Henry M.Y.
Flight distance : 11548839 ft
Hi Alex,
Thank you for doing the tests and sharing your findings with us.
I would like to expressed some of my humble views on some of the findings which you and other Fellow Forum Members may take into consideration when interpreting the findings.
1) Diffraction abbreviation is the main reason why shutting down to f11 will result with less sharp photo in the sharpness tests.
2) When comparing flares, the sun was shot in the middle of the photo taken with the X4S, and was shot slight on the right hand side of the photo taken with the X5S. Any flare, if ever exist in the photo of the X4S, would definitely be also right in the middle of that photo, rendering it impossible to be distinguished from the bright image of the sun.
3) Great to know that the dynamic ranges of both cameras in low ISO are equally good, with the X5S slightly outperforms the X4S. The 1" sensor of the X4S closer in sizes to the M4/3 sensor could be the reason.
4) The findings on the details in low light video footages from both cameras are interesting - there are so many details revealed in the X5S footage, a lot more than those revealed in the X4S footage. It is difficult for me to understand the difference. It would be great if you can advise whether both were shot with the same CODEC (i.e. either H.264 or H.265) or the 2 cameras were shot with different CODEC (i.e. X4S with H.264 and X5S with H.265).
Many thanks again to you Alex, and hope you can further advise / given comment on my views.
Henry |
