Samsung S2 settings?
2809 30 2017-1-14
Gmman
Flight distance : 1003150 ft
Debugging on or off? Any other settings to make this tab work correctly?Samsung sm-t713. Ive read the older version worked great the new version not so much.
2017-1-14
Hello Gmman, please enable the debugging.  Besides, could you please clarify what's the issue with your tab?
2017-1-15
Gmman
Keeps flashing the opening screen before the app opens never opens the app. and when you open the app ahead of time it does not connect to the Mavic.  The only way to get it to work is have the tablet completely powered off and have the RC and Mavic on before turning on the tablet. Then it will connect the tab to the RC.
2017-1-15
Gmman
Not in English but this is what it does.
2017-1-15
Bobaloo
Flight distance : 42051 ft
I would also like to know.
2017-1-15
Gmman
I kinda think DJI focuses on Apple much more than android.... This Tablet is awesome once I get it to connect. No video latency!  Super picture. Fits into the controller.
2017-1-15
Bobaloo
Have you used it successfully for flight?  I assume you powered on the S2 after the MC and after the drone?
2017-1-15
rapcon
Flight distance : 8871 ft
I have this same issue and you are correct the only way to get it to work is to power completely down and start the app with the controller already connected to the Mavic.
2017-1-15
Gmman
Bobaloo Posted at 2017-1-15 16:08
Yes I have had a few flights with it. No video delay, no app crash, no freeze ups. If the connect issue could be resolved it would be a great tablet for my Mavic!
2017-1-15
Mavicator
Flight distance : 129583 ft
I have the S2 T710 and it has worked flawlessly.  I have heard of others with the 713 having this problem.  They resolved it by doing a factory reset.
2017-1-15
Doots
Flight distance : 682598 ft
Here's my S2, 9.7 inch (model SM-T813) flaking when I try to connect it to the controller too. Looks like the USB is constantly switching between Charging and MTP mode.
2017-1-15
CuaC
Flight distance : 369626 ft
What is the Android version on your tablet? The reboot happens on Samsung devices when they found a critical error, which is probably caused by that connection crazyness. Have you tried to cleanup the usb port? Could it be a misscontact? Have you tried another cable? Does the cable go fully into the socket, or stands out (metal side) quite a lot?
2017-1-16
Doots
From what I've been able to glean from the Internet, it seems samsung tablets models that end with "13" are the one that aren't working right. Mine won't even connect with the work-around some have been able to use where they power on the tablet AFTER the remote and mavic is already connected.
2017-1-16
Gmman
CuaC Posted at 2017-1-16 00:39
Its a brand new tablet purchased specifically for this purpose. Brand new cables tried several. It is a software issue...
2017-1-16
Gmman
Doots Posted at 2017-1-16 01:13
Try this Doots.
Craft off
controller off
S2 Off-Important
Plug in USB to S2 while off
Start controller
Start Craft
Turn on S2
Connected!
2017-1-16
Doots
Gmman Posted at 2017-1-16 15:59
Try this Doots.
Craft off
Tried that a few times.That work-around doesn't work for me.
2017-1-16
Gmman
Doots Posted at 2017-1-16 19:34
Have you gone into developer mode for USB debugging?
2017-1-16
Doots
Gmman Posted at 2017-1-16 19:38
Yes I do have developer mode activated on the tablet and usb debugging turned on.
2017-1-17
Rich32
Flight distance : 4951 ft
I have not flown yet with sm-t713, however it does connect with a reboot.  I have not gone to developers mode.  Is there a reason I should activate usb debugging before flying?
2017-1-21
Gmman
Rich32 Posted at 2017-1-21 12:25
If it works without changing it leave it alone. I really hope they resolve the issue with this tablet. It is very nice to fly with...
2017-1-21
garrepa2
Flight distance : 43612 ft
I have a Samsung Tab 2 SM-T813 running android 6.0.1 and I couldn't get it to connect  Then I  saw this thread. Also found that powering off the tablet, then starting the drone and controller, waiting for them to get ready , then powering on the tablet has worked every time so far.
2017-4-17
Roll Tide
Flight distance : 610502 ft
I have used my Samsung Tab S2 for over a year with my P3S, no problems at all.
2017-4-17
garrepa2
I have the SM-T813 and couldn't get it to connect until I tried the following. 1) power off the tablet, 2) power up the controller and the Mavic, Plug the recharge cable into the front USB on the controller and the other end into the tablet 5) power on the tablet and immediately enter your password if one is required.
2017-4-17
garrepa2
Hopefully you will connect and in my case everything works great! I don't think debugging matters but my is IN debugging mode.
2017-4-17
fans4c24aa26
I had close to the same problem with my galaxy tab e and i found that if i change usb configuration to RNDIS in developer options the problem went away. You just have to switch it to that every time right before connecting the controller...hope this helps
2017-4-24
fansc36c9eff
I just got my Samsung S2 9.7 and I'm also having connectivity issues. I have the T-818v from Verizon. I got this tab because it gives me data as well. I went into the developer mode and turned on debug and RNDIS, but that didn't help me. I was able to do the restart steps, but now that doesn't work. Anyone got any ideas?
2017-4-30
Gmman
fansc36c9eff Posted at 2017-4-30 18:50
Did you turn the tablet completely off then turn on the remote and mavic? Seems to work for most.
Sorry if it doesnt no more suggestions.
2017-4-30
Cagueca
Flight distance : 54147 ft
Switzerland
Mine s2 T813 does this ...
Please Dji add suport for this tablet
2017-4-30
Jenkins
Flight distance : 10814 ft
It is annoying but worth the hassle to be able to use the excellent screen. I already have my tab off. I connect the cables. Turn on remote. Turn on tab. Put remote down and then get the mavic ready. Doesn't actually take any more time that way.
2017-5-1
fansc36c9eff
Gmman Posted at 2017-4-30 19:03
I tried it again today and after 3 tries I was finally able to connect. It is just frustrating to have jump through all of these hoops to fly
2017-5-1
Cagueca
Switzerland
garrepa2 Posted at 2017-4-17 18:28
After 3 times it worked
2017-5-2
