No EXT feed in GS Pro using GH4
841 4 2017-1-13
SkySight Aerial
Flight distance : 3312018 ft
Hi,
Is anyone using GS Pro with A3 and Z15 GH4?  I cannot get any EXT feed from GH4 and only have the option of AV or HDMI in the Camera view. Even using DJI Go on the slave monitor it switches the main controller back to AV/HDMI even if I set it up to EXT before starting GS Pro? The update seems to suggest that you should be able to select the EXT feed from within the GS Pro app but I do not get the option. Anyone out there with the same setup and problem?
2017-1-13
SkySight Aerial
Can anyone help?
2017-1-15
iSkyUnmannedSys
Flight distance : 7152087 ft
I keep telling you about the DJI Industrial Facebook page. DJI reps very active on there. Maybe they could help you out.
2017-1-15
SkySight Aerial
Thanks, I have posted there also with no joy.
2017-1-15
ricci2
Flight distance : 61158 ft
If it helps the ground station team have stoped work on the pc based GS and now only working on the tablet version so the beta team have said.
ricci
2017-1-15
