because my phone is in the controler.
2017-1-3
LukasBlecha
Czechia
Still no ideas, DJI?
2017-1-5
LukasBlecha
Czechia
Edited because of reply to Mindy in next post.
2017-1-18
LukasBlecha
Czechia
DJI Mindy Posted at 2017-1-2 19:33
Today I was able to shoot it with my mobile, experiencing this triple yellow blinking REALLY OFTEN! DJI, why is this happening? What does triple yellow means??
THANK YOU!
2017-1-18
CuaC
Flight distance : 369626 ft
LukasBlecha Posted at 2017-1-18 00:50
Today I was able to shoot it with my mobile, experiencing this triple yellow blinking REALLY OFTEN! DJI, why is this happening? What does triple yellow means??https://www.youtube.com/watch?v=ugFsZM24AZE
THANK YOU!
On the uploaded healthydrones log it says many times:
        Warning        Large Wind Velocity. Fly with caution.
Could it be that the light blinks due to a warning status? Did you see the wind velocity warning on the app?
2017-1-18
LukasBlecha
Czechia
CuaC: Of course not. It has nothing to do with wind. On video with triple yellow there was no wind warning.
2017-1-18
DRONE-flies-YOU
LukasBlecha Posted at 2017-1-18 08:09
OK, mine intermittently did this so I did a perfect IMU calibration at a local CNC machine shop.  They had a machine-leveled granite block that I used.  Now no more weird lighting scheme ever on the Mavic and the horizon is always level.  It also seemed to smooth out the Mavic's flight characteristics.
2017-1-18
THANK YOU!
Did you get any error message from DJI GO app?
2017-1-19
LukasBlecha
Czechia
DJI Mindy Posted at 2017-1-19 03:51
No warning messages at all as I wrote in my first post.
2017-1-19
LukasBlecha Posted at 2017-1-19 09:35
I have reported this to our related team.
If I get any update, I'll let you know.
2017-1-20
I have confirmed with our engineers.
It will not affect your flight, please don't worry about it.
I also PM you, thank you for your feedback.
2017-1-21
LukasBlecha
Czechia
Thank you, Mindy.
2017-1-26
HWKIDD
Flight distance : 22877 ft
CuaC Posted at 2017-1-18 03:59
been following this thread,   has there been any update as to why this is going on?  have not seen anyone else post with the same issue,,   I have seen several issues  but  very few have resulted, in a statement of what caused it,  or what the fix was,
2017-1-27
Doots
Flight distance : 682598 ft
So the answer to the triple yellow flash is top secret info now?
2017-1-27
CuaC
Doots Posted at 2017-1-27 22:22
It means chinese government taking pictures over the western countries
2017-1-28
djiuser_5jG4nFn
Flight distance : 1365676 ft
Looks like this thread has gone a little quiet. But I'm posting in case anyone is still interested. I'm getting exactly the same symptoms as LukasBlecha. Doesn't seem to affect flight performance. It does make your cheeks go tight when you are over water though. Happening at really short range too. I'm pretty good at analysing the logs, so I'll keep an eye on it and see if I can narrow it down to a specific piece of flight activity.
2017-8-5
Lucas775
Flight distance : 50642090 ft
DJI Mindy Posted at 2017-1-21 20:01
Is there any way you could share us what the triple yellow flashing means?
Thnaks,
2017-8-5
wisnia.sebastia
The two imu may be disagree with each other at that moment. Flight log  will be appreciated for deep analysis.
2017-8-8
Lucas775 Posted at 2017-8-5 12:00
Thnaks,
Hi, Lucas, the post on 23# is from our R&D engineers, if you encounter the same issue, we would appreciate if you could provide us the flight log.
2017-8-9
