wojdop
Flight distance : 564469 ft
Hi All! I was following this forum many months as I was waiting for my Mavic endlessly. Finally it arrived so I can share with you some experiences.
Many of you was writing about the problems and even crashes what was worrying me quite a lot. Luckily my bird works perfect straight out from the box, just updated. No calibration at all needed. And it flies amazing. It's my first drone but I had no problems at all with flying.
I bought it mainly for the photography and here are my first thoughts:
For such a small sensor it does it job very well. Has enough dynamic range for most of the landscapes, but be worry that If you push the shadows up the grain comes out very quickly, killing the details in the dark parts.
Highlights have gentle borders, no strange glooms and halos. But watch out the histogram, there is no place for the mistake. With such small sensor highlights burns out quickly (but I have to say that It performs better than I expected).
I've tested only ISO 100 so far and the files are flexible enough to post process RAW files in Lightroom quite a lot. Automatic WB tends to give a bit green and cold images, but there are no problems with adjusting that and final results are good. I like the colours which it gives, especially green looks natural and it doesn't turns yellow as it tends to do in my Olympus camera.
Editing be worry that the colour noise shows up almost immediately during the post production, but luckily it's easy to correct without harm to the quality
The lens is fine, sharp across the whole image with CA corrected very well. It catches flares very easily (even if the sun is quite a bit outside from the frame).
That's all what I can say by now, I have it only 3 days so there is still a lot to discover an a lot of photos to take.
What are yours experiences with the Mavic as a Photo drone? Share your images!
