So my Mavic just dropped from the sky... What the ...
2579 20 2017-1-13
stratosHD
Flight distance : 1231280 ft
Well, yes just as the title reads. I am very worried and confused at what just happened now.
As I type this im exporting the logs form my Mavic, it just dropped from the sky.
I was taking a safe and even a bit boring flight around 7pm today. There was good visibility and decided to fly in a nearby Golf course.
I was just flying on around the area and decided to just land as normal. I took off from a 'Green' of one of the holes.
As I was returning to land everything looked normal, open area , flat non obstructed, I had about 80% batttery left.  I was about to land hovering about 1 metter from the ground, I pull the joystick down to land and it suddently dropped to the ground just like that.
It hit the grass violently, I reacted when I saw it falling and push the stick up to prevent the fall but it just regain altituted after it bounced from the ground.  I heared the props hitting the body of the mavic when it hit the ground, then I hover it for a couple of seconds in disbelief on what just happened!
Then again I tried landing, exactly on the same spot without issues. After the crash I inspected the props and both the rear ones got damaged.
The blades also left some scars on the back of the Mavic's body, just above the exhaust vents.
Im really really dissapointed on what just happend and trashed my confidence on my Mavic. Tomorrow I was supposed to get some shots and yes I do have some spare props but Im worried of this happening again.
Mindy and Ken, can you please help me look after this case please? and help me understand what happened??
Details:
Iphone 6,
DJI Go 4 app, latest update.
Firmware : 1.03.0200 (Mavic and Batteries)
Controller as well updated with latest firmware.
As soon as the logs and flight record are downloaded will upload.
Crash Pics:
https://files.mycloud.com/home.php?brand=webfiles&seuuid=bf30218402334f4abf809bdfa7b8ad74&name=Pics
Notice the one that shows the "two holes" that the front arms did on the green. :/
Healthy Drones upload:
http://healthydrones.com/main?flight=7ccbfd791d54e36dbdcae83a72bc9199&page_id=GENERALNotifications
2017-1-13
Nomadic
Flight distance : 754692 ft
China
Flight control log is needed, you need to use the DJI ASSISTANT to export it.
2017-1-13
stratosHD
Nomadic Posted at 2017-1-13 04:11
Thanks buddy I have extracted the full logs, ready to provide.
Care to take a look?
2017-1-13
Wandering Cloud
Flight distance : 839633 ft
7PM good visibility at this time of the year in Switzerland?
2017-1-13
Angelo26
Flight distance : 799718 ft
Austria
Wandering Cloud Posted at 2017-1-13 05:13
well commented
2017-1-13
DJI-Ken
Flight distance : 1515312 ft
I got your PM, thank you.
I've forwarded it on.
Add your email to the PM so I can review the last flight.
2017-1-13
SPARKFLASH
Flight distance : 63743 ft
Did you push both controller joysticks down and to the bottom?  If so thats an emergency ability to make the drone suddenly stop and fall.  That would make sense if thats what happened?
2017-1-13
Mir
Flight distance : 2718491 ft
He's flying the mavic in Australia, not Switzerland
2017-1-13
Wandering Cloud
Mir Posted at 2017-1-13 09:29
In that case it is down to the monochrome surface of the green that cause VPS to stop functioning.
I have similar issue when landing on a super white sandy beach under midday sun.  Sometime the Mavic will land really fast without stoping few feet above the ground first. Had I not react quickly, the drone will smash onto the ground while I try to land the craft.
2017-1-13
Jason Lane
Flight distance : 260144 ft
Philippines
Wandering Cloud Posted at 2017-1-13 10:01
I would have thought the Mavic relies more on the ultrasonic sensors for distance measurement, rather than the optical sensors.
2017-1-13
stratosHD
DJI-Ken Posted at 2017-1-13 07:57
Thanks ken will do it ASAP
2017-1-13
DJI-Ken
stratosHD Posted at 2017-1-13 11:26
Sounds good, thanks.
2017-1-13
Griffith
Flight distance : 98537 ft
Jason Lane Posted at 2017-1-13 10:34
It should use ultrasonic sensors for landing, optical for finding the exact takeoff spot (fine tuning for gps).
If everything was functioning properly, a possible explanation might be a poorly ultrasound - reflective surface, which,  in the case of a Green is improbable.
One question might be how Mavic measures higher altitudes (GPS, barometric pressure ?).  Ultrasound has too short a range - guessing 20-30 ft.
2017-1-13
MacIak
Flight distance : 3419 ft
Griffith Posted at 2017-1-13 13:30
GPS and when atti barometric. Need more size for radio altimeter.
2017-1-13
stratosHD
I thought the mavic had some built in redundancy bot using optical and sonar to find the ground. Can It be that my sensors stopped working for a sec???
2017-1-13
Griffith
MacIak Posted at 2017-1-13 13:36
If barometric pressure is involved in relative altitude determination, it can be off if the local barometric pressure changes.
Out of curiosity, did you notice your displayed relative altitude while you were hovering in preparation for landing?
2017-1-13
Griffith
Having little knowledge of the actual internals of the Mavik systems, I'm relying on how I might have approached the problem as a design engineer.
- GPS can be used to measure altitude (but in my experience is much less accurate than its lateral positioning accuracy.
- Barometric pressure -based altimeters are common in most light aircraft - still not accurate enough to land autonomously, Plus, it's subject to weather conditions.
- Radio altimetry  is accurate but too costly (and not sufficiently miniaturized).
- Ultrasound is accurate but has a limited range.
- monoscopic optical CAN yield some altitude information in very  specific circumstances - like unique and distinctive surface patterns.  I think DJI uses the bottom optics to locate help locate the take-off position using a pattern recognition algorithm
I think If I were designing an autonomously landing drone today, I would utilize GPS or barometric altitude to get within a few feet of ground and then switch to US to get  down the last few feet.  Don't know if that's what DJI did here.  I certainly wouldn't leave US turned on for the entire flight.
Would be really interesting to get some DJI engineering comments on the Mavic landing system. Thanks for letting me brainfart.
2017-1-13
Logger
Flight distance : 2883714 ft
Almost as if it sensed it was on the ground when you were in the hover and it shut the props down when you went Left Stick down. Odd.
Alternatively VPS may have been deactivated by accident or disabled by the system for some reason. Then you would need to stick down much more gently than normal to land.
DJI Ken should be able to see what was going during the landing in the logs. You can also check yourself to see how much downstick you gave it.
2017-1-13
stratosHD
Logger Posted at 2017-1-13 19:02
Yes exactly. That when I commanded to land it felt that it completely shut down the engines as if it believed it was already on the ground.  I was lucky that the damage were only 2 props and some damage to the outside of the craft.
But if it would have hit front first my gimbal would have been hit really hard.
Ken do you have any updates?
2017-1-13
stratosHD
Mate I am in australia, were are in Summer and its quite bright at 7pm.
2017-1-13
stratosHD
SPARKFLASH Posted at 2017-1-13 07:59
No, only push them down ,  from hover down to land the craft.
2017-1-13
