Possobile OIS solution for iPhone 7 Plus
7223 14 2017-1-8
fans417abfbd
Flight distance : 434593 ft
Thailand
Since the x2 rearward facing camera does not have OIS, would it not be possible to produce/supply a "Clip On" converter to make this the same as the wide angle lens?
Some people say they already have weight issues with the iPhone 7 Plus so maybe this would be a non starter?  Just a thought.
2017-1-8
fans9c9a7d66
Flight distance : 12543 ft
what about the magnet option - anyone trying this?
2017-1-9
Artifex
Belgium
fans9c9a7d66 Posted at 2017-1-9 05:22
That's also my question !
The easiest solution is that Apple offers an option to disable the OIS, simple as that...
2017-1-9
DJI-Thor
Flight distance : 13602 ft
It's not a weight issue, iPhone 7P has similar weight with 6sp, so it's not a problem.
Currently the only fix of the OIS is through hardware fix, the magnet option.
2017-1-10
ComPH
Artifex Posted at 2017-1-9 06:22
I don't think that Apple can do that. I believe that the OIS is hard wired into the camera modules and not accessible to system software.
2017-1-11
A1000
Flight distance : 149760 ft
ComPH Posted at 2017-1-11 10:40
I think you're right, as I understand it there are two types of image stabilisation 1) software (cinematic stabilisation) which can be turned off; 2) OIS which is hardware based and built into the camera module in the form of small 'springs'.  #2 can't therefore be disabled other than potentially using a magnet to dampen the 'springs' and hold the camera using still. It has to be said that this does have a potential risk in that it could damage the camera module.
2017-1-11
fansf491992d
Flight distance : 942231 ft
Pretty sure its not as simple as that. OIS is a mechanical hardware feature built into the camera.
2017-1-12
ComPH
A1000 Posted at 2017-1-11 11:09
Well, the OIS is actually active as well. There are springs, but there are also voice coil electrical and magnetic mechanisms, that actually form "servo loop" with the sensors and controllers that are hard wired into the camera module that Apple (and almost anyone else) buys from Sony. Sony has this system self contained, and doesn't allow external software to disable it. In stand alone cameras they can disable this servo loop and have the electro-magnets hold the optics still. For whatever reason, this is not possible in the iPhones. In some cases they can also keep the optics still, and move the actual sensor.
https://en.wikipedia.org/wiki/Image_stabilization
2017-1-22
ComPH
As far as external magnets overriding the servo mechanism, I would hope that the module is either magnetically shielded or uses non-magnetic stainless metals, otherwise that would be some mess to guarantee operation in all instances. I really don't think that the OIS in the iPhone can be disabled without gutting the iPhone.
I read about the problem and look at the videos, but there seem to be several issues with the stability. One is bobbing, that is caused by walking, and moving in the vertical direction. That cannot be fixed, unless 'four plus' axes stabilizer is used. Steadicam vest, Movi, etc. have that as part of the system the operators wear, it is heavy and consists of spring loaded parallelogram like mechanism(s). that is something on top of the three axes, and could be added. You'd still need the three axes like Osmo. (https://www.bhphotovideo.com/exp ... ideo-rig-stabilizer)
I also seem frame drops, that are most likely caused by the system either not keeping with the very high bitstream coming out of 4k video, or in case of editing, the discrepancy between frame rates (e.g. Computer 24p vs TV/some editors 23.976p).
(https://en.wikipedia.org/wiki/Frame_rate)
I so far haven't see something that is specific to DJI Osmo Mobile.
2017-1-22
A1000
ComPH Posted at 2017-1-22 10:27
You have unpacked my definition and simplification of 'springs' well ;-) and the system that Sony/Apple have created does a pretty good job on my iPhone 6S plus.  There is little advantage for Apple in spending time and effort providing mechanisms to disable it for the few users who have an osmo or the like is my guess.
2017-1-22
A1000
ComPH Posted at 2017-1-22 11:01
I read about the problem and look at the videos, but there seem to be several issues with the stability. One is bobbing, that is caused by walking, and moving in the vertical direction. That cannot be fixed, unless 'four plus' axes stabilizer is used. Steadicam vest, Movi, etc. have that as part of the system the operators wear, it is heavy and consists of spring loaded parallelogram like mechanism(s). that is something on top of the three axes, and could be added. You'd still need the three axes like Osmo. (https://www.bhphotovideo.com/explora/video/buying-guide/video-rig-stabilizer)
I agree with you on the 'bobbing' at this price point it is a '3 axis gimbal', the 4th axis is in your legs, body and arms ;-)
Having played with the gimbal and looked at the great output others' have created I don't believe the issues are necessarily with the physical hardware.  It feels good in the hand and ergonomically works for me. There may be tweaks to the firmware that could enhance it, but the real challenge is two-fold: firstly, in the DJI Go app (and the integration with other apps); and secondly, us as users getting used to what it can achieve and can't achieve and adapting our styles and usage profiles.
It is a 1st gen product and therefore probably not a true open the box and operate product in a mass consumer context yet and requires some additional skills to be provided by the user. The good thing is that so far the physical hardware seems sound and the firmware/apps/users can be tweaked, adjusted and evolved over time - hopefully ;-)
2017-1-22
ComPH
Above is image of the two lenses in the iPhone 7 Plus. The top picture shows the coils (L) and magnets(R) at the corners of the OIS assembly of the wider angle lens. The lens below, the longer focal lens, doesn't have the OIS arrangement.
Above is little more detailed photo of the iPhone 7 Plus wide angle lens clearly showing the OIS coils (L) and magnets (R), comprising the active portion of the image stabilization "motors".
2017-1-25
ComPH
There is a shield over the OIS motors (right camera). I doubt that external magnet would disable just the OIS motors, but not something else, like the focusing motors, if it would work at all.
2017-1-25
ComPH
ComPH Posted at 2017-1-25 10:30
[view_image]
The system failed me - didn't show both photos, and wouldn't let me edit the post. Above I obviously meant the (LEFT camera). Sorry.
2017-1-25
djiuser_ADcRmjW
Hey guys here is a test with the magnet fix. We have been using it for a while, it works pretty well...
[/url]
2017-7-13
