ducpeter
Flight distance : 62175 ft
i rebuild my S900 with the 1200 propulsion (please use no vibration rubbers on the engines), A3, LB2, Z15 brackets for the M600 Gimbal mounting bracket (https://m.dji.com/product/matric ... al-mounting-bracket)
i check different threads, but i find not all answers in the manuals so DJI please provide us with detailed informations
like voltage informations for X3/X5 cam & gimbal or how to power LB2 airmodul
in my case i mounted the A3 on the top-plate from S900 for the cooling and followed the A3 manual for connetions
setup in the DJI Assistent 2, updated and downgrade 2-3 times before it was possible, please use the version from 2016.10.21
not the 2017
[size=14.666666984558105px]from blade strike:
[size=14.666666984558105px]Update pulled.. You are fine if you didn't use the restore procedure.
[size=14.666666984558105px]http://forum.dji.com/thread-80100-1-1.html
Connections from LB2 by
-DBUS Cable II -> A3 RF Port -> provide 9,0 V DC to the LB2 (measured by myself)
Gimbal Bracket X3/X5
-7-Pin Connector (only 6 wires in) -> LB2
-3 Pin Connector -> Can1 at the A3
-Power XT30 -> XT60 -> S900 board 6S (measured on an Inspire)
from my Z15 Gimbals i used the triangel brackets to get the gimbal closer to the main craft as you can see in the following pictures
