kiltedrunner
Flight distance : 484948 ft
DJI-Ken Posted at 2017-1-14 20:25
You can try to restore to factory settings from the Assistant2 so see if that helps.
You can also refresh, or downgrade/upgrade the firmware.
If those don't resolve it, then you may need to send it in for evaluation.
Thank you DJI Ken.
I already reset to factory settings a week ago, and today I downgraded the firmware one level. Once downgraded, I flew the drone and the same Compass Error came up. I decided to re calibrate the compass to see if that would help, flew again with issues on the compass. So then I upgraded the firmware to the most current - flew the drone and received errors, so then I re-calibrated the compass and again received more errors.
I'm not sure what else I can do. Thoughts? |
